Try to transfert ADC sampling signal by BLE.
I am trying to transfer a signal sampled on AN0 (P0.02)  at 16kHz via Bluetooth using an ATT MTU of 247 and a 2MBPS PHY speed. The basis project used is  examples \ ble_central_and_peripheral \ experimental \ ble_app_att_mtu_throughput.
I also used  examples \ peripheral \ saadc for sampling trigger based on a timer 2 configuration.
  • If I test the signal sampling and disable the BLE pairing +vdata transfer, i can notice a good sampling.
  • When I disable the ADC sampling T(bsaadc_sampling_event_enable ()  )and test the pairing and data transfer, the operation is correct.
  • If I enable sampling and data transfer by BLE, the Bluetooth stack no longer works (the pairing does not run). I tried to use SAADC sampling using other Timers and the problem is not solved.I notice that the timer activation generates a conflict with the bluetooth stack.
I hope you can help me with the code I am writing below.
Thanks in advance,
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/**@cond To Make Doxygen skip documentation generation for this file.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "nordic_common.h"
#include "nrf.h"
#include "sdk_config.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "amt.h"
#include "counter.h"
#include "ble.h"
#include "ble_gatt.h"
#include "ble_hci.h"
#include "nrf_gpio.h"
#include "bsp_btn_ble.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "app_error.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "app_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "iirfilter.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define DATA_LENGTH_DEFAULT 27 /**< The stack default data length. */
#define DATA_LENGTH_MAX 251 /**< The stack maximum data length. */
#define CONN_INTERVAL_DEFAULT (uint16_t)(MSEC_TO_UNITS(7.5, UNIT_1_25_MS)) /**< Default connection interval used at connection establishment by central side. */
#define CONN_INTERVAL_MIN (uint16_t)(MSEC_TO_UNITS(7.5, UNIT_1_25_MS)) /**< Minimum acceptable connection interval, in units of 1.25 ms. */
#define CONN_INTERVAL_MAX (uint16_t)(MSEC_TO_UNITS(500, UNIT_1_25_MS)) /**< Maximum acceptable connection interval, in units of 1.25 ms. */
#define CONN_SUP_TIMEOUT (uint16_t)(MSEC_TO_UNITS(4000, UNIT_10_MS)) /**< Connection supervisory timeout (4 seconds). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define SCAN_ADV_LED BSP_BOARD_LED_0
#define READY_LED BSP_BOARD_LED_1
#define PROGRESS_LED BSP_BOARD_LED_2
#define DONE_LED BSP_BOARD_LED_3
#define START_BUTTON BSP_BUTTON_2 /**< Button to press at the beginning of the test to indicate that this board is connected to the PC and takes input from it via the UART. */
//#define BOARD_DUMMY_BUTTON BSP_BUTTON_3 /**< Button to press at the beginning of the test to indicate that this board is standalone (automatic behavior). */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that refers to the BLE stack configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
#define SAADC_SAMPLE_RATE 80 /**< SAADC sample rate in us. */
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(2);
static nrf_saadc_value_t m_buffer_pool[2];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
static uint32_t wait_filter_time_const = 0;
int16_t adc_buffer[2000];
static char flagsend = 1;
//static nrf_saadc_value_t adc_buf[2];
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
//typedef enum
// NOT_SELECTED = 0x00,
// BOARD_TESTER,
// BOARD_DUMMY,
//} board_role_t;
typedef struct
uint16_t att_mtu; /**< GATT ATT MTU, in bytes. */
uint16_t conn_interval; /**< Connection interval expressed in units of 1.25 ms. */
ble_gap_phys_t phys; /**< Preferred PHYs. */
uint8_t data_len; /**< Data length. */
bool conn_evt_len_ext_enabled; /**< Connection event length extension status. */
} test_params_t;
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery); /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
static nrf_ble_amtc_t m_amtc;
static nrf_ble_amts_t m_amts;
NRF_SDH_BLE_OBSERVER(m_amtc_ble_obs, BLE_AMTC_BLE_OBSERVER_PRIO, nrf_ble_amtc_on_ble_evt, &m_amtc);
NRF_SDH_BLE_OBSERVER(m_amts_ble_obs, BLE_AMTS_BLE_OBSERVER_PRIO, nrf_ble_amts_on_ble_evt, &m_amts);
static bool volatile m_run_test;
static bool volatile m_notif_enabled;
static bool volatile m_mtu_exchanged;
static bool volatile m_data_length_updated;
static bool volatile m_phy_updated;
static bool volatile m_conn_interval_configured;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current BLE connection .*/
static uint8_t m_gap_role = BLE_GAP_ROLE_INVALID; /**< BLE role for this connection, see @ref BLE_GAP_ROLES */
//// Name to use for advertising and connection.
static char const m_target_periph_name[] = DEVICE_NAME;
void test_begin(void);
// Test parameters.
