[nRF52840 with zigbee] How to append user data append to HA profile ?
I am developing a system similar to door lock system.
In our system, user data should transmit from ZED(or ZR) to ZC.
So i modified the ZB_ZCL_ON_OFF_SEND_REQ macro to add user data.
With wireshark, packet size is ok (includes the user data bytes).
But i cannot extract appended user data at ZC side.(Light On/Off command can be parsed successfully).
I am using HA profile.
Give some clues.
Thanks.
#define my_ZB_ZCL_ON_OFF_SEND_REQ(                                                         \
    buffer, addr, dst_addr_mode, dst_ep, ep, prof_id, dis_default_resp, command_id, cb) \
  zb_uint8_t* ptr = ZB_ZCL_START_PACKET_REQ(buffer)                                     \
  ZB_ZCL_CONSTRUCT_SPECIFIC_COMMAND_REQ_FRAME_CONTROL(ptr, dis_default_resp)            \
  ZB_ZCL_CONSTRUCT_COMMAND_HEADER_REQ(ptr, ZB_ZCL_GET_SEQ_NUM(), command_id);           \
  ZB_ZCL_PACKET_PUT_DATA8(ptr, 0xab);  \
  ZB_ZCL_PACKET_PUT_DATA8(ptr, 0xcd);  \
  ZB_ZCL_PACKET_PUT_DATA8(ptr, 0xef);  \
  ZB_ZCL_PACKET_PUT_DATA8(ptr, 0x01);  \
  ZB_ZCL_PACKET_PUT_DATA8(ptr, 0xaa);  \
  ZB_ZCL_FINISH_PACKET(buffer, ptr)                                                     \
  ZB_ZCL_SEND_COMMAND_SHORT(                                                            \
      buffer, addr, dst_addr_mode, dst_ep, ep, prof_id, ZB_ZCL_CLUSTER_ID_ON_OFF, cb);  \
    EP handler is called successfully.
    Instead of using "NRF_ZIGBEE_EP_HANDLER_REGISTER(attr, cli_agent_ep_handler_attr)",
    call "ZB_AF_SET_ENDPOINT_HANDLER(10,cli_agent_ep_handler_attr)".
    and cli_agent_ep_handler_attr is called normally.
    But get_attr_table_row_by_sn return "-1".
    What is the problem ?
    Thanks.
    static zb_uint8_t cli_agent_ep_handler_attr(zb_uint8_t param)
    zb_buf_t * p_zcl_cmd_buf = (zb_buf_t *)ZB_BUF_FROM_REF(param);
    zb_zcl_parsed_hdr_t * p_cmd_info = ZB_GET_BUF_PARAM(p_zcl_cmd_buf, zb_zcl_parsed_hdr_t);
    zb_int8_t row;
    /* Get the row in the requests table according by the sequence number */
    row = get_attr_table_row_by_sn(p_cmd_info->seq_number);
  • Hi, .
    Sorry for posting too many.
    Ignore above posts. I will debug and test more deeply and let you know the process.
    Thansk.
    Now registered handler is called when packet is received.
    But i cannot find how to locate "user supplied data".
    Where can i find clues about this ?
    With HA, ZB_ZCL_CLUSTER_ID_ON_OFF command with additional data i added,
    how can access the data.
    Thanks..
  • I got the answer.
    ZB_BUF_BEGIN returns start address of user supplied data.
    as the next step, you may also look into the CLI ping command implementation. It looks like it does exactly the thing that you want to achieve - presents how to send a hand-crafted, raw ZCL packet via Zigbee.
    Over time it got quite complicated (you may want to look inside previous SDKs to check that), so it might not be that easy to understand what's going on inside "cli_agent_ep_handler_ping" (the endpoint handler), but the most important piece is right at the beginning of the function:
    There are two pointers - one of them (p_zcl_cmd_buf) gives you the access to the payload of the received ZCL packet, the other one (p_cmd_info) gives you all additional data from ZCL header and other, lower layers headers you may need (RSSI, addresses, endpoints, cluster ID, profile ID, command ID, sequence number etc.).
    Note that whatever you do inside endpoint handler - you should behave according to the specification. If someone requests a default response - you should send one. Returning ZB_TRUE means that everything related to that packet got processed inside the application (i.e. the buffer got reused or freed), and no further processing will be performed. If you plan to return ZB_FALSE, please remember not to modify the packet, or recover the initial state of the buffer before returning (like endianness). The endpoint handler is a very powerful tool and must be used with care.
    If you plan to implement a custom cluster, the right place to start is to look at the zb_zcl_pressure_measurement.c. This time the profile and cluster ID will be checked automatically by the stack and your role will be to implement all three handlers passed to "zb_zcl_add_cluster_handlers(...)" call. The idea is pretty much the same - you get the payload at the beginning of the buffer and additional data in "buf_param". Using this approach will keep your code clean, much closer to the way other Zigbee devices expect it to be and reusable in further projects.
    Tomchy
