How can we connect the max30101 from the \ncs\zephyr\samples\sensor\max30101 .. i added the links to a blinky and it compiles successfully but can't seem to get the i2c working .. please help
Main in green
* Copyright (c) 2016 Intel Corporation
#include <zephyr.h>
#include <device.h>
#include <gpio.h>
#include <misc/printk.h>
#include <stdio.h>
#include <string.h>
#include <sensor.h>
#define LED_PORT LED0_GPIO_CONTROLLER
#define LED LED1_GPIO_PIN
/* 1000 msec = 1 sec */
#define SLEEP_TIME 1000
void main(void)
printk("UART loopback start!\n");
int cnt = 0;
//struct device *dev;
//dev = device_get_binding(LED_PORT);
/* Set LED pin as output */
//gpio_pin_configure(dev, LED, GPIO_DIR_OUT);
struct sensor_value green;
struct device *dev = device_get_binding("MAX30101");
if (dev == NULL) {
printk("Could not get max30101 device\n");
return;
while (1) {
/* Set pin to HIGH/LOW every 1 second */
sensor_sample_fetch(dev);
sensor_channel_get(dev, SENSOR_CHAN_GREEN, &green);
/* Print green LED data*/
printk("GREEN=%d\n", green.val1);
k_sleep(20);
//gpio_pin_write(dev, LED, cnt % 2);
printk("Hello World! %s\n", CONFIG_BOARD);
cnt++;
k_sleep(SLEEP_TIME);
CONF FILE in red
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_I2C_1=y
CONFIG_I2C_1_NRF_TWIM=y
CONFIG_SENSOR=y
CONFIG_LOG=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_AT_HOST_LIBRARY=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SENSOR_LOG_LEVEL_DBG=y
CONFIG_MAX30101=y
  • Thank you
    I'm getting this error while compilation when it reaches nrfx.twim.c
    'NRF_TWIM1' undeclared (first use in this function); did you mean 'NRF_TWIM2'?
    Thats the prj.conf
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_1=y
    CONFIG_SENSOR=y
    CONFIG_LOG=y
    CONFIG_MAX30101=y
    And the main
    #include <zephyr.h>
    #include <device.h>
    #include <gpio.h>
    #include <stdio.h>
    #include <string.h>
    #include <sensor.h>
    void main(void)
    	int cnt = 0;
    	if (dev == NULL) {
    		return;
    	while (1) {
    		k_sleep(20);
    		cnt++;
  • Try to do the following:
    • Copy the folder max30101 (<..>ncs\zephyr\samples\sensor\) into your working folder (e.g. <..>ncs\nrf\samples\nrf9160)
    • Don't modify any of the files, let the prj.conf and main.c be as it is
    • Create a file named nrf9160_pca10090ns.overlay inside the max30101 folder, and add the following inside it:
    &i2c2 {
    	max30101@57 {
    		compatible = "max,max30101";
    		reg = <0x57>;
    		label = "MAX30101";
    This extends on the enabled i2c2 device tree node from <..>\ncs\zephyr\boards\arm\nrf9160_pca10090\nrf9160_pca10090_common.dts
    • Build the example with the board set as nrf9160_pca10090ns (or whatever you chose for the overlay file)
    • Connect the max30101 using the SDA and SCL pins as defined in the i2c2 device tree node from <..>\ncs\zephyr\boards\arm\nrf9160_pca10090\nrf9160_pca10090_common.dts (If you haven overwritten it in the overlay file).
    Simon
  • Hello, im having currently this error, in max3010.c
    'DT_MAX_MAX30101_0_BUS_NAME' undeclared (first use in this function); did you mean 'CONFIG_MAX30101_SMP_AVE'?
    Also, can you specify the value of DT_MAX_MAX30101_0_LABEL
    Thanks
    Regards
  • What tag are you using? NCS v1.2.0? NCS v1.3.0? Master?
    Simon
