Dear Nordic Support,
I am using PPI to link 2 timers (10ms & 5s) with 2 SAADC channel (AIN1 - channel 0 & AIN2 - channel 1).
The nrf_drv_saadc_init function is only called once so it means there is only one callback for the sampling event. In case I am using 2 channels, how do I know that which channel has completed its sampling event in the callback function? When I printed out the ADC value, all I saw is CH0 and CH1 are read at the same time while I expect CH0 every 10ms and CH1 every 5s.
I am using nRF52840 + nRF5 SDK 15.3 + SD 6.1.1.
Thank you and best regards,
Duy
void saadc_transducer_callback(nrf_drv_saadc_evt_t const * p_event)
uint8_t idx;
APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, RAW_ADC_BUFF_SIZE));
NRF_LOG_INFO("T.ADC event number: %d", (int)m_transducer_evt_counter);
for (idx = 0; idx < RAW_ADC_BUFF_SIZE; idx++)
NRF_LOG_INFO("%d", p_event->data.done.p_buffer[idx]);
m_transducer_evt_counter++;
static void saadc_sampling_event_init(void)
uint32_t transducer_timer_compare_event_addr, battery_timer_compare_event_addr;
uint32_t saadc_sample_task_addr;
APP_ERROR_CHECK(nrf_drv_ppi_init());
nrf_drv_timer_enable(&TRANSDUCER_TIMER);
nrf_drv_timer_enable(&BATTERY_TIMER);
transducer_timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&TRANSDUCER_TIMER, NRF_TIMER_CC_CHANNEL0);
battery_timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&BATTERY_TIMER, NRF_TIMER_CC_CHANNEL0);
saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
/* Setup ppi channel so that timer compare event is triggering sample tasks in SAADC */
APP_ERROR_CHECK(nrf_drv_ppi_channel_alloc(&TORQUE_SAADC_TIMER_PPI_CHANNEL));
APP_ERROR_CHECK(nrf_drv_ppi_channel_alloc(&BATTERY_SAADC_TIMER_PPI_CHANNEL));
APP_ERROR_CHECK(nrf_drv_ppi_channel_assign(TORQUE_SAADC_TIMER_PPI_CHANNEL, transducer_timer_compare_event_addr, saadc_sample_task_addr));
APP_ERROR_CHECK(nrf_drv_ppi_channel_assign(BATTERY_SAADC_TIMER_PPI_CHANNEL, battery_timer_compare_event_addr, saadc_sample_task_addr));
static void saadc_init(void)
nrf_saadc_channel_config_t adc_channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
nrf_saadc_channel_config_t battery_channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
APP_ERROR_CHECK(nrf_drv_saadc_init(NULL, saadc_transducer_callback));
APP_ERROR_CHECK(nrf_drv_saadc_channel_init(0, &adc_channel_config));
APP_ERROR_CHECK(nrf_drv_saadc_channel_init(1, &battery_channel_config));
APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(m_buffer_pool[0], RAW_ADC_BUFF_SIZE));
APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(m_buffer_pool[1], RAW_ADC_BUFF_SIZE));
