We are using UART peripheral from nrf52840. It communicates with a modem over the serial, but after receiving a random number of bytes, we get frame errors(the uart driver return 0x4 in error mask)
We changed the test and the device from AT modem to a usb-serial adapter and from our device to development board PCA10056, but the error appears at each test.
The wires we are using are about 2 cm for AT modem and 10 cm for usr-serial adapter.
No flow control is used.
Also we have tested with different speeds - 38400, 115200, 230400.
The test program is the example from nRF5_SDK_15.3.0_59ac345/examples/peripheral/serial_uartes/ (attached) , modified to use only one serial instance and wait for UART bytes.
We send a small number of characters (10 -20) followed by <CR><LF> sequence.
After a random number of sequences the UART driver indicate frame error.
How can we resolve this to have a correct transfer?
* Copyright (c) 2018 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_power.h"
#include "nrf_serial.h"
#include "app_timer.h"
#include "app_error.h"
#include "app_util.h"
#include "boards.h"
/** @file
* @defgroup nrf_serial_uartes_example main.c
* @ingroup nrf_serial_uartes_example
* @brief Example of @ref nrf_serial usage. Loopback example using two UARTE peripherals.
* Please short Arduino SCL and SDA GPIOs to start transmission.
#define OP_QUEUES_SIZE 3
#define APP_TIMER_PRESCALER NRF_SERIAL_APP_TIMER_PRESCALER
static void sleep_handler(void)
__WFE();
__SEV();
__WFE();
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
RX_PIN_NUMBER, TX_PIN_NUMBER,
RTS_PIN_NUMBER, CTS_PIN_NUMBER,
NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
NRF_UART_BAUDRATE_115200,
UART_DEFAULT_CONFIG_IRQ_PRIORITY);
#define SERIAL_FIFO_TX_SIZE 32
#define SERIAL_FIFO_RX_SIZE 1024
NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 255
NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
&serial0_queues, &serial0_buffs, NULL, sleep_handler);
NRF_SERIAL_UART_DEF(serial0_uarte, 0);
void read_uart_bytes()
char c;
int ret;
do
do
ret = nrf_serial_read(&serial0_uarte, &c, sizeof(c), NULL, 200);
if (ret == 0)
if (c == 0xA)
} while (1);
bsp_board_led_invert(2);
} while (1);
ret_code_t ret;
ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
ret = nrf_drv_power_init(NULL);
ret = app_timer_init();
// Initialize LEDs and buttons.
bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
read_uart_bytes();
