Help with serial DFU; "Failed to send data over serial interface!"
I'm attempting to use the serial DFU bootloader to update my nRF52832 firmware but am unable to. I started by following this guide though I changed some things so that the uart and not the ble bootloader was loaded. My setup consists of a nRF52832 on a custom board connected via a serial port to a linux computer. I'm using the most recent SDK (15.3) My process so far has been:
  1. Generate public and private keys with nrfutil
  2. Compiling uECC in external/micro-ecc/nRF52hf_gcc/armgcc
  3. Building the bootloader in examples/dfu/secure_bootloader/pca10040_uart_debug/armgcc
  4. Flash the nRF with the commands
    nrfjprog -f nrf52 --program softdevice.hex --chiperase
    nrfjprog -f nrf52 --program bootloader.hex -r
    Thanks to a comment on this post.
    I should note that when I flash with the version of the bootloader in pca10040_ble_debug, the nRF now begins advertising with the name DFUTarg, indicating to me that the DFU bootloader has been loaded successfully.
  5. In my Linux computer, which is separate from the computer I flashed the Bluetooth module with, I generate a DFU packet with the ble_app_blinky example and my private key with the command
    nrfutil pkg generate --debug-mode --application ble_blinky_example.hex --key-file private.key app_dfu_package.zip
  6. Try to perform a DFU with the command
    nrfutil dfu serial -pkg app_dfu_package.zip -p /dev/ttymxc3 -b 115200
At this point after a while the terminal where I run nrfutil prints "pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port".
To try to figure out what was going wrong, I added a bunch of debug statements in the files for the DFU bootloader and in dfu_transport_serial.py, which is called by nrfutil. On the terminal where I run nrfutil, I see that it continuously sends pings to the nRF but never receives a response. I also confirmed that the serial connection made with pyserial has identical parameters to serial connections I have made between my Linux computer and the nRF in the past, where each device was able to send and receive properly. Using the JLinkRTTViewer, I see the following from the nRF when I try to perform the DFU (please excuse the inconsistent debug format):
in nrfx_uarte_0_irq_handler
in nrfx_uarte uarte_irq_handler
Receive buffer is filled up
secondary buffer == 0
in nrfx_uarte rx_done_event
in nrf_drv_uart uarte_evt_handler
in nrfx_uarte_rx
Function: nrfx_uarte_rx, error code: NRF_SUCCESS.
reached end of uarte_irq_handler
in nrfx_uarte_rx
in nrfx_uarte_rx
in nrf_drv_uart_tx
NRF_DRV_UART_USE_UARTE==true
in nrfx_uarte_tx
in nrf_uarte_tx_buffer_set
<debug> nrf_dfu_serial: Received ping 1
<info> nrf_dfu_serial_uart: Allocated buffer 20001764
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
<debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
in nrfx_uarte_rx
in nrfx_uarte_rx
in nrfx_uarte_rx
in nrf_drv_uart_tx
in nrfx_uarte_tx
uarte tx in progress
<debug> nrf_dfu_serial: Received ping 2
<error> nrf_dfu_serial: Failed to send data over serial interface!
So it seems that the Bluetooth module is receiving the ping and attempting to send a response but the python script called by nrfutil never receives it. Thinking that nrfutil may simply be pinging too frequently and too quickly, I tried adding a delay but that didn't help. I have written other programs on this same set up where the nRF device was able to send serial messages that were received by the Linux computer, so I'm not sure what could be the issue now. Does anybody have any suggestions?
  • It's not enabled by pyserial by default, I mean when nrfutil runs and executes dfu_transport_serial.py it creates a serial connection with rtscts flow control enabled (see lines 151 and 199 in https://github.com/NordicSemiconductor/pc-nrfutil/blob/master/nordicsemi/dfu/dfu_transport_serial.py)
  • Oh sorry, didnt think when I asked the question. Yes, nRFutil enables it by default.
