adding SPI to ble_app_uart
im using Feather EVM. im using the app_ble_uart . after i added SPI to the project i dont get any errors but the code does not run (goes to main) and when i press run it goes into hard fault.
the SPI is enabled.
  • i have no need for physical uart pins, i only use it for the ble communication. i am trying to disable it with no success.call-stack is:
    app_error_fault_handler()
    app_error_handler_bare(uint32_t error_code = ?)
    uart_event_handle(app_uart_evt_t * p_event = ?)
    uart_event_handler(struct <Unnamed 41> * p_event = ?, void * p_context = ?)
    uart_evt_handler(nrfx_uart_event_t const * p_event = ?, void * p_context = ?)
    uarte_irq_handler(NRF_UARTE_Type * p_uarte = 0x40002000, uarte_control_block_t * p_cb = m_cb (0x20003DE0))
    <Exception frame>
    [nrfx_coredep_delay_us::delay_machine_code + 0]
  • This looks like it is caused by errors on the UART HW. Try commenting out/remove call to uart_init() in main, this is what initializes the UART peripheral. You will also have to remove calls to app_uart_put() in nus_data_handler(), as calling this when the app_uart library is not initialized will cause errors.
  • thaks
    i did it but now in nrf_drv_uart.h , im getting :
    Building configuration: ble_app_uart_pca10040_s132 - nrf52832_xxaa
    Updating build tree...
    app_uart_fifo.c
    Error[Pe020]: identifier "nrf_uarte_baudrate_t" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.h 122
    Error[Pe020]: identifier "nrf_uarte_error_mask_t" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.h 127
    Error[Pe020]: identifier "nrf_uarte_hwfc_t" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.h 130
    Error[Pe020]: identifier "nrf_uarte_parity_t" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.h 133
    Error[Pe020]: identifier "nrf_uarte_task_t" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.h 134
    Error[Pe020]: identifier "nrf_uarte_event_t" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.h 135
    Error[Pe020]: identifier "NRF_UARTE_PSEL_DISCONNECTED" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\components\libraries\uart\app_uart_fifo.c 151
    Error[Pe020]: identifier "NRF_UARTE_HWFC_DISABLED" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\components\libraries\uart\app_uart_fifo.c 154
    Error[Pe020]: identifier "NRF_UARTE_HWFC_ENABLED" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\components\libraries\uart\app_uart_fifo.c 154
    Error[Pe020]: identifier "NRF_UARTE_PARITY_INCLUDED" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\components\libraries\uart\app_uart_fifo.c 156
    Error[Pe020]: identifier "NRF_UARTE_PARITY_EXCLUDED" is undefined D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\components\libraries\uart\app_uart_fifo.c 156
    Error while running C/C++ Compiler
    main.c
    nrf_drv_uart.c
    Error[Pe550]: variable "config" was set but never used D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.c 124
    Error[Pe550]: variable "m_handlers" was set but never used D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.c 49
    Error[Pe550]: variable "m_contexts" was set but never used D:\Documents\Projects\work facilitation\Miter sow\C ble_app org + spi\integration\nrfx\legacy\nrf_drv_uart.c 50
    Total number of errors: 20
    Total number of warnings: 0
  • You must have made more changes than the ones I suggested to get those errors. Did you modify sdk_config.h or remove some includes/source files?
  • thank you. after clearing all the errors its working.
