Central getting disconnected automatically after few seconds with 0x08 reason.
I am using custom nrf52832 PCB as central role. Also i have the peripheral with similar board . Peripheral communication is working properly if connected with the mobile device.
Where as the custom board with example code given by SDK V 15.2. The central gets connected with the peripheral . After 5-6 seconds appx. central gets disconnected from peripheral with 0x08 reason of event TIMEOUT.
I have added debug logs to every possible disconnect event in both the central and peripheral code. But the log gets only at peripheral side with disconnection reason. where central does not give any error. I am not understanding the reason behind this. Can anybody tell what should i do?
  • he error indicates that you've called app_button_enable() without configuring any buttons first.
    yes error was due to the enabling the button without initializing it. But even after removing the function i am getting this error.I have added the C code below:
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_timer.h"
    #include "boards.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    #include "ble_lbs_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_delay.h"
    #include "app_uart.h"
    #include "gpio.h"
    #include "Timer_Driver.h"
    #include "Battery_level.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0                     /**< Scanning LED will be on when the device is scanning. */
    #define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1                     /**< Connected LED will be on when the device is connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                     /**< LED to indicate a change of state of the the Button characteristic on the peer. */
    #define SCAN_INTERVAL                   0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                     0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION                   0x0000                              /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL         MSEC_TO_UNITS(7.5, UNIT_1_25_MS)    /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL         MSEC_TO_UNITS(30, UNIT_1_25_MS)     /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY                   0                                   /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT             MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Determines supervision time-out in units of 10 milliseconds. */
    #define LEDBUTTON_BUTTON_PIN            BSP_BUTTON_1                        /**< Button that will write to the LED characteristic of the peer */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                 /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define APP_BLE_CONN_CFG_TAG            1                                   /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO           3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    NRF_BLE_SCAN_DEF(m_scan);                                       /**< Scanning module instance. */
    BLE_LBS_C_DEF(m_ble_lbs_c);                                     /**< Main structure used by the LBS client module. */
    NRF_BLE_GATT_DEF(m_gatt);                                       /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                /**< DB discovery module instance. */
    static char const m_target_periph_name[] = "Unirro";     /**< Name of the device we try to connect to. This name is searched in the scan report data*/
    /**@brief Function to handle asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function to start scanning.
    static void scan_start(void)
        ret_code_t err_code;
        err_code = nrf_ble_scan_start(&m_scan);
        bsp_board_leds_off();
        bsp_board_led_on(CENTRAL_SCANNING_LED);
    /**@brief Handles events coming from the LED Button central module.
    static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
        switch (p_lbs_c_evt->evt_type)
            case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
                err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c,
                                                    p_lbs_c_evt->conn_handle,
                                                    &p_lbs_c_evt->params.peer_db);
                NRF_LOG_INFO("LED Button service discovered on conn_handle 0x%x.", p_lbs_c_evt->conn_handle);
    //            err_code = app_button_enable();
    //            APP_ERROR_CHECK(err_code);
                // LED Button service discovered. Enable notification of Button.
                err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
            } break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
            case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
                NRF_LOG_INFO("Button state changed on peer to 0x%x.", p_lbs_c_evt->params.button.button_state);
                if (p_lbs_c_evt->params.button.button_state)
                    bsp_board_led_on(LEDBUTTON_LED);
                    bsp_board_led_off(LEDBUTTON_LED);
            } break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
                // No implementation needed.
        // For readability.
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            // Upon connection, check which peripheral has connected (HR or RSC), initiate DB
            // discovery, update LEDs status and resume scanning if necessary. */
            case BLE_GAP_EVT_CONNECTED:
                ble_gap_addr_t addr = p_ble_evt->evt.gap_evt.params.connected.peer_addr;
                NRF_LOG_INFO("Connected.");
                err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
                err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
                // Update LEDs status, and check if we should be looking for more
                // peripherals to connect to.
                bsp_board_led_on(CENTRAL_CONNECTED_LED);
                bsp_board_led_off(CENTRAL_SCANNING_LED);
            } break;
            // Upon disconnection, reset the connection handle of the peer which disconnected, update
            // the LEDs status and start scanning again.