// Settings like ATT MTU size are set only once, on the dummy board.
// Make sure that defaults are sensible.
static test_params_t m_test_params =
.att_mtu = NRF_SDH_BLE_GATT_MAX_MTU_SIZE,
.data_len = NRF_SDH_BLE_GAP_DATA_LENGTH,
.conn_interval = CONN_INTERVAL_DEFAULT,
.conn_evt_len_ext_enabled = true,
// Only symmetric PHYs are supported.
#if defined(S140)
.phys.tx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
.phys.rx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
#else
.phys.tx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS,
.phys.rx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS,
// Connection parameters requested for connection.
static ble_gap_conn_params_t m_conn_param =
.min_conn_interval = CONN_INTERVAL_MIN, // Minimum connection interval.
.max_conn_interval = CONN_INTERVAL_MAX, // Maximum connection interval.
.slave_latency = SLAVE_LATENCY, // Slave latency.
.conn_sup_timeout = CONN_SUP_TIMEOUT // Supervisory timeout.
static void test_terminate(void);
void data_len_set(uint8_t value);
static bool is_test_ready()
return ( m_conn_interval_configured
&& m_notif_enabled
&& m_mtu_exchanged
&& (m_data_length_updated || m_test_params.data_len == DATA_LENGTH_DEFAULT)
&& m_phy_updated
&& !m_run_test);
ret_code_t err_code;
float adc_value,adc_value_filered;
uint8_t value[2];
uint8_t bytes_to_send;
// set buffers
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
// print samples on hardware UART and parse data for BLE transmission
// printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
bsp_board_led_invert(PROGRESS_LED);
// printf("%d\r\n", p_event->data.done.p_buffer[0]);
adc_value = (float)p_event->data.done.p_buffer[0];
IRBiquadForm1PS(&adc_value, &adc_value_filered);
adc_buffer[m_adc_evt_counter] = (int16_t)adc_value_filered;
// value[0] = adc_value;
// value[1] = adc_value >> 8;
// Send data over BLE via NUS service. Makes sure not to send more than 20 bytes.
if((1*2) <= 20)
bytes_to_send = (1*2);
bytes_to_send = 20;
// err_code = ble_nus_string_send(&m_nus, value, bytes_to_send);
// if (err_code != NRF_ERROR_INVALID_STATE)
// APP_ERROR_CHECK(err_code);
if((m_adc_evt_counter < 2000) && (wait_filter_time_const > 1000 ))
m_adc_evt_counter++;
wait_filter_time_const++;
void timer_handler(nrf_timer_event_t event_type, void* p_context)
nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
/* setup m_timer for compare event */
uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
// printf("get tick %ld \n", ticks );
nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
void saadc_sampling_event_disable(void)
ret_code_t err_code = nrf_drv_ppi_channel_disable(m_ppi_channel);
void saadc_init(void)
nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
//Configure SAADC channel
nrf_saadc_channel_config_t config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0); //Disable pulldown resistor on the input pin
err_code = nrf_drv_saadc_channel_init(0, &config);
err_code = nrf_drv_saadc_buffer_convert(&m_buffer_pool[0],1);
err_code = nrf_drv_saadc_buffer_convert(&m_buffer_pool[1],1);
char const * phy_str(ble_gap_phys_t phys)
static char const * str[] =
"1 Mbps",
"2 Mbps",
"Coded",
"Unknown"
switch (phys.tx_phys)
case BLE_GAP_PHY_1MBPS:
return str[0];
case BLE_GAP_PHY_2MBPS:
case BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS:
case BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED:
return str[1];
case BLE_GAP_PHY_CODED:
return str[2];
return str[3];
//static void instructions_print(void)
// printf("Type 'config' to change the configuration parameters.");
// printf("You can use the Tab key to autocomplete your input.");
// printf("Type 'run' when you are ready to run the test.");
/**@brief Function for handling BLE_GAP_EVT_CONNECTED events.
