QSPI block device issue with S25FS flash part
I am trying to modify the nrf_block_dev_qspi.c to work with S25FS256 flash part in our project. However, i am facing issues. When trying to understand the code I see some things that I don't quite understand.
#define BD_ERASE_UNIT_INVALID_ID   0xFFFFFFFF /**< Invalid erase unit number*/
// p_work->erase_unit_idx is initialized to BD_ERASE_UNIT_INVALID_ID in init function
// This means p_work->erase_unit_idx = -1
uint32_t block_to_program = __CLZ(__RBIT(p_work->erase_unit_dirty_blocks));
uint32_t dst_address = (p_work->erase_unit_idx * NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE) +
                               (block_to_program * p_work->geometry.blk_size);
const void * p_src_address = p_work->p_erase_unit_buff +
                                     block_to_program * p_work->geometry.blk_size;
In the above snippet of code, "p_work->erase_unit_dirty_blocks" is initially 0. This results in "block_to_program" being 32. Is this a valid block number? It seems like with a block size of 512, and an erase unit size of 4096, results in 8 blocks only. So block_to_program being 32 is suspicious.
Moreover, the "p_work->erase_unit_idx" is initialized with -1. This results in the "dst_address" being = (-1 * 4096) + (32 * 512). What is the logic here to start with -1.
Another point is, "p_src_address" = p_work->p_erase_unit_buff + (32 * 512 = 16384). The buffer is only allocated with 4096 bytes in the structure. Not sure if this is a bug or some other logic explains this.
Could anyone answer these questions, as it is critical to our project in understanding this code and modifying as necessary for our project.
  • Hi, latest is that we expect to have a fix tomorrow.
    Kenneth
  • They have found the root cause and understood the issue. This issue may have a broader impact on the behavior of the driver. They need a few more days to prepare software test harness, investigation and solving the issue.
  • Any ETA? Also can we get the patch so we can try it out?
  • Hi Sumanth,
    All the concerns you had with wrong initialization values were converging into a bug where there could be unnecessary write writes. So we opted for a simple solution now to avoid unnecessarily writes and adding a few more checks.
     erase_unit_idx initialized with -1 could provide extra write to memory, but now with bypassing unnecessary write when erase_unit_dirty_blocks is zero, the IRQ should reload erase_unit_idx with the correct value.
    Please replace your qspi_block dev driver file with the below
     * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(NRF_BLOCK_DEV_QSPI)
    #include "nrf_serial_flash_params.h"
    #include "nrf_block_dev_qspi.h"
    #include <inttypes.h>
    /**@file
     * @ingroup nrf_block_dev_qspi
     * @brief This module implements block device API. It should be used as a reference block device.
    #if NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL
    #define NRF_LOG_INFO_COLOR  NRF_BLOCK_DEV_QSPI_CONFIG_INFO_COLOR
    #define NRF_LOG_DEBUG_COLOR NRF_BLOCK_DEV_QSPI_CONFIG_DEBUG_COLOR
    #else
    #define NRF_LOG_LEVEL       0
    #include "nrf_log.h"
    #define QSPI_STD_CMD_WRSR    0x01   /**< Write status register command*/
    #define QSPI_STD_CMD_RSTEN   0x66   /**< Reset enable command*/
    #define QSPI_STD_CMD_RST     0x99   /**< Reset command*/
    #define QSPI_STD_CMD_READ_ID 0x9F   /**< Read ID command*/
    #define BD_PAGE_PROGRAM_SIZE 256    /**< Page program size (minimum block size)*/
    #define BD_ERASE_UNIT_ERASE_VAL    0xFFFFFFFF /**< Erased memory value*/
     * @brief Block to erase unit translation
     * @param blk_id    Block index
     * @param blk_size  Block size
    #define BD_BLOCK_TO_ERASEUNIT(blk_id, blk_size)   \