                NRF_LOG_INFO("Disconnected.");
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
                scan_start();
            } break;
            case BLE_GAP_EVT_TIMEOUT:
                // We have not specified a timeout for scanning, so only connection attemps can timeout.
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                            &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            } break;
            case BLE_GATTS_EVT_TIMEOUT:
            } break;
    /**@brief LED Button client initialization.
    static void lbs_c_init(void)
        ble_lbs_c_init_t lbs_c_init_obj;
        lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
        err_code = ble_lbs_c_init(&m_ble_lbs_c, &lbs_c_init_obj);
     * @details Initializes the SoftDevice and the BLE event interrupts.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON_PIN:
                err_code = ble_lbs_led_status_send(&m_ble_lbs_c, button_action);
                NRF_LOG_INFO("LBS write LED state %d", button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE)
                if (err_code == NRF_SUCCESS)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for handling Scaning events.
     * @param[in]   p_scan_evt   Scanning event.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                err_code = p_scan_evt->params.connecting_err.err_code;
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_lbs_on_db_disc_evt(&m_ble_lbs_c, p_evt);
    /**@brief Database discovery initialization.
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    /**@brief Function for initializing the log.
    static void log_init(void)
    /**@brief Function for initializing the timer.
    static void timer_init(void)
    /**@brief Function for initializing the Power manager. */
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        // Setting filters for scanning.
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Handle any pending log operation(s), then sleep until the next event occurs.
    //    NRF_LOG_FLUSH();
        nrf_pwr_mgmt_run();
    void key_test_function()
        switch(key_number)
          case 1:
          key_number=0;
          case 0x02:
          key_number=0;
          case 3:
          key_number=0;
          case 4:
          key_number=0;
          case 5:
          key_number=0;
          case 6:
          key_number=0;
          case 7:
          key_number=0;
          case 8:
          key_number=0;
          case 9:
          key_number=0;
          case 10:
          key_number=0;
          case 11:
          key_number=0;
          case 12:
          key_number=0;
          case 13:
          key_number=0;
          case 14:
          key_number=0;
          case 0x82:
          key_number=0;
          case 15:
          key_number=0;
        int test=0;
        float battery;
        gpio_triggerpin=0;
        gb_page_sel_key_count=0;
        key_pressed=0;
        key_number=0;
        gb_key_time_count=0;
        log_init();
        saadc_init();
        saadc_sampling_event_init();
        gpio_init();
        leds_init();
        timer_init();
        ble_stack_init();
        scan_init();
        gatt_init();
        db_discovery_init();
        lbs_c_init();
        // Start execution.
        NRF_LOG_INFO("Blinky CENTRAL example started\n");
        scan_start();
        for(;;)//while(1)
          Key_Detect();
          key_test_function();
          idle_state_handle();
  • Same error in app_button.c at line 186? Does it happen on startup, or do you need to do something to trigger it?
    I can't build your project here since there are several missing dependencies.
    NO. No the error is not shown as i removed the handler function.
    Yes. After connection event the device goes to NRF_BREAKPOINT_COND .
    Actually , I want to send the predefined  data to peripheral after detecting the key press is short or long from a 7*2 matrix keypad. i have done all the BLE stack related configuration as same as Led Button service example. Just the difference in the button handler.
  • NO. No the error is not shown as i removed the handler function.
    Ok, what does the error message say now?
  • No error message is shown . But the Peripheral gets the disconnect event also when i press the button to send the data the communication gets place. I am bit confused why the peripheral is getting the disconnect event ?. and if it is disconnecting then how the data is getting communicated.??? At  the time of disconnection the central does not get any disconnect event though.
