BLE Transmission Latency
I have two nRF52832 (BL652) modules setup and connected through an RF cable. I am feeding the peripheral radio (2x) 174 byte packets every 5 ms. On the central, I am monitoring the receiving of these packets using the RTC clock and tracking the elapsed time between receiving these two packets from the peripheral. I have noticed that often times my latency climbs up to 15 ms, but most of the time it is around 5 ms. Is there a reason for this? I would expect to see some latency due to re-transmission, but not if I am connected through a RF cable.
I am using HVX notification transmissions from the peripheral, and occasionally sending packets from the central using a WRITE_CMD. My connection interval is set to be 7.5 ms, I have my CONN_SUP_TIMEOUT set to 1 second, and my SLAVE_LATENCY set to 0.
I modified the NUS example to where the main routine calls a new HVX transmission if the previous one ended with NRF_ERROR_RESOURCES. Should I move that to an APP_TIMER to give higher priority?
I confused as to why the latency would drift that far. Do I need to have all of the HVX packets loaded with the outgoing data before the beginning of the connection interval? Am I not able to load  the HVX buffers with new data after the connection interval is underway? I was hoping that every other CI would have 4 packets of 174 bytes (10ms), and therefore maintain the rate. Should I increase my CI to 15 ms?
As an odd side note, it seemed like I needed to increase NRF_SDH_BLE_GAP_EVENT_LENGTH to a large value (300) as opposed to using 6 like the CI would require. That is the only way to get better latency, otherwise it was around ~30ms.
I would really appreciate some guidance.
Chris
  • If you can provide a sniffer trace, we can have a look and check if the latency was actually because of packets drop or something else.
    It could be that the buffering was not good enough and we end up not sending a packet on a connection event.
    We currently don't have an option to change the connection interval to lower than 7.5ms but we may have that in the future release.
    Another option you can think of if BLE is not a requirement is to use our proprietary protocol ESB. Then you can have much more flexible option to do communication and can have very low latency.