        ((blk_id) * (blk_size)) / (NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE)
     * @brief Blocks per erase unit
    #define BD_BLOCKS_PER_ERASEUNIT(blk_size)         \
        (NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE / (blk_size))
    static ret_code_t block_dev_qspi_eunit_write(nrf_block_dev_qspi_t const * p_qspi_dev,
                                                 nrf_block_req_t * p_blk_left);
    static void block_dev_qspi_read_from_eunit(nrf_block_dev_qspi_t const * p_qspi_dev)
        nrf_block_dev_qspi_work_t const * p_work = p_qspi_dev->p_work;
        /*In write-back mode data that we read might not be the same as in erase unit buffer*/
        uint32_t eunit_start = BD_BLOCK_TO_ERASEUNIT(p_work->req.blk_id,
        uint32_t eunit_end = BD_BLOCK_TO_ERASEUNIT(p_work->req.blk_id + p_work->req.blk_count,
        if ((eunit_start > p_work->erase_unit_idx) || (eunit_end < p_work->erase_unit_idx))
            /*Do nothing. Read request doesn't hit current cached erase unit*/
            return;
        /*Case 1: Copy data from start erase unit*/
        if (eunit_start == p_work->erase_unit_idx)
             size_t blk = p_work->req.blk_id %
                          BD_BLOCKS_PER_ERASEUNIT(p_work->geometry.blk_size);
             size_t cnt = BD_BLOCKS_PER_ERASEUNIT(p_work->geometry.blk_size) - blk;
             size_t off = p_work->geometry.blk_size * blk;
             if (cnt > p_work->req.blk_count)
                 cnt = p_work->req.blk_count;
             memcpy(p_work->req.p_buff,
                    p_work->p_erase_unit_buff + off,
                    cnt * p_work->geometry.blk_size);
             return;
        /*Case 2: Copy data from end erase unit*/
        if (eunit_end == p_work->erase_unit_idx)
             size_t cnt = (p_work->req.blk_id + p_work->req.blk_count) %
             size_t off = (p_work->erase_unit_idx * BD_BLOCKS_PER_ERASEUNIT(p_work->geometry.blk_size) -
                           p_work->req.blk_id) * p_work->geometry.blk_size;
             memcpy((uint8_t *)p_work->req.p_buff + off,
                    p_work->p_erase_unit_buff,
             return;
        /*Case 3: Copy data from  eunit_start < p_work->erase_unit_idx < eunit_end*/
               NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE);
     * @brief Active QSPI block device handle. Only one instance.
    static nrf_block_dev_qspi_t const * m_active_qspi_dev;
    static void qspi_handler(nrf_drv_qspi_evt_t event, void * p_context)
        if (m_active_qspi_dev != p_context)
            return;
        nrf_block_dev_qspi_t const * p_qspi_dev = p_context;
        nrf_block_dev_qspi_work_t *  p_work = p_qspi_dev->p_work;
        nrf_block_req_t * p_blk_left = &p_work->left_req;
        switch (p_work->state)
            case NRF_BLOCK_DEV_QSPI_STATE_READ_EXEC:
                if (p_work->writeback_mode)
                    block_dev_qspi_read_from_eunit(p_qspi_dev);
                p_work->state = NRF_BLOCK_DEV_QSPI_STATE_IDLE;
                if (p_work->ev_handler)
                    const nrf_block_dev_event_t ev = {
                            NRF_BLOCK_DEV_EVT_BLK_READ_DONE,
                            NRF_BLOCK_DEV_RESULT_SUCCESS,
                            &p_work->req,
                            p_work->p_context
                    p_work->ev_handler(&p_qspi_dev->block_dev, &ev);
            case NRF_BLOCK_DEV_QSPI_STATE_EUNIT_LOAD:
                ret_code_t ret;
                uint32_t erase_unit = BD_BLOCK_TO_ERASEUNIT(p_blk_left->blk_id,
                UNUSED_VARIABLE(erase_unit);
                ASSERT(erase_unit == p_work->erase_unit_idx);
                /* Check if block is in erase unit buffer*/
                ret = block_dev_qspi_eunit_write(p_qspi_dev, p_blk_left);
                ASSERT(ret == NRF_SUCCESS);
                UNUSED_VARIABLE(ret);