* Save the connection handle and GAP role, then discover the peer DB.
static void on_ble_gap_evt_connected(ble_gap_evt_t const * p_gap_evt)
m_conn_handle = p_gap_evt->conn_handle;
m_gap_role = p_gap_evt->params.connected.role;
if (m_gap_role == BLE_GAP_ROLE_PERIPH)
printf("Connected as a peripheral.\n");
else if (m_gap_role == BLE_GAP_ROLE_CENTRAL)
printf("Connected as a central.\n");
// Stop scanning and advertising.
nrf_ble_scan_stop();
(void) sd_ble_gap_adv_stop(m_adv_handle);
bsp_board_leds_off();
// Assign connection handle to the Queued Write module.
printf("Discovering GATT database...\n");
err_code = ble_db_discovery_start(&m_ble_db_discovery, p_gap_evt->conn_handle);
printf("Sending PHY Update, %s \n.", phy_str(m_test_params.phys));
err_code = sd_ble_gap_phy_update(p_gap_evt->conn_handle, &m_test_params.phys);
/**@brief Function for handling BLE_GAP_EVT_DISCONNECTED events.
* Unset the connection handle and terminate the test.
static void on_ble_gap_evt_disconnected(ble_gap_evt_t const * p_gap_evt)
printf("Disconnected: reason 0x%x. \n", p_gap_evt->params.disconnected.reason);
// bsp_board_leds_off();
if (m_run_test)
NRF_LOG_WARNING("GAP disconnection event received while test was running.")
test_terminate();
/**@brief Function for handling BLE Stack events.
* @param[in] p_ble_evt Bluetooth stack event.
uint32_t err_code;
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
on_ble_gap_evt_connected(p_gap_evt);
on_ble_gap_evt_disconnected(p_gap_evt);
case BLE_GAP_EVT_CONN_PARAM_UPDATE:
m_conn_interval_configured = true;
printf("Connection interval updated: 0x%x, 0x%x. \n",
p_gap_evt->params.conn_param_update.conn_params.min_conn_interval,
p_gap_evt->params.conn_param_update.conn_params.max_conn_interval);
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accept parameters requested by the peer.
ble_gap_conn_params_t params;
params = p_gap_evt->params.conn_param_update_request.conn_params;
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle, &params);
printf("Connection interval updated (upon request): 0x%x, 0x%x.\n",
p_gap_evt->params.conn_param_update_request.conn_params.min_conn_interval,
p_gap_evt->params.conn_param_update_request.conn_params.max_conn_interval);
} break;
err_code = sd_ble_gatts_sys_attr_set(p_gap_evt->conn_handle, NULL, 0, 0);
} break;
case BLE_GATTC_EVT_TIMEOUT: // Fall through.
case BLE_GATTS_EVT_TIMEOUT:
NRF_LOG_DEBUG("GATT timeout, disconnecting.");
err_code = sd_ble_gap_disconnect(m_conn_handle,
} break;
case BLE_GAP_EVT_PHY_UPDATE:
ble_gap_evt_phy_update_t const * p_phy_evt = &p_ble_evt->evt.gap_evt.params.phy_update;
if (p_phy_evt->status == BLE_HCI_STATUS_CODE_LMP_ERROR_TRANSACTION_COLLISION)
// Ignore LL collisions.
NRF_LOG_DEBUG("LL transaction collision during PHY update.");
m_phy_updated = true;
ble_gap_phys_t phys = {0};
phys.tx_phys = p_phy_evt->tx_phy;
phys.rx_phys = p_phy_evt->rx_phy;
printf("PHY update %s. PHY set to %s. \n",
(p_phy_evt->status == BLE_HCI_STATUS_CODE_SUCCESS) ?
"accepted" : "rejected",
phy_str(phys));
} break;
} break;
// No implementation needed.
