How to turn on/off GPS while LTE is on?
I'm attempting t to turn on and off GPS function while LTE is on, but it doesn't work out. I merged mqtt_simple and gps example programs into a new project. What's wrong with the program?
In configure_gps_off_on function, buf stores "ERROR" in the line of bytes_received = recv(at_sock, buf, 2, 0),  which means that receiving data through socket does not work.
ncs version: 1.0.0
In version 1.0.0, is it possible to use LTE and GPS at the same time?
<prj.conf>
# General config
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_NEWLIB_LIBC=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# BSD library
CONFIG_BSD_LIBRARY=y
# AT Host
CONFIG_AT_HOST_LIBRARY=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=n
# Appliaction
CONFIG_MQTT_PUB_TOPIC="myPubTopic"
CONFIG_MQTT_SUB_TOPIC="mySubTopic"
CONFIG_MQTT_CLIENT_ID="myClientID"
CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxx.com"
CONFIG_MQTT_BROKER_PORT=xxxx
# Main thread
CONFIG_MAIN_THREAD_PRIORITY=7
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=1024
# Disable native network stack to save some memory
CONFIG_NET_IPV4=n
CONFIG_NET_IPV6=n
CONFIG_NET_UDP=n
CONFIG_NET_TCP=n
CONFIG_NET_RX_STACK_SIZE=256
CONFIG_NET_TX_STACK_SIZE=256
<main.c>
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <stdio.h>
#include <uart.h>
#include <string.h>
#include <net/mqtt.h>
#include <nrf_socket.h>
#include <net/socket.h>
#include <lte_lc.h>
#include <stdio.h>
#define MQTT_USERNAME "username"
#define MQTT_PASSWORD "password"
#define AT_XSYSTEMMODE_EN_M1_GPS "AT\%XSYSTEMMODE=1,0,1,0" // %XSYSTEMMODE=<M1_support>,<NB1_support>,<GNSS_support>,<LTE_preference>
#define AT_XSYSTEMMODE_EN_M1 "AT\%XSYSTEMMODE=1,0,0,0"
#define AT_CFUN_EN_MODEM "AT+CFUN=1"
/* Set the modem functional mode.
 * 0 – Power off
 * 1 – Normal mode
 * 4 – Offline mode
 * 44 – Offline mode without shutting down UICC */
#ifdef CONFIG_BOARD_NRF9160_PCA10090NS
#define AT_MAGPIO_EN_GPS "AT\%XMAGPIO=1,0,0,1,1,1574,1577" // %XMAGPIO=<MAGPIO0>,<MAGPIO1>,<MAGPIO2>,<The number of frequency ranges>,<state_0>,<flo_0>,<fhi_0><state_1>,<flo_1>,<fhi_1>,...
#define AT_MAGPIO_DIS  "AT\%XMAGPIO"
#define GPS_EN true
#define GPS_DIS false
static int            fd;
static char           nmea_strings[10][NRF_GNSS_NMEA_MAX_LEN];
static u32_t          nmea_string_cnt;
static bool           got_first_fix;
static bool           update_terminal;
static u64_t          fix_timestamp;
nrf_gnss_data_frame_t last_fix;
/* Buffers for MQTT client. */
static u8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* The mqtt client struct */
static struct mqtt_client client;
/* MQTT Broker details. */
static struct sockaddr_storage broker;
/* Connected flag */
static bool connected;
/* File descriptor */
static struct pollfd fds;
#if defined(CONFIG_BSD_LIBRARY)
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
	printk("bsdlib recoverable error: %u\n", err);
/**@brief Irrecoverable BSD library error. */
void bsd_irrecoverable_error_handler(uint32_t err)
	printk("bsdlib irrecoverable error: %u\n", err);
	__ASSERT_NO_MSG(false);
#endif /* defined(CONFIG_BSD_LIBRARY) */
/* GPS setting*/
static int configure_gps_off_on(bool status)
	int  at_sock;
	int  bytes_sent;
	int  bytes_received;
	char buf[2];
        char *at_commands[3];
        if(status == GPS_EN){
                at_commands[0] = AT_XSYSTEMMODE_EN_M1_GPS;
                at_commands[1] = AT_MAGPIO_EN_GPS;
        } else {
                at_commands[0] = AT_XSYSTEMMODE_EN_M1;
                at_commands[1] = AT_MAGPIO_DIS;
        at_commands[2] = AT_CFUN_EN_MODEM;
        printf("at_commands[0] = %s\n", at_commands[0]);
        printf("at_commands[1] = %s\n", at_commands[1]);
        printf("at_commands[2] = %s\n", at_commands[2]);
