Power Profiler: Failed to start the PPK
Hello!
Im running Power Profiler to measure current. I have uppdated nRF Connect from v2.7.0.0 to v3.0.0 and now the Power Profiler does not work as it did before. I am using Windows 10.  I get this logfile:
2019-07-16T04:51:17.579Z INFO Application data folder: C:\Users\H863260\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk
2019-07-16T04:51:17.583Z INFO App initialized
2019-07-16T04:51:17.747Z DEBUG App pc-nrfconnect-ppk v2.2.0 official
2019-07-16T04:51:17.748Z DEBUG App path: C:\Users\H863260\.nrfconnect-apps\node_modules\pc-nrfconnect-ppk
2019-07-16T04:51:17.748Z DEBUG nRFConnect 3.0.0 is supported by the app (^3.0.0)
2019-07-16T04:51:17.748Z DEBUG nRFConnect path: C:\Users\H863260\AppData\Local\Programs\nrfconnect\resources\app.asar
2019-07-16T04:51:17.748Z DEBUG HomeDir: C:\Users\H863260
2019-07-16T04:51:17.748Z DEBUG TmpDir: C:\Users\H863260\AppData\Local\Temp
2019-07-16T04:51:24.636Z INFO Validating firmware for device with s/n 000682414075
2019-07-16T04:51:24.642Z INFO PPK closed
2019-07-16T04:51:30.452Z INFO Opening device with s/n 000682414075
2019-07-16T04:51:30.452Z INFO PPK opened
2019-07-16T04:51:30.459Z INFO Initializing the PPK
2019-07-16T04:51:38.419Z INFO SEGGER serial:  682414075
2019-07-16T04:51:38.419Z INFO SEGGER speed:  2000  kHz
2019-07-16T04:51:38.419Z INFO SEGGER version:  J-Link OB-SAM3U128-V2-NordicSemi compiled Jan  7 2019 14:07:15
2019-07-16T04:51:44.432Z ERROR Failed to start the PPK.
2019-07-16T04:51:44.435Z DEBUG
2019-07-16T04:51:44.435Z INFO Deselecting device
2019-07-16T04:51:44.439Z INFO PPK closed
2019-07-16T04:51:52.738Z INFO Validating firmware for device with s/n 000682414075
2019-07-16T04:51:52.740Z INFO PPK closed
2019-07-16T04:52:09.260Z ERROR Error while setting up device 000682414075: Error occured when close opened device. Errorcode: CouldNotOpenDevice (0x4)
Lowlevel error: NO_EMULATOR_CONNECTED (fffffff3)
2019-07-16T04:52:09.261Z INFO Deselecting device
2019-07-16T04:52:09.265Z INFO PPK closed
At the first time I try to connect I get this:2019-07-16T04:51:44.432Z ERROR Failed to start the PPK.
At the second time I try to connect I get this :2019-07-16T04:52:09.260Z ERROR Error while setting up device 000682414075: Error occured when close opened device. Errorcode: CouldNotOpenDevice (0x4)Lowlevel error: NO_EMULATOR_CONNECTED (fffffff3).
The Programmer app works fine.
I have uninstalled nRF Connect and reinstalled it again but the result is the same. Any suggestions what to do?
Thanks in advance.
