Init Packet
I'm referring this
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.2.0%2Flib_dfu_transport_ble.html
which states that when in bootloader mode, I've to send the init packet first & then the firmware image.
So what happens after I send 06 01 command. What is init packet? How do I create one? The response received for each command - is it written over a characteristic or a descriptor inside characteristic? My understanding is DFU Control Point & DFU Packet characteristics do not support read property. So where can I see the response received for every command sent by host to BLE device?
Sorry I could not understand a thing from the sniffer trace which I captured while executing the actual DFU procedure listed on Nordic Infocenter. I'm using SDK 15.2 & nrf52832.
5875.original.pcapng
  • It is done in the request handler module of the bootloader , see on_data_obj_select_request in nrf_dfu_req_handler.c (nRF5_SDK_15.2.0_9412b96\components\libraries\bootloader\dfu\nrf_dfu_req_handler.c)
    static void on_data_obj_select_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
        NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_SELECT (data)");
        p_res->select.crc    = s_dfu_settings.progress.firmware_image_crc;
        p_res->select.offset = s_dfu_settings.progress.firmware_image_offset;
        p_res->select.max_size = DATA_OBJECT_MAX_SIZE;
        NRF_LOG_DEBUG("crc = 0x%x, offset = 0x%x, max_size = 0x%x",
                      p_res->select.crc,
                      p_res->select.offset,
                      p_res->select.max_size);
  • Is the init packet generated from the zip package? - .dat file?
    I think the responses below are incorrect except the first two. What am I doing wrong?
    HOST -> BLE DEVICE BLE DEVICE -> HOST
    06 01 60-06-01-00-01-00-00-00-00-00-00-00-00-00-00
    01 01 8E 00 00 00 60-01-01
    12 8b 01 0a 45 08 01 12 41 08 90 4e 10 34 1a 02 af 01 20 00  60-12-02
    28 00 30 00 38 b0 8e 03 42 24 08 03 12 20 01 91 8e 46 bb 14  60-28-02
    fc b6 37 95 6d dd d4 34 40 a4 60 ab ec 76 57 8f 9c 72 e6 b5  60-FC-02
    8a 62 c7 9b b3 df 48 00 52 04 08 01 12 00 10 00 1a 40 9d 86 60-8A-02
    94 d0 23 bd 0e db 03 47 26 f9 4d 27 77 4c 4b 04 8e de 75 79  60-94-02
    bf d4 b5 1a df 0f 5a 39 f0 b1 5b 44 bc 12 bf 16 87 99 6d c8  60-BF-02
    e2 a7 aa 4e 62 c4 ad 68 55 2f b1 8c a4 27 1e bc 07 65 5a 0f  60-E2-02
    28 a3 60-28-02
    3 60-03-01-00-00-00-00-00-00-00-00
    4 60-04-08
    Yes, the init packet is the .dat file in the zip package.
    The first request from the host is the select command, where the control point replies with 60-06-01-00-01-00-00-00-00-00-00-00-00-00-00, which means that the Select command was successful, i.e. 60-06-01, then you have the max size of the init packet 00-01-00-00, the offset 00-00-00-00 and the CRC32 00-00-00-00.
    The second request is a Create request from the host, i.e. 01 01, where it informs the Control Point that the size of the init packet is 8E 00 00 00.
    The Control point should not respond to the data packets after the Control Point has replied with Create Success, i.e. 60-01-01.
    The two last operations consists of the following:
    Opcode 3 is a CRC request from the host. The control point replies with 60-03-01-00-00-00-00-00-00-00-00, which is means NRF_SUCESS, but the offset and the current CRC is zero.
    Opcode 4 is an Execute request from the host. The control point replies replies with 60-04-08, which means NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED.
