DFU with external QSPI memory
   I am working on project, in which we using nordic nRF52840 chip. We need to flash the app+SD+BL image file in external QSPI memory.
After prevalidation, the DFU controller starts to send flash image package, we need to receive this and need to save in external QSPI memory. Once the postvalidation is successful, then read all the flash image package stored in external QSPI memory and write it to internal flash memory.
For that we use secure bootloader example code as reference file. I need to know where i need to modify the secure bootloader code.
I noticed that after prevalidation, the flash is erased in on_data_obj_create_request() function in nrf_dfu_req_handler.c file, and flash is written in on_data_obj_write_request() under the same c file. Is that right?
Thanks & Regards
Mohammad Gouse
  • Hi Tom
    Can you tell me how you implemented the callback of the SPI (I'm using QSPI but it will be smilar)
    In the function on_data_obj_write_request is the call for nrf_dfu_flash_store (file nrf_dfu_req_handler.c
    static void on_data_obj_write_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
        NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_WRITE (data)");
        if (!nrf_dfu_validation_init_cmd_present())
            /* Can't accept data because DFU isn't initialized by init command. */
            p_res->result = NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED;
            return;
        uint32_t const data_object_offset = s_dfu_settings.progress.firmware_image_offset -
                                            s_dfu_settings.progress.firmware_image_offset_last;
        if ((p_req->write.len + data_object_offset) > s_dfu_settings.progress.data_object_size)
            /* Can't accept data because too much data has been received. */
            NRF_LOG_ERROR("Write request too long");
            p_res->result = NRF_DFU_RES_CODE_INVALID_PARAMETER;
            return;
        uint32_t const write_addr = m_firmware_start_addr + s_dfu_settings.write_offset;
        /* CRC must be calculated before handing off the data to fstorage because the data is
         * freed on write completion.
        uint32_t const next_crc =
            crc32_compute(p_req->write.p_data, p_req->write.len, &s_dfu_settings.progress.firmware_image_crc);
        ASSERT(p_req->callback.write);
        ret_code_t ret =
            nrf_dfu_flash_store(write_addr, p_req->write.p_data, p_req->write.len, p_req->callback.write);
        if (ret != NRF_SUCCESS)
            /* When nrf_dfu_flash_store() fails because there is no space in the queue,
             * stop processing the request so that the peer can detect a CRC error
             * and retransmit this object. Remember to manually free the buffer !
            p_req->callback.write((void*)p_req->write.p_data);
            return;
        /* Update the CRC of the firmware image. */
        s_dfu_settings.write_offset                   += p_req->write.len;
        s_dfu_settings.progress.firmware_image_offset += p_req->write.len;
        s_dfu_settings.progress.firmware_image_crc     = next_crc;
        /* This is only used when the PRN is triggered and the 'write' message
         * is answered with a CRC message and these field are copied into the response.
        p_res->write.crc    = s_dfu_settings.progress.firmware_image_crc;
        p_res->write.offset = s_dfu_settings.progress.firmware_image_offset;
    There is a callback which is needed:
    ret_code_t ret =
    inside this function I use the QSPI function:
    hal_qspi_write(&p_src, len, (dest & EXTERNAL_FLASH_ADDRESS_LOWER_BYTES), (void*)callback))
    which at the end is calling the nrfx function nrfx_qspi_write.
    Here I should have a callback, but I don't know what I should implement.
    The original callback in the nrf_fstorage_write is implemented like this:
    return (p_fs->p_api)->write(p_fs, dest, p_src, len, p_context);
    ret_code_t nrf_fstorage_write(nrf_fstorage_t const * p_fs,
                                  uint32_t               dest,
                                  void           const * p_src,
                                  uint32_t               len,
                                  void                 * p_context)
        NRF_FSTORAGE_PARAM_CHECK(p_fs,        NRF_ERROR_NULL);
        NRF_FSTORAGE_PARAM_CHECK(p_src,       NRF_ERROR_NULL);
        NRF_FSTORAGE_PARAM_CHECK(p_fs->p_api, NRF_ERROR_INVALID_STATE);
        NRF_FSTORAGE_PARAM_CHECK(len,         NRF_ERROR_INVALID_LENGTH);
        /* Length must be a multiple of the program unit. */
        NRF_FSTORAGE_PARAM_CHECK(!(len % p_fs->p_flash_info->program_unit), NRF_ERROR_INVALID_LENGTH);
        /* Source and destination addresses must be word-aligned. */
        NRF_FSTORAGE_PARAM_CHECK(addr_is_aligned32(dest),                NRF_ERROR_INVALID_ADDR);
        NRF_FSTORAGE_PARAM_CHECK(addr_is_aligned32((uint32_t)p_src),     NRF_ERROR_INVALID_ADDR);
        NRF_FSTORAGE_PARAM_CHECK(addr_is_within_bounds(p_fs, dest, len), NRF_ERROR_INVALID_ADDR);
    Now the DFU is strating on bank1 but the App is generating an error because data is missing because of this callack I guess?