/**@brief AMT server event handler. */
static void amts_evt_handler(nrf_ble_amts_evt_t evt)
switch (evt.evt_type)
case NRF_BLE_AMTS_EVT_NOTIF_ENABLED:
printf("Notifications enabled. \n");
// bsp_board_led_on(READY_LED);
m_notif_enabled = true;
if (m_test_params.conn_interval != CONN_INTERVAL_DEFAULT)
NRF_LOG_DEBUG("Updating connection parameters..");
m_conn_param.min_conn_interval = m_test_params.conn_interval;
m_conn_param.max_conn_interval = m_test_params.conn_interval;
err_code = sd_ble_gap_conn_param_update(m_conn_handle, &m_conn_param);
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("sd_ble_gap_conn_param_update() failed: 0x%x.", err_code);
} break;
case NRF_BLE_AMTS_EVT_NOTIF_DISABLED:
printf("Notifications disabled.\n");
// bsp_board_led_off(READY_LED);
} break;
case NRF_BLE_AMTS_EVT_TRANSFER_1KB:
printf("Sent %u KBytes \n", (evt.bytes_transfered_cnt / 1024));
// bsp_board_led_invert(PROGRESS_LED);
} break;
case NRF_BLE_AMTS_EVT_TRANSFER_FINISHED:
counter_stop();
// bsp_board_led_off(PROGRESS_LED);
// bsp_board_led_on(DONE_LED);
uint32_t time_ms = counter_get();
uint32_t bit_count = (evt.bytes_transfered_cnt * 8);
float throughput_kbps = ((bit_count / (time_ms / 1000.f)) / 1000.f);
printf("Done.\n");
printf("=============================\n");
printf("Time: %u.%.2u seconds elapsed.\n", (time_ms / 1000), (time_ms % 1000));
printf("Throughput: " NRF_LOG_FLOAT_MARKER " Kbps.\n",
NRF_LOG_FLOAT(throughput_kbps));
printf("=============================");
printf("Sent %u bytes of ATT payload.\n", evt.bytes_transfered_cnt);
printf("Retrieving amount of bytes received from peer...\n");
err_code = nrf_ble_amtc_rcb_read(&m_amtc);
// if (err_code != NRF_SUCCESS)
// NRF_LOG_ERROR("nrf_ble_amtc_rcb_read() failed: 0x%x.", err_code);
test_terminate();
} break;
static void adc_handler(void * p_context)
/**@brief AMT Client event handler. */
static void amtc_evt_handler(nrf_ble_amtc_t * p_amt_c, nrf_ble_amtc_evt_t * p_evt)
char i;
switch (p_evt->evt_type)
case NRF_BLE_AMT_C_EVT_DISCOVERY_COMPLETE:
printf("AMT service discovered at peer.\n");
err_code = nrf_ble_amtc_handles_assign(p_amt_c,
p_evt->conn_handle,
&p_evt->params.peer_db);
// Enable notifications.
err_code = nrf_ble_amtc_notif_enable(p_amt_c);
} break;
case NRF_BLE_AMT_C_EVT_NOTIFICATION:
static uint32_t bytes_cnt = 0;
static uint32_t kbytes_cnt = 0;
if (p_evt->params.hvx.bytes_sent == 0)
bytes_cnt = 0;
kbytes_cnt = 0;
bytes_cnt += p_evt->params.hvx.notif_len;
if (bytes_cnt > 1024)
bytes_cnt -= 1024;
kbytes_cnt++;
printf("Received %u kbytes\n", kbytes_cnt);
nrf_ble_amts_rbc_set(&m_amts, p_evt->params.hvx.bytes_rcvd);
if (p_evt->params.hvx.bytes_rcvd >= AMT_BYTE_TRANSFER_CNT)
bytes_cnt = 0;
kbytes_cnt = 0;
printf("Transfer complete, received %u bytes of ATT payload.\n",
// for(i=0; i<244; i++)
// printf("[%d]-%x",i, Mybuffer[i]);
} break;
case NRF_BLE_AMT_C_EVT_RBC_READ_RSP:
printf("Peer received %u bytes of ATT payload.\n", (p_evt->params.rcv_bytes_cnt));
test_terminate();
} break;
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective service instances.
* @param[in] p_evt Pointer to the database discovery event.
static void db_disc_evt_handler(ble_db_discovery_evt_t * p_evt)
nrf_ble_amtc_on_db_disc_evt(&m_amtc, p_evt);
/**@brief Function for handling events from the GATT library. */
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
switch (p_evt->evt_id)
case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
m_mtu_exchanged = true;
printf("ATT MTU exchange completed. MTU set to %u bytes.\n",
p_evt->params.att_mtu_effective);
} break;
case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
m_data_length_updated = true;
printf("Data length updated to %u bytes.\n", p_evt->params.data_length);
} break;
nrf_ble_amts_on_gatt_evt(&m_amts, p_evt);
/**@brief Function for setting up advertising data. */
static void advertising_data_set(void)
ret_code_t ret;
ble_gap_adv_params_t const adv_params =
.properties =
.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED,
.p_peer_addr = NULL,
.filter_policy = BLE_GAP_ADV_FP_ANY,
.interval = ADV_INTERVAL,
.duration = 0,
.primary_phy = BLE_GAP_PHY_1MBPS, // Must be changed to connect in long range. (BLE_GAP_PHY_CODED)
.secondary_phy = BLE_GAP_PHY_1MBPS,
ble_advdata_t const adv_data =
.name_type = BLE_ADVDATA_FULL_NAME,
.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE,
.include_appearance = false,
ret = ble_advdata_encode(&adv_data, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
APP_ERROR_CHECK(ret);
ret = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
/**@brief Function for starting advertising. */
printf("Starting advertising.\n");
// bsp_board_led_on(SCAN_ADV_LED);
ret_code_t err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ble_gap_evt_adv_report_t const * p_adv =
p_scan_evt->params.filter_match.p_adv_report;
ble_gap_scan_params_t const * p_scan_param =
p_scan_evt->p_scan_params;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_FILTER_MATCH:
printf("Device \"%s\" found, sending a connection request.\n",
(uint32_t) m_target_periph_name);
// Stop advertising.
