Init Packet
I'm referring this
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.2.0%2Flib_dfu_transport_ble.html
which states that when in bootloader mode, I've to send the init packet first & then the firmware image.
So what happens after I send 06 01 command. What is init packet? How do I create one? The response received for each command - is it written over a characteristic or a descriptor inside characteristic? My understanding is DFU Control Point & DFU Packet characteristics do not support read property. So where can I see the response received for every command sent by host to BLE device?
Sorry I could not understand a thing from the sniffer trace which I captured while executing the actual DFU procedure listed on Nordic Infocenter. I'm using SDK 15.2 & nrf52832.
5875.original.pcapng
  • HI Sonal,
    its on_data_obj_write_request() in nrf_dfu_req_handler.c that handles data sent do the DFU packet characteristic.
        NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_WRITE (data)");
        if (!nrf_dfu_validation_init_cmd_present())
            /* Can't accept data because DFU isn't initialized by init command. */
            p_res->result = NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED;
            return;
        uint32_t const data_object_offset = s_dfu_settings.progress.firmware_image_offset -
                                            s_dfu_settings.progress.firmware_image_offset_last;
        if ((p_req->write.len + data_object_offset) > s_dfu_settings.progress.data_object_size)
            /* Can't accept data because too much data has been received. */
            NRF_LOG_ERROR("Write request too long");
            p_res->result = NRF_DFU_RES_CODE_INVALID_PARAMETER;
            return;
        uint32_t const write_addr = m_firmware_start_addr + s_dfu_settings.write_offset;
        ASSERT(p_req->callback.write);
        ret_code_t ret =
            nrf_dfu_flash_store(write_addr, p_req->write.p_data, p_req->write.len, p_req->callback.write);
        if (ret != NRF_SUCCESS)
            /* When nrf_dfu_flash_store() fails because there is no space in the queue,
             * stop processing the request so that the peer can detect a CRC error
             * and retransmit this object. Remember to manually free the buffer !
            p_req->callback.write((void*)p_req->write.p_data);
            return;
        /* Update the CRC of the firmware image. */
        s_dfu_settings.write_offset                   += p_req->write.len;
        s_dfu_settings.progress.firmware_image_offset += p_req->write.len;
        s_dfu_settings.progress.firmware_image_crc     =
            crc32_compute(p_req->write.p_data, p_req->write.len, &s_dfu_settings.progress.firmware_image_crc);
        /* This is only used when the PRN is triggered and the 'write' message
         * is answered with a CRC message and these field are copied into the response.
        p_res->write.crc    = s_dfu_settings.progress.firmware_image_crc;
        p_res->write.offset = s_dfu_settings.progress.firmware_image_offset;
    If the DFU process stops, then please post the debug log output from the bootloader.
    It is possible to write larger chunks than 20 bytes as long as you do not exceed the object size, see on_data_obj_write_request().  The ATT MTU size is negotiable, see the BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST case in ble_evt_handler() in nrf_dfu_ble.c. It can be set as high as NRF_SDH_BLE_GATT_MAX_MTU_SIZE, i.e. 247.
    Best regards
    Bjørn
  • HI Sonal,
            return;
            return;
        ret_code_t ret =
            return;
    Best regards
    Bjørn
  • Hi Bjorn,
    I have the init packet as 141 bytes. I am sending over the DFU packet characteristics as 15 bytes from nrf52833 controller. The another nrf52833 DFU bootloader receives upto 135 bytes. the last set of 6 bytes are not received by the bootloader. If i retransmit also, it gives the same result. Please suggest how to send all the 141 init bytes data.
