My hardware only has one spi slave and one spi master. So can I just set the spi slave miso pin as output in spis_init function? If can not, can I set the pull down resistor on the slave miso pin on spis_init?
So do you mean I can set the intenal pull resistor on spis miso pin?
Yes, you can set the pull configuration in the PIN_CNF[x] register, but, are you sure that's what you want to do?
Yes, I just want to give the miso pin on slave side an const value. The new sdk set this pin pull on master side, but my spi master is an otp mcu. I think the pullup or pull down resistor will cost more power in spi transfer, so I want to set this pin as output.
But SPI requires a constant drive - either high or low - anyhow.
SPI is not open-drain.
Oh, right, the miso is already an output, you just need to set the pull configuration.
Use nrf_gpio_cfg:
dir = NRF_GPIO_PIN_DIR_OUTPUT
input = NRF_GPIO_PIN_INPUT_DISCONNECT
pull = NRF_GPIO_PIN_PULLDOWN
drive = NRF_GPIO_PIN_S0S1
sense = NRF_GPIO_PIN_NOSENSE