            case NRF_BLOCK_DEV_QSPI_STATE_WRITE_ERASE:
            case NRF_BLOCK_DEV_QSPI_STATE_WRITE_EXEC:
                /*Clear last programmed block*/
                if (p_work->state == NRF_BLOCK_DEV_QSPI_STATE_WRITE_EXEC)
                    p_work->erase_unit_dirty_blocks ^= 1u << block_to_program;
                if (p_work->erase_unit_dirty_blocks == 0)
                    if (p_work->left_req.blk_count)
                        /*Load next erase unit*/
                        ret_code_t ret;
                        uint32_t eunit = BD_BLOCK_TO_ERASEUNIT(p_blk_left->blk_id,
                        p_work->erase_unit_idx = eunit;
                        p_work->state = NRF_BLOCK_DEV_QSPI_STATE_EUNIT_LOAD;
                        ret = nrf_drv_qspi_read(p_work->p_erase_unit_buff,
                                                NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE,
                    /*All blocks are programmed. Call event handler if required.*/
                    if (p_work->ev_handler && !p_work->cache_flushing)
                                NRF_BLOCK_DEV_EVT_BLK_WRITE_DONE,
                                &p_work->req,
                                p_work->p_context
                    p_work->cache_flushing = false;
                /*Get next block to program from program mask*/
                ASSERT(block_to_program <
                       (NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE / p_work->geometry.blk_size));
                ASSERT(dst_address <
                       (p_work->geometry.blk_count * p_qspi_dev->qspi_bdev_config.block_size));
                p_work->state = NRF_BLOCK_DEV_QSPI_STATE_WRITE_EXEC;
                ret_code_t ret = nrf_drv_qspi_write(p_src_address,
                                                    p_work->geometry.blk_size,
                                                    dst_address);
                ASSERT(0);
    static void wait_for_idle(nrf_block_dev_qspi_t const * p_qspi_dev)
        while (p_work->state != NRF_BLOCK_DEV_QSPI_STATE_IDLE)
            __WFI();
    static ret_code_t block_dev_qspi_init(nrf_block_dev_t const * p_blk_dev,
                                          nrf_block_dev_ev_handler ev_handler,
                                          void const * p_context)
        ASSERT(p_blk_dev);
                                      CONTAINER_OF(p_blk_dev, nrf_block_dev_qspi_t, block_dev);
        nrf_drv_qspi_config_t const * p_qspi_cfg = &p_qspi_dev->qspi_bdev_config.qspi_config;
        ret_code_t ret = NRF_SUCCESS;
        NRF_LOG_INST_DEBUG(p_qspi_dev->p_log, "Init");
        if (p_qspi_dev->qspi_bdev_config.block_size % BD_PAGE_PROGRAM_SIZE)
            /*Unsupported block size*/
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Unsupported block size because of program page size");
            return NRF_ERROR_NOT_SUPPORTED;
        if (NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE % p_qspi_dev->qspi_bdev_config.block_size)
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Unsupported block size because of erase unit size");
        if (m_active_qspi_dev)
            /* QSPI instance is BUSY*/
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Cannot init because QSPI is busy");
            return NRF_ERROR_BUSY;
        ret = nrf_drv_qspi_init(p_qspi_cfg, qspi_handler, (void *)p_blk_dev);
        if (ret != NRF_SUCCESS)
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI init error: %"PRIu32"", ret);
            return ret;
        nrf_qspi_cinstr_conf_t cinstr_cfg = {
            .opcode    = QSPI_STD_CMD_RSTEN,
            .length    = NRF_QSPI_CINSTR_LEN_1B,
            .io2_level = true,
            .io3_level = true,
            .wipwait   = true,
            .wren      = true
        /* Send reset enable */
