SOFTDEVICE: ASSERTION FAILED while running mesh.
Hi, I'm getting regular crashes with my app: SOFTDEVICE: ASSERTION FAILED.
Using and NRF52832, SDK 15.3.0, SD 132 6.1.1, and Mesh SDK 3.1.0.
With DEBUG defined, I don't really get more info: id=1, pc=148742, info=0.
The last mesh log usually is something with TX (mostly net_beacon.c,  265, BEACON TX).
One crash, I also had a log of getting event NRF_EVT_RADIO_SESSION_IDLE.
I use the mesh SDK to communicate via mesh between nodes, to advertise iBeacon (100ms interval), and I use the scan callback. Next to that, I also use the SD to advertise service data.
Parameters:
	nrf_clock_lf_cfg_t lfclksrc;
	lfclksrc.source = NRF_SDH_CLOCK_LF_SRC;
	lfclksrc.rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV;
	lfclksrc.rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV;
	lfclksrc.accuracy = NRF_CLOCK_LF_ACCURACY_20_PPM;
	mesh_stack_init_params_t init_params;
	init_params.core.irq_priority       = NRF_MESH_IRQ_PRIORITY_THREAD;
	init_params.core.lfclksrc           = lfclksrc;
	init_params.core.p_uuid             = NULL;
	init_params.core.relay_cb           = NULL;
Any idea of what causes this crash?
  • Tried completely without mesh advertising, but that didn't help.
    Also tried with mesh 3.2.0, that didn't help either.
    Every crash I've seen last days, I always got this event 7 (NRF_EVT_RADIO_SESSION_IDLE).
  • Which priorities are you running in your example (see link)?
  • All mesh functions are called from thread, from the main loop (I'm using the app scheduler).
    Edit: while checking your link, I do notice that I hadn't set NRF_SDH_DISPATCH_MODEL to 1 yet. I will try and see if that helps. Until now, I manually put events that I actually use on the app scheduler. Does this setting matter for the mesh code?
    Edit2: With NRF_SDH_DISPATCH_MODEL 1, I'm still getting the crash.
    The one that's easiest to reproduce is the one on boot, where i get timeouts from FDS, and then this event 7 (NRF_EVT_RADIO_SESSION_IDLE).
    The back trace I have in that case:
    #0  0x0003b012 in app_error_fault_handler (id=1, pc=86552, info=0) at (...)/SDK-15-3/components/libraries/util/app_error_weak.c:100
    #1  0x00023de8 in ?? ()
    Backtrace stopped: previous frame identical to this frame (corrupt stack?)
    (gdb) info registers
    r0             0x0    0
    r1             0x1    1
    r2             0xe000e100    3758153984
    r3             0x80000000    2147483648
    r4             0x10001    65537
    r5             0x0    0
    r6             0x1    1
    r7             0x15218    86552
    r8             0x0    0
    r9             0x20005eac    536895148
    r10            0x20000000    536870912
    r11            0x0    0
    r12            0x0    0
    sp             0x2000fd98    0x2000fd98
    lr             0x3c0b9    245945
    pc             0x3b012    0x3b012 <app_error_fault_handler+110>
    xpsr           0x810f0003    2165243907
    msp            0x2000fd98    536935832
    psp            0x0    0
    primask        0x1    1
    basepri        0x0    0
    faultmask      0x0    0
    control        0x0    0
    fpscr          0x80000010    2147483664
  • Also tried with PERSISTENT_STORAGE 0, but still getting the same crash.
  • I tried setting TIMESLOT_END_SAFETY_MARGIN_US to 1000. In that case, I still quite often get the FDS timeouts on boot, but it doesn't result in the event NRF_EVT_RADIO_SESSION_IDLE, and a softdevice assert anymore.
    Does that mean the 100 is too tight? How do you determine the correct value?
