Serial bootloader watchdog and RTT print issue
i am currently developing on nRF52840 using SDK 15.2.0. I have an application and a bootloader. I use the GPREGRET register to boot to bootloader.
I have an issue where the WDT does not get reloaded if i do not have a debug printout in the WDT reload request located in nrf_bootloader_wdt.c:
static void wdt_feed(void)
if (nrf_wdt_started())
for (nrf_wdt_rr_register_t i = NRF_WDT_RR0; i < NRF_WDT_RR7; i++)
if (nrf_wdt_reload_request_is_enabled(i))
nrf_wdt_reload_request_set(i);
NRF_LOG_INFO("Feed RR %d wdt", i);
Without the NRF_LOG_INFO printout, the wdt reset is performed after the reload period set in the application has expired. With the print, the reload seems to work and the WDT reset is not performed.
I tried using a delay instead of the printout but that did not help.
Is there some known issue that could be causing this?
BR,
tommi
  • Hi Tommik,
    This is very strange, especially the issue with nrf_clock_lf_is_running().
     Just for clarification, do you see the same issue on the stock bootloader example ? Could you let us know how to reproduce the issue here ?
  • The bootloader i am using is the unchanged UART bootloader SW from SDK 15.2.0, which I compile from source. sdk_config and main are from the secure_bootloader\pca10056_uart_debug example.
    From what i understand, the issue is present with other people also, as in this ticket I linked earlier: https://devzone.nordicsemi.com/f/nordic-q-a/35570/entering-dfu-via-gpreget-secure-bootloader-serial-example-not-feeding-wdt-in-sdkv15/
    From that ticket:
    "I suspect that what is happening is that the event loop / app_scheduler is not working for some reason when the WDT is enabled, and neither the app timer for feeding the WDT nor the app timer for NRF_BL_INACTIVITY_TIMEOUT_MS are working. "
    This is the same exact issue I am witnessing. Others seem to circumvent the problem by implementing an own timer to replace the non-functioning timer.
    Steps to recreate:
    Use nRF5_SDK_15.2.0_9412b96 example in examples\dfu\secure_bootloader\pca10056_uart_debug with the following values changed in the sdk_config:
    #define NRF_BL_DFU_ENTER_METHOD_BUTTON 0
    #define NRF_BL_DFU_ENTER_METHOD_BUTTONLESS 1
    #define NRF_BL_DFU_INACTIVITY_TIMEOUT_MS 180000
    #define NRFX_UARTE_DEFAULT_CONFIG_HWFC 1
    #define NRFX_UART_DEFAULT_CONFIG_HWFC 1
    #define NRF_LOG_BUFSIZE 1024
    Other values in sdk_config are as provided in the example.
    Use an application software with the following WDT setting:
    nrf_drv_wdt_config_t config = {
    .behaviour = 1,
    .reload_value = 20000,
    .interrupt_priority = 6,
    Then start the application. Some time after the application has started, do the following functions:
    err_code = sd_power_gpregret_clr(0, 0xffffffff);
    err_code = sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
    NVIC_SystemReset();
    The bootloader boots into DFU mode. On my application the bootloader starts into DFU mode, and tries to start the dfu timers but they do not start, and a wdt reset happens shortly after. When commenting out the clock check, thus starting the LFCLK, all works fine.
  • Hi Tommik,
    I have tried to reproduce the issue but couldn't. Attached you can find the bootloader and the buttonless application. It works with just the WDT timer to feed the dog ( I commented out the nrf_bootloader_wdt_feed() inside the loop_forever)
    If you comment out  wdt_feed(); inside wdt_feed_timer_handler() you can see that WDT will be triggered after 5 seconds (or 20 seconds if you use your setting). This shows that the timer is working normally. So maybe it needs something else to trigger the issue.
    ble_app_buttonless_dfu - WDT.zip
    pca10040_ble_debug - WDT_bootloader.zip
    If you can modify the projects I sent here to show the issue it would be greatly appreciated.
    I removed the CRC check, you don't need to generate bootloader setting to run the buttonless app. These are based on SDK v15.2
  • Hi Hung,
    unfortunately I do not have any time to debug this at the moment, i will return to you when i find the time.