err_code = sd_ble_gap_adv_stop(m_adv_handle);
// Initiate connection.
m_conn_param.min_conn_interval = CONN_INTERVAL_DEFAULT;
m_conn_param.max_conn_interval = CONN_INTERVAL_DEFAULT;
err_code = sd_ble_gap_connect(&p_adv->peer_addr,
p_scan_param,
&m_conn_param,
NRF_LOG_ERROR("sd_ble_gap_connect() failed: 0x%x.", err_code);
} break;
/**@brief Function for initialization the scanning and setting the filters.
static void scan_init(void)
err_code = nrf_ble_scan_init(&m_scan, NULL, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan,
SCAN_NAME_FILTER,
err_code = nrf_ble_scan_filters_enable(&m_scan,
NRF_BLE_SCAN_NAME_FILTER,
false);
/**@brief Function for starting the scanning. */
static void scan_start(void)
printf("Starting scanning.\n");
ret_code_t err_code = nrf_ble_scan_start(&m_scan);
/**@brief Function for initializing the LEDs.
* @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for enabling button input.
static void buttons_enable(void)
ret_code_t err_code = app_button_enable();
/**@brief Function for disabling button input. */
static void buttons_disable(void)
ret_code_t err_code = app_button_disable();
/**@brief Function for handling events from the button handler module.
* @param[in] pin_no The pin that the event applies to.
* @param[in] button_action The button action (press or release).
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
switch (pin_no)
case START_BUTTON:
printf("Button start Pressed !");
if(!m_run_test)
test_begin();
} break;
buttons_disable();
/**@brief Function for initializing the button library.
static void buttons_init(void)
// The array must be static because a pointer to it will be saved in the button library.
static app_button_cfg_t buttons[] =
{START_BUTTON, false, BUTTON_PULL, button_evt_handler}
ret_code_t err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
static void client_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_evt_handler);
err_code = nrf_ble_amtc_init(&m_amtc, amtc_evt_handler);
/**@brief Function for handling Queued Write module errors.
* @details A pointer to this function is passed to each service that may need to inform the
* application about an error.
* @param[in] nrf_error Error code that contains information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for initializing the Queued Write module.
static void qwr_init(void)
nrf_ble_qwr_init_t qwr_init_obj = {0};
qwr_init_obj.error_handler = nrf_qwr_error_handler;
err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
static void server_init(void)
qwr_init();
nrf_ble_amts_init(&m_amts, amts_evt_handler);
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for initializing GAP parameters.
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device, including the device name and the preferred connection parameters.
(uint8_t const *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_ppcp_set(&m_conn_param);
/**@brief Function for initializing the GATT library. */
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
//void preferred_phy_set(ble_gap_phys_t * p_phy)
// memcpy(&m_test_params.phys, p_phy, sizeof(ble_gap_phys_t));
void gatt_mtu_set(uint16_t att_mtu)
m_test_params.att_mtu = att_mtu;
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, att_mtu);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, att_mtu);
//void connection_interval_set(uint16_t value)
// m_test_params.conn_interval = value;
void conn_evt_len_ext_set(bool status)
ble_opt_t opt;
memset(&opt, 0x00, sizeof(opt));
opt.common_opt.conn_evt_ext.enable = status ? 1 : 0;
err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
m_test_params.conn_evt_len_ext_enabled = status;
err_code = nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, value);
m_test_params.data_len = value;
printf("Preparing the test.\n");
NRF_LOG_FLUSH();
#if defined(S132)
// PHY does not need to be updated for s132.
switch (m_gap_role)
// If no connection was established, the role is not established either.
// In this case, start both the advertising and the scanning.
advertising_start();
scan_start();
case BLE_GAP_ROLE_PERIPH:
m_test_params.phys.tx_phys = BLE_GAP_PHY_2MBPS;
case BLE_GAP_ROLE_CENTRAL:
scan_start();
static void test_run(void)
counter_start();
nrf_ble_amts_notif_spam(&m_amts);
//void cli_process(void)
// nrf_cli_process(&m_cli_uart);
* @details Handles any pending operations, then sleeps until the next event occurs.
