PeerManager error (error: 133)
I have a question about PeerManager.
SDK: 15.3.0
example: ble_app_multirole_lesc (I changed the source from the sample)
using device: EYSHJNZWZ (nRF52832)
connection device: Android (Bluetooth v5.0)
When trying to connect with LESC security level using PeerManager, the following error occurred.
Please tell me the cause.
<info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133
<warning> peer_manager_handler: Disconnecting conn_handle 0.
I know that this error means "BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP".
The connection partner supports pairing.
I confirmed that I could connect many times.
However, this error may occur.
Also, after this error occurs, the same error will occur no matter how many times you try to connect.
This error does not occur after reset.
  • A similar phenomenon occurred in the development kit.
    The same phenomenon occurred when the clock configuration was set to 0 instead of 1.
  • Hi there
    Okay, so the hardware works fine it seems. Are you able to reliably reproduce this or does it happen randomly?
    Are you able to upload a sniffer trace, so that we can see what happens on air when this disconnect occurs? If not, you could upload your project here, so that I could take a look and try to find out what's wrong here on my end.
    Simon
  • >> Okay, so the hardware works fine it seems. Are you able to reliably reproduce this or does it happen randomly?
    This phenomenon occurs randomly.
    It is difficult to reproduce reliably.
    I don't own a sniffer.
    Therefore, it cannot be confirmed by that method.
    It is difficult to upload all the contents of a project.
    You can upload some of them.
    How do I upload a project?
    Please tell me how.
  • Hi
    You can make a .zip file of wherever you've stored the project in your SDK folder. For example, if your project is a modified version of the ble_app_multirole_lesc example, go to \..\nRF5_SDK_15.3.0_59ac345\examples\ble_central_and_peripheral\experimental  and copy the ble_app_multirole_lesc example into a .zip file. Additionally, please add any modified SDK files and tell me what IDE you've used, as well as add any specific details on how to build and reproduce this error.
    Simon
  • I am able to consistently reproduce this issue.
    1) Build and run a Bluetooth app, e.g. the HRM example.
    2) Set NRF_LOG_BACKEND_RTT_ENABLED = 1 to enable logging
    3) Debug->Run
    - Pairing from the phone starts for a brief moment and then stops, no indication of a problem.
    - Debug log shows the above error.
    4) Set NRF_LOG_BACKEND_RTT_ENABLED =  to disable logging
    - The problem persists on the nRF-DK
    5) Flash the Blinky example (copy the hex file to the JLINK foder)
    6) Flash the HRM example, now you can pair again.
    SUMMARY: If I enable logging with NRF_LOG_BACKEND_RTT_ENABLED = 1, I cannot pair a phone to the nRF52-DK. Reverting the setting does not fix the issue, I'm forced to flash a different build to the nRF52-DK before I can re-flash and pair.
