How to implement CODED_PHY in ble_app_uart in SDK 15.3.0
I am working long nrf52840 and trying to implement long range in my project. There were examples in SDK 15.2.0 but i couldn't find any example or post which is related to SDK 15.3.0. I tried my own modification like changing the advertising layer from 1 Mbps to CODED in ble_adverstisement.c file(15.3.0) but after i made the changes my device keep resetting. I did not make any other changes in sdk_config and main. file
p_advertising->adv_params.secondary_phy   = BLE_GAP_PHY_CODED;
this line i added in ble_advertisement_init() function. i don't more what changes need to be done to make it work in coded mode.
  • i have attached the main.c file and copy of ble_advertisng.c where i made changes for coded mode testing.is there any changes need to be done in sdk_config.h also?
    // ble_advertising.c
    #define BLE_APP_UART_CODED_ENABLED 1
    uint32_t ble_advertising_init(ble_advertising_t            * const p_advertising,
                                  ble_advertising_init_t const * const p_init)
        uint32_t ret;
        if ((p_init == NULL) || (p_advertising == NULL))
            return NRF_ERROR_NULL;
        if (!config_is_valid(&p_init->config))
            return NRF_ERROR_INVALID_PARAM;
        p_advertising->adv_mode_current               = BLE_ADV_MODE_FAST;
        p_advertising->adv_modes_config               = p_init->config;
        p_advertising->conn_cfg_tag                   = BLE_CONN_CFG_TAG_DEFAULT;
        p_advertising->evt_handler                    = p_init->evt_handler;
        p_advertising->error_handler                  = p_init->error_handler;
        p_advertising->current_slave_link_conn_handle = BLE_CONN_HANDLE_INVALID;
        p_advertising->p_adv_data                     = &p_advertising->adv_data;
        //p_advertising->adv_modes_config.ble_adv_extended_enabled = true;
        memset(&p_advertising->peer_address, 0, sizeof(p_advertising->peer_address));
        // Copy advertising data.
        if (!p_advertising->initialized)
            p_advertising->adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
        p_advertising->adv_data.adv_data.p_data = p_advertising->enc_advdata;
        if (p_advertising->adv_modes_config.ble_adv_extended_enabled == true)
    #ifdef BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED
            p_advertising->adv_data.adv_data.len = BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED;
    #else
        p_advertising->adv_data.adv_data.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX;
    #endif // BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED
        ret = ble_advdata_encode(&p_init->advdata, p_advertising->enc_advdata, &p_advertising->adv_data.adv_data.len);
        VERIFY_SUCCESS(ret);
        p_advertising->adv_data.scan_rsp_data.p_data = p_advertising->enc_scan_rsp_data;
            p_advertising->adv_data.scan_rsp_data.len = BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_CONNECTABLE_MAX_SUPPORTED;
    #else
            p_advertising->adv_data.scan_rsp_data.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX;
        ret = ble_advdata_encode(&p_init->srdata,
                                  p_advertising->adv_data.scan_rsp_data.p_data,
                                 &p_advertising->adv_data.scan_rsp_data.len);
        // Configure a initial advertising configuration. The advertising data and and advertising
        // parameters will be changed later when we call @ref ble_advertising_start, but must be set
        // to legal values here to define an advertising handle.
        p_advertising->adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        #ifdef BLE_APP_UART_CODED
        p_advertising->adv_params.primary_phy     = BLE_GAP_PHY_CODED;
        p_advertising->adv_params.duration        = p_advertising->adv_modes_config.ble_adv_fast_timeout;
        p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
        p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
        p_advertising->adv_params.p_peer_addr     = NULL;
        p_advertising->adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        p_advertising->adv_params.interval        = p_advertising->adv_modes_config.ble_adv_fast_interval;
        ret = sd_ble_gap_adv_set_configure(&p_advertising->adv_handle, &p_advertising->adv_data, &p_advertising->adv_params);
        p_advertising->initialized = true;
        return ret;
    uint32_t ble_advertising_start(ble_advertising_t * const p_advertising,
                                   ble_adv_mode_t            advertising_mode)
        uint32_t ret;
        if (p_advertising->initialized == false)
        p_advertising->adv_mode_current = advertising_mode;
        if (  ((p_advertising->adv_modes_config.ble_adv_directed_high_duty_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
            ||((p_advertising->adv_modes_config.ble_adv_directed_enabled)           && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
            ||((p_advertising->adv_modes_config.ble_adv_directed_enabled)           && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED))
            if (p_advertising->evt_handler != NULL)
                p_advertising->peer_addr_reply_expected = true;
                p_advertising->evt_handler(BLE_ADV_EVT_PEER_ADDR_REQUEST);
                p_advertising->peer_addr_reply_expected = false;
        p_advertising->adv_mode_current = adv_mode_next_avail_get(p_advertising, advertising_mode);
        // Fetch the whitelist.