// cli_process();
int ret;
if (is_test_ready())
printf("Test started\n");
m_run_test = true;
test_run();
nrf_pwr_mgmt_run();
m_run_test = false;
m_notif_enabled = false;
m_mtu_exchanged = false;
m_data_length_updated = false;
m_phy_updated = false;
m_conn_interval_configured = false;
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
printf("Disconnecting... \n");
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
NRF_LOG_ERROR("sd_ble_gap_disconnect() failed: 0x%0x.", err_code);
buttons_enable();
// else
// if (m_board_role == BOARD_DUMMY)
// if (m_gap_role == BLE_GAP_ROLE_PERIPH)
// advertising_start();
// else
// scan_start();
//void cli_init(void)
// if (CoreDebug->DHCSR & CoreDebug_DHCSR_C_DEBUGEN_Msk)
// ret_code_t err_code = nrf_cli_init(&m_cli_rtt, NULL, true, true, NRF_LOG_SEVERITY_INFO);
// nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
// uart_config.pseltxd = TX_PIN_NUMBER;
// uart_config.pselrxd = RX_PIN_NUMBER;
// uart_config.hwfc = NRF_UART_HWFC_DISABLED;
// ret_code_t err_code = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
//void cli_start(void)
// ret_code_t err_code = nrf_cli_start(&m_cli_uart);
/**@brief Function for initializing the timer.
* @details Initializes the timer module. This creates and starts application timers.
static void timer_init(void)
ret_code_t ret;
ret = nrf_pwr_mgmt_init();
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t data_array[100];
static uint8_t index = 0;
// uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (data_array[index - 1] == '\r'))
if (index > 1)
// NRF_LOG_DEBUG("Ready to send data over BLE NUS");
printf("Ready to send data over BLE NUS \n");
if( strstr(data_array, "RUN") != NULL)
printf("Get DATA %s \n",data_array);
test_begin();
// NRF_LOG_HEXDUMP_DEBUG(data_array, index);
// do
// uint16_t length = (uint16_t)index;
// err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
// if ((err_code != NRF_ERROR_INVALID_STATE) &&
// (err_code != NRF_ERROR_RESOURCES) &&
// (err_code != NRF_ERROR_NOT_FOUND))
// } while (err_code == NRF_ERROR_RESOURCES);
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
static void log_init(void)
ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
// Initialize.
int count_buffet;
uart_init();
log_init();
// cli_init();
leds_init();
timer_init();
counter_init();
buttons_init();
power_management_init();
ble_stack_init(); // nitializes the SoftDevice and the BLE event interrupt
gap_params_init(); //sets up all the necessary GAP (Name , Min & Max connection latency )
gatt_init(); // Sets up Gap parameters (MTU size : 247, Gap Data length : 251 ..... )
advertising_data_set();
scan_init();
server_init();
client_init();
gatt_mtu_set(m_test_params.att_mtu);
conn_evt_len_ext_set(m_test_params.conn_evt_len_ext_enabled);
// Start execution.
// cli_start();
buttons_enable();
iir_loadcoeff_250_2k5_16ksps();
data_len_set(DATA_LENGTH_DEFAULT);
saadc_sampling_event_init();
saadc_init();
//saadc_sampling_event_enable();
for (;;)
nrf_delay_ms(1000);
// if((m_adc_evt_counter >= 2000) && flagsend )
// flagsend = 0;
// for(count_buffet=0; count_buffet<2000; count_buffet++)
// nrf_delay_ms(10);
// printf("%d \r\n",adc_buffer[count_buffet]);
idle_state_handle();
printf("get status ready = %d, %d, %d, %d, %d, %d \r\n",
m_conn_interval_configured,
m_notif_enabled,
m_mtu_exchanged,
m_data_length_updated || m_test_params.data_len == DATA_LENGTH_DEFAULT,
m_phy_updated,
m_run_test);
  • So if your question is now resolved, please verify the answer:
  • Dear sir,
    After synchronizing the samples signal, I would like to send them to my ble central.
    To test the transfer, I set up the device code below, I want to call a timer every 4ms to transfer 64 bytes to ble central so i use the example examples / ble_central / ble_app_uart_c  for data recovery.
    I modified the code to configure ATT MTU = 244, gatt data len = 244, PHY update 2MBPS. To ensure synchronization, the module ble_central toggle the LED at each reception.
    Problem: I notice that I have a synchronization problem for transfers below 30ms. How can I solve this problem?
    Thanks in advance for your answer.
