Can't reconnect to MQTTSN gateway
I have been running a mqttsn client publisher/subscriber project (based on the example) successfully for some months.  I have added a mosquitto broker to the raspberry pi border router.  Each thread node publishes data every 10 seconds.
SDK:   nRF5_SDK_for_Thread_and Zigbee_2.0.0
RaspPi image:   RaspPi_Thread_Border_Router_Demo_2.0.0-1.alpha
I turned both the raspberry pi and thread node on at the same time several weeks ago.  Today, the connection to the broker was lost and cannot be regained.  A second thread node with debugger attached shows that the gateway is found, but the connection ( mqttsn_client_connect(&m_client, &m_gateway_addr, m_gateway_id, &m_connect_opt); ) times out repeatedly.   I am assuming the Thread network connection is ok, since the gateway was found.
My PC remains connected to the broker on the raspberry pi, but is not receiving any messages.  I have repeatedly restarted the node attached to the debugger, and it continues to timeout on the mqtt gateway connection.
This error occurs infrequently (only after running continuously for several weeks).  What can I check on the raspberry pi to diagnose the problem?
Mary
  • Yes, as I mentioned above.
    I've also looked at the MQTT-SNGateway code at github.  There's a limit of 100 connections, after that no more can be accepted.  The current version of the software provides for re-using a connection when a device re-connects after a disconnection.  I wonder if this provision is missing in the 1.0.1 version that is installed on the 3.1.0 Border Router, such that after 100 Thread device reboots all connections fail.
    I'd like to try the latest version of MQTT-SNGateway, and just wanted some guidance on how to do that without breaking anything.
    Mary
  • Hi.
    Sorry for the late reply, I've been out of office for a while.
    I have forwarded this to our development team to get some assistance from them.
    Andreas
  • Hi.
    Still waiting on reply from the development team.
    Andreas
  • I was able to download and compile the latest MQTTSN-Gateway.  This solved my problem.  I was able to have a node reboot every 10 seconds and successfully reconnect for several hours.
    Instructions for compiling the MQTTSN-Gateway are here.
    Here's what I did:
    Before compiling on the RaspberryPi, first install ssl-dev.  This adds header files, etc so you can compile OpenSSL dependent code..
    $ sudo apt-get update
    $ sudo apt-get install libssl-dev
    Create a working directory.  I used /home/pi/Projects.
    Next, build the gateway:
    $ cd ~
    $ mkdir Projects
    $ cd Projects
    $ git clone -b experiment https://github.com/eclipse/paho.mqtt-sn.embedded-c
    $ cd paho.mqtt-sn.embedded-c/MQTTSNGateway
    $ make SENSORNET=udp6
    $ make install INSTALL_DIR=/home/pi/Projects/MQTTSNGateway_v1.3.1 CONFIG_DIR=/home/pi/Projects/MQTTSNGateway_v1.3.1
    $ make clean
    Stop the currently running gateway:
    $ sudo systemctl stop paho-mqttsn-gateway.service
    Edit the service file:
    $ sudo nano /etc/systemd/system/paho-mqttsn-gateway.service
    Change the ExecStart line to explicitly specify the configuration file:
    ExecStart=/usr/sbin/MQTT-SNGateway -f /etc/paho-mqtt-sn-gateway.conf
    Copy the predefinedTopics.conf file from the CONFIG_DIR to /etc or add a new file for predefined topics and edit as needed.
    $ sudo nano /etc/predefinedTopic.conf
    Make a backup of the original executable and copy the new one to /usr/sbin:
    $ sudo cp /usr/sbin/MQTT-SNGateway /usr/sbin/MQTT-SNGateway_v1.0.1
    $ sudo cp /home/pi/Projects/MQTTSNGateway_v1.3.1/MQTT-SNGateway /usr/sbin/MQTT-SNGateway
    $ make clean
    Restart the gateway:
    $ sudo systemctl start paho-mqttsn-gateway.service
    Viewing the systemd log will show the gateway activity.
    $ journalctl -ef