	at_sock = socket(AF_LTE, 0, NPROTO_AT); // retunr 4
        printk("at_sock = %u\n", at_sock);
	if (at_sock < 0) {
                printk("Error1\n");
		return -1;
	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
		bytes_sent = send(at_sock, at_commands[i], strlen(at_commands[i]), 0);
                printk("at_commands[i] = %s\n", at_commands[i]);
                printk("strlen(at_commands[i]) = %u\n", strlen(at_commands[i]));
		if (bytes_sent < 0) {
			close(at_sock);
                        printk("Error2\n");
			return -1;
		do {
			bytes_received = recv(at_sock, buf, 2, 0); // this is not successful
		} while (bytes_received == 0);
                printk("buf = %s\n", buf); // "ER"
		if (memcmp(buf, "OK", 2) != 0) {
			close(at_sock);
                        printk("Error3\n"); // reach here
			return -1;
	close(at_sock);
	return 0;
static int init_gps(void)
	u16_t fix_retry     = 0;
	u16_t fix_interval  = 1;
	u16_t nmea_mask     = NRF_CONFIG_NMEA_GSV_MASK |
			      NRF_CONFIG_NMEA_GSA_MASK |
			      NRF_CONFIG_NMEA_GLL_MASK |
			      NRF_CONFIG_NMEA_GGA_MASK |
			      NRF_CONFIG_NMEA_RMC_MASK;
	int   retval;
	if (configure_gps_off_on(GPS_EN) != 0) {
		printk("Failed to enable GPS\n");
		return -1;
	fd = nrf_socket(NRF_AF_LOCAL, NRF_SOCK_DGRAM, NRF_PROTO_GNSS);
	if (fd >= 0) {
		printk("Socket created\n");
	} else {
		printk("Could not init socket (err: %d)\n", fd);
		return -1;
	retval = nrf_setsockopt(fd,
				NRF_SOL_GNSS,
				NRF_SO_GNSS_FIX_RETRY,
				&fix_retry,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set fix retry value\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_FIX_INTERVAL,
				&fix_interval,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set fix interval value\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_NMEA_MASK,
				&nmea_mask,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set nmea mask\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_START,
				NULL,
				0);
	if (retval != 0) {
		printk("Failed to start GPS\n");
		return -1;
	return 0;
int process_gps_data(nrf_gnss_data_frame_t *gps_data)
	int retval;
	retval = nrf_recv(fd, gps_data, sizeof(nrf_gnss_data_frame_t), NRF_MSG_DONTWAIT);
	if (retval > 0) {
		switch (gps_data->data_id) {
		case NRF_GNSS_PVT_DATA_ID:
			if ((gps_data->pvt.flags &
				NRF_GNSS_PVT_FLAG_FIX_VALID_BIT)
				== NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
				if (!got_first_fix) {
					got_first_fix = true;
				fix_timestamp = k_uptime_get();
				memcpy(&last_fix, gps_data, sizeof(nrf_gnss_data_frame_t));
				nmea_string_cnt = 0;
				update_terminal = true;
		case NRF_GNSS_NMEA_DATA_ID:
			if (nmea_string_cnt < 10) {
				memcpy(nmea_strings[nmea_string_cnt++],
				       gps_data->nmea,
				       retval);
	return retval;
static void print_pvt_data(nrf_gnss_data_frame_t *pvt_data)
	printf("Longitude:  %f\n", pvt_data->pvt.longitude);
	printf("Latitude:   %f\n", pvt_data->pvt.latitude);
	printf("Altitude:   %f\n", pvt_data->pvt.altitude);
	printf("Speed:      %f\n", pvt_data->pvt.speed);
	printf("Heading:    %f\n", pvt_data->pvt.heading);
	printk("Date:       %02u-%02u-%02u\n", pvt_data->pvt.datetime.day,
					       pvt_data->pvt.datetime.month,
					       pvt_data->pvt.datetime.year);
	printk("Time (UTC): %02u:%02u:%02u\n", pvt_data->pvt.datetime.hour,
					       pvt_data->pvt.datetime.minute,
					      pvt_data->pvt.datetime.seconds);
/**@brief Function to print strings without null-termination
static void data_print(u8_t *prefix, u8_t *data, size_t len)
	char buf[len + 1];
	memcpy(buf, data, len);
	buf[len] = 0;
	printk("%s%s\n", prefix, buf);
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
	struct mqtt_publish_param param;
	param.message.topic.qos = qos;
	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
	param.message.payload.data = data;