    #include <stdint.h>
    #include <string.h>
    #include <stdio.h>
    #include "nrf.h"
    #include "ble.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_drv_i2s.h"
    #include "saadc_service.h"
    #include "sdt_sample_transfer_service.h"
    #include "ble_advertising.h"
    #include "ble_nus_c.h"
    APP_TIMER_DEF(m_sample_delay_timer_id);
    #define MAIN_DEBUG
    #ifdef MAIN_DEBUG
    #define DEBUG(x,y...) printf ("(%s:%d) " x "\n", __func__ , __LINE__,  ## y)
    #else
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define CONNECTED_LED                    BSP_BOARD_LED_0
    #define TEST_LED                       BSP_BOARD_LED_1
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define SAMPLE_TEST_DELAY  APP_TIMER_TICKS(8)
    extern uint32_t       *mp_block_to_fill;
    BLE_ITS_DEF(m_its, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint8_t                          m_new_command_received = 0;
    static uint8_t                          m_new_resolution, m_new_phy;
    //static arducam_mini_2mp_init_t          m_camera_init;
    static bool                             m_stream_mode_active = false;
    static ble_its_ble_params_info_t        m_ble_params_info = {20, 50, 1, 1};
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_its_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
        {BLE_UUID_ITS_SERVICE, NUS_SERVICE_UUID_TYPE}
    board_role_t  m_board_role;
    			// command type
    enum {CMD_NO_COMMAND = 0,
        	CMD_COMMAND,
    	    CMD_SENSAMP,
    		  CMD_DISABLE_MEAS,
    	    CMD_ENABLE_MEASURE,
    	    CMD_SAMPLE_RATE,
          CMD_FLTER_CONFIG,
          CMD_FILTER_TYPE,
    	    CMD_BYPASS,
    	    CMD_GET_BATT_VOLTAGE,
    	    CMD_GET_BATT_CURRENT,
    	    CMD_GET_BATT_PERCENT,
    	    CMD_SAMPLES_XFER
    			static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    /**@brief Function for starting scanning. */
        ret_code_t ret;
        ret = nrf_ble_scan_start(&m_scan);
       // ret = bsp_indication_set(BSP_INDICATE_SCANNING);
      //  APP_ERROR_CHECK(ret);
        uint32_t err_code;
    			DEBUG("=> 0x%x", p_ble_evt->header.evt_id);
                DEBUG("Connected");
    				    bsp_board_led_on(CONNECTED_LED);
    //            err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                DEBUG("Disconnected");
    				    bsp_board_led_off(CONNECTED_LED);
                DEBUG("PHY update request 2MBPS.");
                ble_gap_phys_t const phys =
                    BLE_GAP_PHY_2MBPS,
                    BLE_GAP_PHY_2MBPS,
            } break;
                // Pairing not supported
                uint16_t max_con_int = p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.max_conn_interval;
                uint16_t min_con_int = p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.min_conn_interval;
                m_ble_params_info.con_interval = max_con_int;
               // ble_its_ble_params_info_send(&m_its, &m_ble_params_info);
                DEBUG("Con params updated: CI %i, %i", (int)min_con_int, (int)max_con_int);
            } break;
                m_ble_params_info.tx_phy = p_ble_evt->evt.gap_evt.params.phy_update.tx_phy;
                m_ble_params_info.rx_phy = p_ble_evt->evt.gap_evt.params.phy_update.rx_phy;
                DEBUG("Phy update: %i, %i", (int)m_ble_params_info.tx_phy, (int)m_ble_params_info.rx_phy);
                //DEBUG("BLE event not handled by app: %i", p_ble_evt->header.evt_id);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
    #if 0
        ble_gap_addr_t ble_address = {.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
                                      .addr_id_peer = 0,
                                      .addr = {0xC3,0x11,0x99,0x33,0x44,0xFF}};
        err_code = sd_ble_gap_addr_set(&ble_address);
        uint32_t data_length;
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            data_length = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            //m_ble_params_info.mtu = m_ble_its_max_data_len;
            DEBUG("gatt_event: ATT MTU is set to 0x%X (%d)", data_length, data_length);
        else if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED))
            data_length = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH - 4;
            m_ble_its_max_data_len = data_length;
            DEBUG("gatt_event: Data len is set to 0x%X (%d)", data_length, data_length);
        //NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
          //            p_gatt->att_mtu_desired_central,
            //        p_gatt->att_mtu_desired_periph);
    	    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        err_code = nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, NRF_SDH_BLE_GAP_DATA_LENGTH);
        ret_code_t ret;
        ble_opt_t  opt;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        switch(p_evt->evt_type)