        if ((p_advertising->evt_handler != NULL) &&
            (p_advertising->adv_mode_current == BLE_ADV_MODE_FAST || p_advertising->adv_mode_current == BLE_ADV_MODE_SLOW) &&
            (p_advertising->adv_modes_config.ble_adv_whitelist_enabled) &&
            (!p_advertising->whitelist_temporarily_disabled))
            p_advertising->whitelist_in_use         = false;
            p_advertising->whitelist_reply_expected = true;
            p_advertising->evt_handler(BLE_ADV_EVT_WHITELIST_REQUEST);
            p_advertising->whitelist_reply_expected = false;
        // Initialize advertising parameters with default values.
        memset(&p_advertising->adv_params, 0, sizeof(p_advertising->adv_params));
        // Use 1MBIT as primary phy if no phy was selected.
        if (phy_is_valid(&p_advertising->adv_modes_config.ble_adv_primary_phy))
            p_advertising->adv_params.primary_phy = p_advertising->adv_modes_config.ble_adv_primary_phy;
        if (p_advertising->adv_modes_config.ble_adv_extended_enabled)
            // Use 1MBIT as secondary phy if no phy was selected.
                p_advertising->adv_params.secondary_phy = p_advertising->adv_modes_config.ble_adv_secondary_phy;
                p_advertising->adv_params.secondary_phy = BLE_GAP_PHY_1MBPS;
        // Set advertising parameters and events according to selected advertising mode.
        switch (p_advertising->adv_mode_current)
            case BLE_ADV_MODE_DIRECTED_HIGH_DUTY:
                ret = set_adv_mode_directed_high_duty(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_DIRECTED:
                ret = set_adv_mode_directed(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_FAST:
                ret = set_adv_mode_fast(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_SLOW:
                ret = set_adv_mode_slow(p_advertising, &p_advertising->adv_params);
            case BLE_ADV_MODE_IDLE:
                p_advertising->adv_evt = BLE_ADV_EVT_IDLE;
        if (p_advertising->adv_mode_current != BLE_ADV_MODE_IDLE)
            //#ifndef BLE_APP_UART_CODED
            uint8_t *p_data_test = p_advertising->p_adv_data->adv_data.p_data;
            for(int d=0;d<31;d++){
            printf("\n value %d = %X",d,*p_data_test);
            p_data_test++;
            nrf_delay_ms(10);
            if (ret != NRF_SUCCESS)
                return ret;
            //#endif
            ret = sd_ble_gap_adv_start(p_advertising->adv_handle, p_advertising->conn_cfg_tag);
                return ret;
            p_advertising->evt_handler(p_advertising->adv_evt);
        return NRF_SUCCESS;
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_drv_clock.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "boards.h"
    #include "nrf_drv_twi.h"
    #include "app_error.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART_TEST"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_BLE // changed for testing 4/30/19                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                500                                         /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                100                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    APP_TIMER_DEF(m_repeated_timer_id);
    APP_TIMER_DEF(m_repeated_timer_id_1);
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static void advertising_start();
    static void advertising_init(void);
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
        {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE} // BLE_UUID_NUS_SERVICE changed from 0x0001 to 0x0008
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    static void ardu_slave(void);
    static uint32_t counter;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    /* Buffer for samples read from temperature sensor. */
    static uint8_t m_sample;
    static volatile char reg[5];
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    static void repeated_timer_handler(void * p_context)
        /*nrf_gpio_pin_clear(16);
        nrf_delay_ms(300);
        nrf_gpio_pin_set(16);*/
        //ardu_slave(); // un comment to get i2c data from the slave by sending request
        counter++;
        advertising_init();
    static void create_timers()
        ret_code_t err_code;
        // Create timers
        err_code = app_timer_create(&m_repeated_timer_id_1,
                                    APP_TIMER_MODE_REPEATED,
                                    repeated_timer_handler);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    __STATIC_INLINE void data_handler(char temp[])
        char* data=temp;
        printf("\n data_handler : ");
        for(int i=0;i<5;i++)
          printf("%c",*data);
          data++;
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
        switch (p_event->type)
            case NRF_DRV_TWI_EVT_DONE:
                if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                    data_handler(reg);
                    m_xfer_done = true;
    void twi_init (void)
        const nrf_drv_twi_config_t twi_lm75b_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
        nrf_drv_twi_enable(&m_twi);
        reg[i] = '\0';
      err_code = nrf_drv_twi_rx(&m_twi,0x02,&reg,sizeof(reg)); // 0x02 i2c slave address of arduino
      while(m_xfer_done == false);
      m_xfer_done= false;
      if(err_code == NRF_SUCCESS)
        NRF_LOG_INFO("READ SUCCESS");
      printf("\n received bytes %c%c%c%c%c",reg[0],reg[1],reg[2],reg[3],reg[4]);
      NRF_LOG_FLUSH();
     * @brief Function for reading data from temperature sensor.