    Which pins on the nRF52 DK are you using? P0.05 through to P0.08? If that is the case, then try to change the pins to some pins that are not connected to the interface MCU, e.g. P0.22 through to P0.25.
    Bjørn
  • Yes we are using P0.05 to P0.08. It would be inconvenient to change the pins but I could do that as a last resort. I do want to clarify and say that this exact hardware setup has been used to produce a serial UART connection between the devices in the past with a different project, so I don't think the pins are the problem.
  • UPDATE: In addition to the nRF52832 on the custom board, I also have a BMD-301 evaluation kit which I have flashed with the same bootloader and SoftDevice with a Mac. I noticed that nrfutil starts with an initial ping that contains the hex values 9 1 and 192 so I've been manually sending those bytes to both nRF devices to see how they respond. After cleaning up my debugging statements this is what I get on the custom board:
    Enter main loop
    in function nrf_uarte_event_check
    in function nrf_uarte_rx_amount_get
    in function uart_event_handler
    event type = NRF_DRV_UART_EVT_RX_DONE
    in functino on_rx_complete
    in nrfx_uarte_rx
    in function nrf_uarte_int_disable
    Transfer rx_len: 1.
    in function nrf_uarte_rx_buffer_set
    in nrf_uarte_task_trigger
    in function nrf_uarte_int_enable
    in nrfx_uarte_rx
    Transfer rx_len: 1.
    in nrfx_uarte_rx
    Transfer rx_len: 1.
    in function nrf_dfu_serial_on_packet_received
    Received ping 1
    in function payload_free
    in function nrf_dfu_req_handler_on_req
    end of nrf_dfu_req_handler_on_req
    in function nrf_dfu_req_handler_req
    in function nrf_dfu_req_handler_req_process
    Request handling complete. Result: 0x1.
    in function dfu_req_handler_rsp_clbk
    p_res->requestion != NRF_DFU_OP_OBJECT_WRITE
    in function response send
    p_response->result == NRF_DFU_RES_CODE_SUCCESS
    in function rsp_send
    in nrf_drv_uart_tx
    in nrfx_uarte_tx
    Transfer tx_len: 5.
    Tx data:
    60 9 1 1 C0
    Function: nrfx_uarte_tx, error code: NRF_SUCCESS.
    On the evaluation board it is exactly the same except these additional statements are printed at the end:
    Last TX byte transmitted.
    in function nrf_uarte_tx_amount_get
    in nrfx_uarte tx_done_event
    event type = NRF_DRV_UART_EVT_TX_DONE
    For whatever reason my custom board isn't triggering nrfx_uarte_0_irq_handler that final time when the Last TX byte transmitted event occurs. What exactly triggers nrfx_uarte_0_irq_handler? Why would the same exact code result in this difference?
  • Hi ,
    I apologize for not replying sooner.
    The nrfx_uarte_0_irq_handler() will be invoked by any of the following events
    EVENTS_CTS 0x100
    CTS is activated (set low). Clear To Send.
    EVENTS_NCTS 0x104
    CTS is deactivated (set high). Not Clear To Send.
    EVENTS_RXDRDY 0x108
    Data received in RXD (but potentially not yet transferred to Data RAM)
    EVENTS_ENDRX 0x110
    EVENTS_TXDRDY 0x11C
    Data sent from TXD
    EVENTS_ENDTX 0x120
    EVENTS_ERROR 0x124
    Error detected
    EVENTS_RXTO 0x144
    Receiver timeout
    EVENTS_RXSTARTED 0x14C
    UART receiver has started
    EVENTS_TXSTARTED 0x150
    UART transmitter has started
    EVENTS_TXSTOPPED 0x158
    Transmitter stopped
    Its hard to say whats going on without knowing which events that are triggering the nrfx_uarte_0_irq_handler on the DK, but not the custom board. Do you think you could print the type of event in addition to "in function nrf_uarte_event_check" - It would also be useful if you could do a logic trace of the UART pins,just to verify that there nothing going on HW wise.
    Best regards
    Bjørn
