Hi I would like to use sdk15.3 with the \nRF5_SDK_15.3.0_59ac345\components\drivers_ext\lis2dh12 but I need to have it with SPI. Is this possible?
The code I posted above is all the code required to get it working. The difficult part is navigating sd_config.h. I have the following enabled (all others set to '0')::
#define NRFX_SPI2_ENABLED 1 #define NRFX_SPIM2_ENABLED 1 #define SPI2_ENABLED 1 #define SPI2_USE_EASY_DMA 1
The various macros mess with these settings, so I don't actually know if they are correct, but it seems to work!
Start by reading the Id code:
// Device identification register - LIS3DH has same code as LIS2DH12
#define WHO_AM_I 0x0F
#define I_AM_LIS3DH 0x33
#define I_AM_LIS2DH 0x33
* @brief SPI event handler indicating SPI transfer has completed
* @param event
static void acc_spi_event_handler(nrf_drv_spi_evt_t const * p_event, void *p_context)
mAccPacketTransferComplete = true;
* @brief Function Send a command to read Id
* This function sends a one-byte command to ACC via SPI
* @param[in] none
static uint8_t AccWhoAmI(void)
uint8_t tx_buf[] = {0x80|LIS2DH12_WHO_AM_I, 0xFF};
uint8_t rx_buf[sizeof(tx_buf)];
uint16_t length = sizeof(tx_buf);
memset(rx_buf, '?', length);
mAccPacketTransferComplete = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&mAccSpiInstance, tx_buf, length, rx_buf, length));
// Check for successful transfer
while (!mAccPacketTransferComplete) ;
// Confirm we have a connection, should be I_AM_LIS2DH
return rx_buf[1];
Hi hmolesworth,
thanks, but the lis2dh12 from the drivers_ext are using TWI can we just use it without changing anything? ret_code_t lis2dh12_cfg_commit(lis2dh12_instance_t * p_inst)
ASSERT(p_inst != NULL);
ret_code_t err;
p_inst->ctrl0 &= ~LIS2DH12_CTRL_REG0_VALID_MASK;
p_inst->ctrl0 |= LIS2DH12_CTRL_REG0_VALID_SET;
uint8_t ctrl_msg[] = {
LIS2DH12_REG_CTRL_REG0 | LIS2DH12_AUTO_INCR_MASK,
p_inst->ctrl0,
p_inst->temp_cfg,
p_inst->ctrl1,
p_inst->ctrl2,
p_inst->ctrl3,
p_inst->ctrl4,
p_inst->ctrl5,
p_inst->ctrl6,
p_inst->reference
err = nrf_twi_sensor_write(p_inst->p_sensor_data,
p_inst->sensor_addr,
ctrl_msg,
ARRAY_SIZE(ctrl_msg),
true);
RETURN_IF_ERR(err);
uint8_t fifo_msg[] = {
LIS2DH12_REG_FIFO_CTRL | LIS2DH12_AUTO_INCR_MASK,
p_inst->fifo_ctrl,
0,
p_inst->int1_cfg,
0,
p_inst->int1_ths,
p_inst->int1_dur,
p_inst->int2_cfg,
0,
p_inst->int2_ths,
p_inst->int2_dur,
p_inst->click_cfg
fifo_msg,
ARRAY_SIZE(fifo_msg),
true);
RETURN_IF_ERR(err);
uint8_t time_msg[] = {
LIS2DH12_REG_CLICK_THS | LIS2DH12_AUTO_INCR_MASK,
p_inst->click_ths,
p_inst->time_lim,
p_inst->latency,
p_inst->time_win,
p_inst->act_ths,
p_inst->act_dur
time_msg,
ARRAY_SIZE(time_msg),
true);
return err;
I am really confuse that where should I start from what you said.
* @param event
* @param[in] none
return rx_buf[1];
For instance, there do you mean to put these code? in the main.c ? or the lis2dh12 driver.
Thank you very much !
sorry that I am really confuse.
there is no SPIM for my case, I am using 15.3 SDK nRF5_SDK_15.3.0_59ac345\examples\peripheral\spi_master_using_nrf_spi_mngr
Is this the same? but there is a LCD with the example which makes the code more complex.
Don't use any of the i2c files and settings; SPI is much simpler and I see you don't have i2c anyway ..
I believe this is twi mean i2C nrf_twi_sensor_write(p_inst->p_sensor_data,p_inst->sensor_addr,time_msg,ARRAY_SIZE(time_msg),true); can you please let me know how exactly you make this work for spi? where should the place to add your code in. I really need this urgently.
Thanks!
