Disable HID some of the time
We are developing a device that has different "modes", and in some modes it acts as a HID keyboard and mouse, but in other modes it does not. This device connects to iOS and android, and in HID modes causes the virtual keyboard to be hidden as it is a HID keyboard. So in none-HID modes we want to avoid iOS recognising the device as a HID keyboard.
We have an existing device on a different platform which already implements this. When switching between HID and non-HID modes, it will modify the HID report and send a services modified indication for the HID service, causing iOS to re-read the HID report. This works fine.
What would be the best way to do the same thing on Nordic nRF52832? I've read that the GATT database cannot be modified without disconnection, which we want to avoid. Is there any way to do the same as on the existing platform – modify the HID report and send a services changed indication?
  • There is a way to find this information, here is a function that will determine the end handle for a given service handle:
    ret_code_t get_service_end_handle(uint16_t service_handle, uint16_t *end_handle) {
        VERIFY_PARAM_NOT_NULL(end_handle);
        ret_code_t err_code = NRF_SUCCESS;
        for (uint16_t handle = service_handle + 1; handle < UINT16_MAX; handle++) {
            ble_uuid_t uuid;
            err_code = sd_ble_gatts_attr_get(handle, &uuid, NULL);
            if (err_code == NRF_ERROR_NOT_FOUND) {
                *end_handle = handle - 1;
                return NRF_SUCCESS;
            VERIFY_SUCCESS(err_code);
            if (uuid.type != BLE_UUID_TYPE_BLE ||
                (uuid.uuid != BLE_UUID_SERVICE_PRIMARY && uuid.uuid != BLE_UUID_SERVICE_SECONDARY)) {
                continue;
            return NRF_SUCCESS;
        *end_handle = UINT16_MAX;
        return NRF_ERROR_NOT_FOUND;
    This end handle can then be passed to sd_ble_gatts_service_changed:
    ret_code_t service_changed(uint16_t conn_handle, uint16_t service_handle) {
        uint16_t service_end;
        (void)get_service_end_handle(service_handle, &service_end);
        return sd_ble_gatts_service_changed(conn_handle, service_handle, service_end);
  • Hello Nick,
    You mentioned
    "We have an existing device on a different platform which already implements this. When switching between HID and non-HID modes, it will modify the HID report and send a services modified indication for the HID service, causing iOS to re-read the HID report. This works fine."
    Please if you can inform us
    (1) is that worked for you with nordic solution in iOS?
    (2) was that working for you with different platform for android OS, where you modify the HID report from keyboard to any other one and android phone still recognize it as keyboard Vs non-keyboard device? You mentioned that iOS re-read the HID report and working fine. But does same works well for android ?
    khodidas