	param.message.payload.len = len;
	param.message_id = sys_rand32_get();
	param.dup_flag = 0;
	param.retain_flag = 0;
	data_print("Publishing: ", data, len);
	printk("to topic: %s len: %u\n",
		CONFIG_MQTT_PUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
	return mqtt_publish(c, &param);
/**@brief Function to subscribe to the configured topic
static int subscribe(void)
	struct mqtt_topic subscribe_topic = {
		.topic = {
			.utf8 = CONFIG_MQTT_SUB_TOPIC,
			.size = strlen(CONFIG_MQTT_SUB_TOPIC)
		.qos = MQTT_QOS_1_AT_LEAST_ONCE
	const struct mqtt_subscription_list subscription_list = {
		.list = &subscribe_topic,
		.list_count = 1,
		.message_id = 1234
	printk("Subscribing to: %s len %u\n", CONFIG_MQTT_SUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
	return mqtt_subscribe(&client, &subscription_list);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c, size_t length)
	u8_t *buf = payload_buf;
	u8_t *end = buf + length;
	if (length > sizeof(payload_buf)) {
		return -EMSGSIZE;
	while (buf < end) {
		int ret = mqtt_read_publish_payload(c, buf, end - buf);
		if (ret < 0) {
			int err;
			if (ret != -EAGAIN) {
				return ret;
			printk("mqtt_read_publish_payload: EAGAIN\n");
			err = poll(&fds, 1, K_SECONDS(CONFIG_MQTT_KEEPALIVE));
			if (err > 0 && (fds.revents & POLLIN) == POLLIN) {
				continue;
			} else {
				return -EIO;
		if (ret == 0) {
			return -EIO;
		buf += ret;
	return 0;
/**@brief MQTT client event handler
void mqtt_evt_handler(struct mqtt_client *const c,
		      const struct mqtt_evt *evt)
	int err;
	switch (evt->type) {
	case MQTT_EVT_CONNACK:
		if (evt->result != 0) {
			printk("MQTT connect failed %d\n", evt->result);
		connected = true;
		printk("[%s:%d] MQTT client connected!\n", __func__, __LINE__);
		subscribe();
	case MQTT_EVT_DISCONNECT:
		printk("[%s:%d] MQTT client disconnected %d\n", __func__,
		       __LINE__, evt->result);
		connected = false;
	case MQTT_EVT_PUBLISH: {
		const struct mqtt_publish_param *p = &evt->param.publish;
		printk("[%s:%d] MQTT PUBLISH result=%d len=%d\n", __func__,
		       __LINE__, evt->result, p->message.payload.len);
		err = publish_get_payload(c, p->message.payload.len);
		if (err >= 0) {
			data_print("Received: ", payload_buf,
			/* Echo back received data */
			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
				payload_buf, p->message.payload.len);
		} else {
			printk("mqtt_read_publish_payload: Failed! %d\n", err);
			printk("Disconnecting MQTT client...\n");
			err = mqtt_disconnect(c);
			if (err) {
				printk("Could not disconnect: %d\n", err);
	} break;
	case MQTT_EVT_PUBACK:
			printk("MQTT PUBACK error %d\n", evt->result);
		printk("[%s:%d] PUBACK packet id: %u\n", __func__, __LINE__,
				evt->param.puback.message_id);
	case MQTT_EVT_SUBACK:
			printk("MQTT SUBACK error %d\n", evt->result);
		printk("[%s:%d] SUBACK packet id: %u\n", __func__, __LINE__,
				evt->param.suback.message_id);
		printk("[%s:%d] default: %d\n", __func__, __LINE__,
				evt->type);
/**@brief Resolves the configured hostname and
 * initializes the MQTT broker structure
static void broker_init(void)
	int err;
	struct addrinfo *result;
	struct addrinfo *addr;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM
	err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
	if (err) {
		printk("ERROR: getaddrinfo failed %d\n", err);
		return;
	addr = result;
	err = -ENOENT;
	/* Look for address of the broker. */
	while (addr != NULL) {
		/* IPv4 Address. */
		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
			struct sockaddr_in *broker4 =
				((struct sockaddr_in *)&broker);
			char ipv4_addr[NET_IPV4_ADDR_LEN];
			broker4->sin_addr.s_addr =
				((struct sockaddr_in *)addr->ai_addr)
				->sin_addr.s_addr;
			broker4->sin_family = AF_INET;
			broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
			inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
				  ipv4_addr, sizeof(ipv4_addr));
			printk("IPv4 Address found %s\n", ipv4_addr);
		} else {
			printk("ai_addrlen = %u should be %u or %u\n",
				(unsigned int)addr->ai_addrlen,
				(unsigned int)sizeof(struct sockaddr_in),
				(unsigned int)sizeof(struct sockaddr_in6));
		addr = addr->ai_next;
	/* Free the address. */
	freeaddrinfo(result);
/**@brief Initialize the MQTT client structure
static void client_init(struct mqtt_client *client)
	mqtt_client_init(client);
	broker_init();
        static struct mqtt_utf8 password;
	static struct mqtt_utf8 user_name;
	password.utf8 = (u8_t*)MQTT_PASSWORD;
	password.size = strlen(MQTT_PASSWORD);
	user_name.utf8 = (u8_t*)MQTT_USERNAME;
	user_name.size = strlen(MQTT_USERNAME);
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
	client->password = &password;
	client->user_name = &user_name;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	client->transport.type = MQTT_TRANSPORT_NON_SECURE;
/**@brief Initialize the file descriptor structure used by poll.
static int fds_init(struct mqtt_client *c)
	if (c->transport.type == MQTT_TRANSPORT_NON_SECURE) {
		fds.fd = c->transport.tcp.sock;
	} else {
#if defined(CONFIG_MQTT_LIB_TLS)
		fds.fd = c->transport.tls.sock;
#else
		return -ENOTSUP;
	fds.events = POLLIN;
	return 0;
/**@brief Configures modem to provide LTE link. Blocks until link is
 * successfully established.
static void modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
		/* Do nothing, modem is already turned on
		 * and connected.
	} else {
		int err;
		printk("LTE Link Connecting ...\n");
		err = lte_lc_init_and_connect();
		__ASSERT(err == 0, "LTE link could not be established.");
		printk("LTE Link Connected!\n");
int8_t poll_and_check_rcv_data(u32_t interval_msec){
        int err = poll(&fds, 1, interval_msec); // Check if any data comes through LTE-M. When it is waiting for an incoming data, it sleeps
        int8_t ret = 0;
        if (err < 0) {
              printk("ERROR: poll %d\n", errno);
              return -1;
        /* Check if data is received through LTE-M */
        /* Caution!! These are mandatory */
        if ((fds.revents & POLLIN) == POLLIN) {
                err = mqtt_input(&client); // if a publish event comes, mqtt_evt_handler is called here
                if (err != 0) {
                        printk("ERROR: mqtt_input %d\n", err);
                        return -1;
        if ((fds.revents & POLLERR) == POLLERR) {
                printk("POLLERR\n");
                return -1;
        if ((fds.revents & POLLNVAL) == POLLNVAL) {
                printk("POLLNVAL\n");
                return -1;
        return ret;
void main(void)
	int err;
	printk("The MQTT simple sample started\n");
	modem_configure();
	client_init(&client);
	err = mqtt_connect(&client);
	if (err != 0) {
		printk("ERROR: mqtt_connect %d\n", err);
		return;
	err = fds_init(&client);
	if (err != 0) {
		printk("ERROR: fds_init %d\n", err);
		return;
        poll_and_check_rcv_data(K_SECONDS(5));
        /* GPS variables */
        nrf_gnss_data_frame_t gps_data;
	while (1) {
                printk("Staring GPS application\n");
                if (init_gps() != 0) {
                        printk("init_app fail\n");
                printk("Getting GPS data...\n");
		do {
			/* Loop until we don't have more
			 * data to read
		} while (process_gps_data(&gps_data) > 0);
                printk("---------------------------------\n");
                print_pvt_data(&last_fix);
                /* If gps data is broken, get it again */
                configure_gps_off_on(GPS_DIS);
                k_sleep(K_SECONDS(20));
<result>
***** Booting Zephyr OS v1.14.99-ncs2-rc3 *****
LTE Link Connected!