            case BLE_CONN_PARAMS_EVT_SUCCEEDED:
            case BLE_CONN_PARAMS_EVT_FAILED:
                //err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
                //APP_ERROR_CHECK(err_code);
                NRF_LOG_ERROR("Conn params failed. Keep the connection anyway..");
    /**@brief Function for handling errors from the Connection Parameters module.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
              //  err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
            case BLE_ADV_EVT_IDLE:
                DEBUG("BLE_ADV_EVT_IDLE...");
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    static void sample_delay_timeout_handler(void * p_context)
     uint8_t arraytest[200];
    	bsp_board_led_invert(TEST_LED);
    	ble_its_string_send(&m_its, arraytest, 64);
    	  uint8_t file_data[10]= {1,3,5,2,35,3,2,14,225,45};
                index++;
    							 if (index > 1)
    									   printf("UART Read(  %s )\n",data_array);
    										 if( (strstr(data_array, "SCAN") != NULL) )
    												//  scan_start();
    										  if( (strstr(data_array, "DISCONNECT") != NULL) )
    												err_code = sd_ble_gap_disconnect(m_advertising.adv_handle , BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    														DEBUG("sd_ble_gap_disconnect() failed: 0x%0x.", err_code);
    										 if( (strstr(data_array, "TESTXFER") != NULL) )
    												 DEBUG("Xfert file.");
    												  ble_its_string_send(&m_its, &file_data[0], sizeof(file_data));
    										 if( (strstr(data_array, "FILE") != NULL) )
    												  ble_its_string_send(&m_its, data_array, strlen(data_array));
    										if( (strstr(data_array, "START") != NULL) )
    												  	app_timer_start(m_sample_delay_timer_id, SAMPLE_TEST_DELAY, NULL);
    //										else if( ( m_board_role == SDT_SENSOR_ROLE && (strstr(data_array, "START") != NULL) ))
    //												//test_begin();
    //										else if( ( m_board_role == SDT_RECIEVER_ROLE && (strstr(data_array, "TESTXFER") != NULL) ))
    //												//reciever_params_info_send(&m_amts);
    //										else if( strstr(data_array, "STOP") != NULL)
    //											stop_transmission();
                    index = 0;
    							      //  m_run_test = true;
                       //  test_run();
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
    /**@brief Function for handling the data from the ITS Service.
     * @details This function will process the data received from the ITS BLE Service.
     * @param[in] p_its    ITS Service structure.
     * @param[in] p_data   Data received.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
    static void its_data_handler(ble_its_t * p_its, uint8_t const * p_data, uint16_t length)
    	//DEBUG("Recieve %d, %d\n", p_data[0],length);
        switch(p_data[0])
    //        // Take picture
    //        case APP_CMD_SINGLE_CAPTURE:
    //        case APP_CMD_SEND_BLE_PARAMS:
    //            m_new_command_received = p_data[0];
    //            break;
    //        case APP_CMD_START_STREAM:
    //            m_stream_mode_active = true;
    //            break;
    //        case APP_CMD_STOP_STREAM:
    //            m_stream_mode_active = false;
    //            break;
    //        case APP_CMD_CHANGE_RESOLUTION:
    //            m_new_command_received = APP_CMD_CHANGE_RESOLUTION;
    //            m_new_resolution = p_data[1];
    //            break;
    //        case APP_CMD_CHANGE_PHY:
    //            m_new_command_received = APP_CMD_CHANGE_PHY;
    //            m_new_phy = p_data[1];
    //            break;
    //        default:
    //            NRF_LOG_ERROR("Unknown command!!");
    //            break;
        uint32_t           err_code;
        ble_its_init_t     its_init;
        // Initialize ITS.
        memset(&its_init, 0, sizeof(its_init));
        its_init.data_handler = its_data_handler;
        err_code = ble_its_init(&m_its, &its_init);
    //    while(NRF_LOG_PROCESS());
    //    sd_app_evt_wait();
    	    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
        // Initialize.
        ble_gap_phys_t gap_phys_settings;
    	  uart_init();
       // log_init();
        leds_init();
        timer_init();
        //counter_init();
    	  gpio_init();
    	  m_board_role = get_sdt_boardrole();
       // buttons_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
    	  services_init();
    	  advertising_init();
    	  conn_params_init();
    	  sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
    	//   scan_init();  // RECIEVER
    	DEBUG("Start test !!!");
     app_timer_create(&m_sample_delay_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                sample_delay_timeout_handler);
    	//  sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
        for (;;)
