DFU on nRF51822 + iOS -- Have to toggle Bluetooth ON/OFF
I'm wondering (hoping) if there is something that I'm not doing correctly ...
We have a BLE application on the nRF51822 which has been working nicely. It is a custom BLE Service/Characteristic which supports a command/response protocol that we've developed for reading the captured information on our device.
We also support DFU mode -- using the DFU bootloader example -- pretty much AS-IS, except for checking the (gpregret == 1) condition on reset (which we set in the main application via a BLE command).
What 'appears' to be happening is this :
1 -- BLE application is running, connected to the iOS App -- able to view data, etc.
2 -- DFU 'key' is hit in the App which does the following on the device : sd_power_gpregret_set(0x01); sd_nvic_SystemReset();
3 -- The device resets, detects the gpreget bit set -- and (successfully) enters DFU mode.
4 -- We use nRF Toolbox to update the F/W. All works well -- find DfuTarg, select file, file type, etc. Upload is successful. Device resets and is now running with new F/W.
5 -- Here is where it gets 'weird' ? In order to get the device to show-up again (even if I remove power from the device and then bring it back up) -- I must cycle BT Off/On on my iOS device! Our App is looking for it's desired Service UUID (0x1723) and Characteristic (0x1724) -- and doesn't find them.
6 -- Prior to cycling BT Off/On in the Settings Menu -- if I run an App that I downloaded on iTunes : itunes.apple.com/.../id525235616 -- then what I see are the Service/Characteristics (0x1530, 1531, 1523) which are the ones in the DFU Bootloader?!?!
SO -- it seems like somehow/someway? iOS is 'latching' those DFU characteristics -- even though the device is correctly advertising with it's non-DFU (1723/1724) Service/Characteristic.
As soon as I cycle BT Off/On on the iOS device -- even the BLE Tool shows the proper results (0x1723/1724) -- with the device being on throughout all this -- no change to/from DFU mode.
I'm wondering if it there is any chance that iOS is getting irk'd with the fact that the default DFU bootloader calls the device DfuTarg -- and our application code calls it something different?
Appreciate any input/guidance that you might have -- as it just can't be that we have to tell user's to cycle BT after a F/W update!
Cheers, -Tim
  • Still struggling with this one. I did find that the Nordic DFU Bootloader example doesn't have the Service Changed Characteristic enabled. So I enabled that. (It was always enabled in my Application F/W). But it still behaves (more or less) the same -- as if there is still some form of Caching happening on the iOS side? I even changed the DFU bootloader and my Application F/W to have the advertise with the identical device name -- just in case. No change.