    I would recommend to debug the bootloader when you transfer the init packet and set breakpoints at the following locations in the bootloader code.
    nRF5_SDK_15.2.0_9412b96/components/libraries/bootloader/dfu/nrf_dfu_req_handler.c:p_res->result = NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED;
    nRF5_SDK_15.2.0_9412b96/components/libraries/bootloader/dfu/nrf_dfu_validation.c:ret_val = NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED;
    You should hit one of them and then hopefully get an indication to why the bootloader does not permit the init packet.
    Best regards
    Bjørn
  • My nrf log file which I captured using RTT viewer -
    00> <info> app: Inside main
    00> <debug> app: In nrf_bootloader_init
    00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    00> <debug> nrf_dfu_settings: Settings OK
    00> <debug> app: Enter nrf_bootloader_fw_activate
    00> <info> app: No firmware to activate.
    00> <debug> app: Enter nrf_dfu_app_is_valid
    00> <debug> app: No valid app to boot.
    00> <debug> app: DFU mode because app is not valid.
    00> <info> nrf_bootloader_wdt: WDT is not enabled
    00> <debug> app: in weak nrf_dfu_init_user
    00> <debug> app: timer_stop (0x200057D0)
    00> <debug> app: timer_activate (0x200057D0)
    00> <info> app: Entering DFU mode.
    00> <debug> app: Initializing transports (found: 1)
    00> <debug> nrf_dfu_ble: Initializing BLE DFU transport
    00> <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
    00> <debug> nrf_dfu_ble: Enabling SoftDevice.
    00> <debug> nrf_dfu_ble: Configuring BLE stack.
    00> <debug> nrf_dfu_ble: Enabling the BLE stack.
    00> <debug> nrf_dfu_ble: No advertising name found
    00> <debug> nrf_dfu_ble: Using default advertising name
    00> <debug> nrf_dfu_ble: Advertising...
    00> <debug> nrf_dfu_ble: BLE DFU transport initialized.
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    00> <debug> app: Enter main loop
    00> <debug> nrf_dfu_ble: Connected
    00> <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 527, reply: 247).
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    00> <debug> app: Shutting down transports (found: 1)
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    00> <info> nrf_dfu_req_handler: Invalid opcode received: 0x12.
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x2
    00> <warning> nrf_dfu_ble: DFU request 18 failed with error: 0x2
    00> <info> nrf_dfu_req_handler: Invalid opcode received: 0x28.
    00> <warning> nrf_dfu_ble: DFU request 40 failed with error: 0x2
    00> <info> nrf_dfu_req_handler: Invalid opcode received: 0xFC.
    00> <warning> nrf_dfu_ble: DFU request 252 failed with error: 0x2
    00> <info> nrf_dfu_req_handler: Invalid opcode received: 0x8A.
    00> <warning> nrf_dfu_ble: DFU request 138 failed with error: 0x2
    00> <info> nrf_dfu_req_handler: Invalid opcode received: 0x94.
    00> <warning> nrf_dfu_ble: DFU request 148 failed with error: 0x2
    00> <info> nrf_dfu_req_handler: Invalid opcode received: 0xBF.
    00> <warning> nrf_dfu_ble: DFU request 191 failed with error: 0x2
    00> <info> nrf_dfu_req_handler: Invalid opcode received: 0xE2.
    00> <warning> nrf_dfu_ble: DFU request 226 failed with error: 0x2
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    00> <error> nrf_dfu_validation: Execute with faulty offset
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x8
    00> <warning> nrf_dfu_ble: DFUrequest 4 failed with error: 0x8
    00> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
    00> <debug> nrf_dfu_ble: max_conn_interval: 12
    00> <debug> nrf_dfu_ble: min_conn_interval: 12
    00> <debug> nrf_dfu_ble: slave_latency: 0
    00> <debug> nrf_dfu_ble: conn_sup_timeout: 600
    Whats missing?
  • HI Sonal,
    It looks like you are writting the date of the init packet to the Control Point Characteristic and not the DFU Packet characteristic. You see that you get a lot of invalid opcode respones. Try writting the data to the DFU packet characteristic instead.
    Best regards
    Bjørn
