NRF52832 MESH with UART
want to add UART communication to nRF52832 with mesh enable.
I have added,
  • nrf_drv_uart.c
  • nrfc_prs.c
  • nrfc_uart.c
  • nrfc_uarte.c
files into nRF_Drivers folder in project and added User include directories for them and also I have added
  • app_fifo.c
  • app_uart_fifo.c
  • retarget.c
files into nRF_Libraries folder in project and added User include directories also for them
In sdk_config.h I have made following settings,
  • NRFX_UARTE_ENABLED 1
  • NRFX_UARTE0_ENABLED 1
  • NRFX_UART_ENABLED 1
  • NRFX_UART0_ENABLED 1
  • NRFX_PRS_ENABLED 1
  • NRFX_PRS_BOX_4_ENABLED 1
and
  • UART_EASY_DMA_SUPPORT 1
  • UART_LEGACY_SUPPORT 1
And project also compiled after setting above configurations.
Code I made as follow (Modified version on light switch server )
#include "app_uart.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256
other functions same as light switch server example
    static uint8_t data_array[50];
    static uint8_t index = 0;
    uint32_t       err_code;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Handler\n");
    //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "evt %d\n", p_event->evt_type);
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "app data ready\n");
            index++;
            if (data_array[index - 1] == '\n')
                if (index > 1)
                        Need to implement the function in here
                    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Receive\n");
                index = 0;
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Communication ERROR\n");
        case APP_UART_FIFO_ERROR:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "FIFO ERROR\n");
static void uart_init(void)
//    #define RX_PIN_NUMBER  8
//    #define TX_PIN_NUMBER  7
//    #define CTS_PIN_NUMBER 6
//    #define RTS_PIN_NUMBER 5
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .rts_pin_no   = NULL,           //RTS_PIN_NUMBER,
        .cts_pin_no   = NULL,           //CTS_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_9600
#else
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,     //NRF_MESH_IRQ_PRIORITY_LOWEST,    //
                       err_code);
initilize uart_init inside initializer
static void initialize(void)
    uart_init();
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
#if BUTTON_BOARD
    ERROR_CHECK(hal_buttons_init(button_event_handler));
    ble_stack_init();
#if MESH_FEATURE_GATT_ENABLED
    gap_params_init();
    conn_params_init();
    mesh_init();
Following result got through debugging,
<t:          0>, main.c,  438, ----- BLE Mesh Light Switch Server Demo -----
<t:      13810>, main.c,  380, Initializing and adding models
<t:      13813>, main.c,  224, App OnOff Model Handle: 2
<t:      18763>, main.c,  479, Device UUID : 005955AA00000000E5F8D4197B5E9BA2
<t:     245432>, main.c,  308, Handler
<t:     245433>, main.c,  331, Communication ERROR
<t:     245436>, app_error_weak.c,  119, Mesh error 4 at 0x00000000 (:0)
according to above result once development board receive a signal through RX pin uart_event_handler function calls as expected, and inside that handler I got APP_UART_COMMUNICATION_ERROR
So what would be the cause for this error.
Is there any .c file missing or something with the code