    static void lfclk_config(void)
        ret_code_t err_code = nrf_drv_clock_init();
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        nrf_delay_ms(500);
        //disabled_uart();
        // Prepare wakeup buttons.
        /*err_code = bsp_btn_ble_sleep_mode_prepare();
        APP_ERROR_CHECK(err_code);*/
        /*err_code = sd_power_system_off();
       //sd_app_evt_wait();
        //TO disable UART peripheral
       /* *(volatile uint32_t *)0x40002FFC = 0;
        *(volatile uint32_t *)0x40002FFC;
        *(volatile uint32_t *)0x40002FFC = 1;*/
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
       // TO change mode of connection go to sdk_config.h and enable or disable BLE_APP_UART_NON_CONNECT for particular use case.
        ble_advertising_init_t init;
        ble_advdata_manuf_data_t                  manuf_data; //Variable to hold manufacturer specific data
        char data[5]; //Our data to advertise
        /*for(int i=0;i<5;i++)
          data[i]=reg[i];
          printf("%c",data[i]);
        }*/                            // uncomment above to send TWI data
        //data[0] = counter;
        printf("\n");
        manuf_data.company_identifier             = 0x0059; //Nordics company ID
        manuf_data.data.p_data                    = data;
        if(data[0] == 255)
          //counter = 0;
        manuf_data.data.size                      = sizeof(data);
        init.advdata.p_manuf_specific_data = &manuf_data;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        ble_advertising_init(&m_advertising, &init);
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        nrf_gpio_cfg_output(13);
        nrf_gpio_pin_clear(13);
        nrf_delay_ms(500);
        nrf_gpio_pin_set(13);
    /**@brief Application main function.
        nrf_gpio_cfg_output(16);
        nrf_delay_ms(500);
        nrf_delay_ms(2000);
        bool erase_bonds;
        //TWI WAS DISABLED. TO ENABLE CHANGE TWI OPTION TO SET IN CMSIS OF SDK_CONFIG.H
        // Initialize.
        uart_init(); // don't comment out this function and don't disable any uart config in
        log_init();
        timers_init();
        create_timers();
        app_timer_start(m_repeated_timer_id_1, APP_TIMER_TICKS(11000), NULL);
        //buttons_leds_init(&erase_bonds);
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        //twi_init();
        // Start execution.
        //printf("\r\nUART started.\r\n");
        // Enter main loop.
        for (;;)
            idle_state_handle();
    whenever code is at sd_ble_gap_adv_set_configure() device resets and if i comment it then it is advertising in legacy mode even if the primary_phy i made as coded phy in ble_advertisng_init().
  • Hi.
    You really should not modify source files inside the SDK, this can have unwelcome consequences.
    I suggest that you revert the modifications you have made in ble_advertisng.c, and take a look at how have implemented BLE_GAP_PHY_CODED in the GitHub link he attached in his reply, you should only have to modify advertising_init in order to configure coded phy.
    Andreas
  • i have tried your code now what is happening is peripheral is transmitting and central is powered but it is not receiving any packet from peripheral. It receives only one packet whenever i hit reset button in central and stops. can you tell me how to receive packets continue?
    i added RSSI print in BLE_GAP_EVT_ADV_REPORT switch case in ble_evt_handler() function to check the packets are receiving are not.
  • Hi.
    Are you running the demo code? Or have you combined the demo code with your code?
    Andreas