IPv4 Address found xxx.xx.xx.xxx
[mqtt_evt_handler:389] MQTT client connected!
Subscribing to: my/subscribe/topic len 18
at_commands[0] = AT%XSYSTEMMODE=1,0,1,0
at_commands[1] = AT%XMAGPIO=1,0,0,1,1,1574,1577
at_commands[2] = AT+CFUN=1
at_sock = 4
at_commands[i] = AT%XSYSTEMMODE=1,0,1,0
strlen(at_commands[i]) = 22
buf = ER
Error3
init_app fail
Getting GPS data...
Longitude:  0.000000
Latitude:   0.000000
Altitude:   0.000000
Speed:      0.000000
Heading:    0.000000
Date:       00-00-00
Time (UTC): 00:00:00
at_commands[0] = AT%XSYSTEMMODE=1,0,0,0
at_sock = 4
at_commands[i] = AT%XSYSTEMMODE=1,0,0,0
buf = ER
Error3
  • >Could you try opening the project in a new build folder or a clean build folder (deleting all contents of the previous build)
    I did it, but still got an error.
    - delete  build_nrf9160_pca10090ns folder
    - reopen asset_tracker
    - right-click on "Solution 'build'" and click Build
    Building ‘spm/zephyr/spm_zephyr_prebuilt.elf’ from solution ‘build’ in configuration ‘Common’
    1> Compiling ‘empty_file.c’
    1> Linking ‘spm_zephyr_prebuilt.elf’
    1> Memory region         Used Size  Region Size  %age Used
    1>            FLASH:       48640 B        48 KB     98.96%
    1>             SRAM:       10000 B        64 KB     15.26%
    1>         IDT_LIST:          40 B         2 KB      1.95%
    Building ‘spm/zephyr/linker_pass_final.cmd’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘spm/zephyr/linker_pass_final.cmd’
    Building ‘spm/zephyr/CMakeFiles/spm_linker_pass_final_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘spm/zephyr/spm_linker_pass_final_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘spm/zephyr/isr_tables.c’ from solution ‘build’ in configuration ‘Common’
    1> Combining ‘spm/zephyr/isr_tables.c’
    Building ‘cmake_object_order_depends_target_spm_zephyr_final’ from solution ‘build’ in configuration ‘Common’
    Building ‘libspmsecureentries.a’ from solution ‘build’ in configuration ‘Common’
    2> Compiling ‘isr_tables.c’
    Building ‘spm/zephyr/zephyr.elf’ from solution ‘build’ in configuration ‘Common’
    1> Linking ‘libspmsecureentries.a’
    1> Post-link command
    1> /opt/gnuarmemb/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-objcopy: 'zephyr.elf': No such file
    Build failed
  • hi
    the tag "v1.0.0 " and "this pull request,"
    is only for latest revision HW(so not work for    0.8.5
    This patch removes support for early prototype hardware and
    moves to only support latest revision. This simplifies the
    device tree file sctructure
  • Hi, stevenlin!
    What is the latest version of DK kit?
    According to the website below, the latest one is DK v0.8.5
    https://www.nordicsemi.com/Software-and-Tools/Development-Kits/nRF9160-DK/Download#infotabs
  • But the error happens when the project is built. That's not related to support for hardware.
  • I see. I see. The asset_tracker supporting real-GPS is only for later version of nrf9160_pca20035. In my case, I find only nrf9160_pca10090 in the folder of <root>/ncs/zephyr/boards/arm.
    Thingy:91 might be suitable to use the asset_tracker
    https://devzone.nordicsemi.com/f/nordic-q-a/50457/thingy-91/201867
    nrf9160_pca20035 board
    • Removed support for earlier hardware versions of nrf52840_pca20035 and nrf9160_pca20035. From now on, only the latest hardware version is supported.
    • Removed configurations specific to the deprecated board versions from the asset_tracker application.