        ret = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI reset enable command error: %"PRIu32"", ret);
            return ret;
        /* Send reset command */
        cinstr_cfg.opcode = QSPI_STD_CMD_RST;
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI reset command error: %"PRIu32"", ret);
            return ret;
        /* Get 3 byte identification value */
        uint8_t rdid_buf[3] = {0, 0, 0};
        cinstr_cfg.opcode = QSPI_STD_CMD_READ_ID;
        cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_4B;
        ret = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, rdid_buf);
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI get 3 byte id error: %"PRIu32"", ret);
            return ret;
        nrf_serial_flash_params_t const * serial_flash_id = nrf_serial_flash_params_get(rdid_buf);
        if (!serial_flash_id)
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI FLASH not supported");
        if (serial_flash_id->erase_size != NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE)
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI FLASH erase unit size not supported");
        /* Calculate block device geometry.... */
        uint32_t blk_size = p_qspi_dev->qspi_bdev_config.block_size;
        uint32_t blk_count = serial_flash_id->size / p_qspi_dev->qspi_bdev_config.block_size;
        if (!blk_count || (blk_count % BD_BLOCKS_PER_ERASEUNIT(blk_size)))
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI FLASH block size not supported");
        p_work->geometry.blk_size = blk_size;
        p_work->geometry.blk_count = blk_count;
        p_work->p_context = p_context;
        p_work->ev_handler = ev_handler;
        p_work->erase_unit_idx = BD_ERASE_UNIT_INVALID_ID;
        p_work->writeback_mode =  (p_qspi_dev->qspi_bdev_config.flags &
                                   NRF_BLOCK_DEV_QSPI_FLAG_CACHE_WRITEBACK) != 0;
        m_active_qspi_dev = p_qspi_dev;
            /*Asynchronous operation (simulation)*/
                    NRF_BLOCK_DEV_EVT_INIT,
                    NULL,
                    p_work->p_context
            p_work->ev_handler(p_blk_dev, &ev);
        return NRF_SUCCESS;
    static ret_code_t block_dev_qspi_uninit(nrf_block_dev_t const * p_blk_dev)
        ASSERT(p_blk_dev);
        NRF_LOG_INST_DEBUG(p_qspi_dev->p_log, "Uninit");
        if (m_active_qspi_dev != p_qspi_dev)
        if (p_work->state != NRF_BLOCK_DEV_QSPI_STATE_IDLE)
            /* Previous asynchronous operation in progress*/
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Cannot uninit because QSPI is busy");
            /*Asynchronous operation*/
                    NRF_BLOCK_DEV_EVT_UNINIT,
                    NULL,
                    p_work->p_context
        p_work->state = NRF_BLOCK_DEV_QSPI_STATE_DISABLED;
        nrf_drv_qspi_uninit();
        memset(p_work, 0, sizeof(nrf_block_dev_qspi_work_t));
        m_active_qspi_dev = NULL;
        return NRF_SUCCESS;
    static ret_code_t block_dev_qspi_read_req(nrf_block_dev_t const * p_blk_dev,
                                              nrf_block_req_t const * p_blk)
        ASSERT(p_blk_dev);
        ASSERT(p_blk);
        NRF_LOG_INST_DEBUG(
            p_qspi_dev->p_log,
            "Read req from block %"PRIu32" size %"PRIu32"(x%"PRIu32") to %"PRIXPTR,
            p_blk->blk_id,
            p_blk->blk_count,
            p_blk_dev->p_ops->geometry(p_blk_dev)->blk_size,
            p_blk->p_buff);
        if ((p_blk->blk_id + p_blk->blk_count) > p_work->geometry.blk_count)
           NRF_LOG_INST_ERROR(
               p_qspi_dev->p_log,
               "Out of range read req block %"PRIu32" count %"PRIu32" while max is %"PRIu32,
               p_blk->blk_id,
               p_blk->blk_count,
               p_blk_dev->p_ops->geometry(p_blk_dev)->blk_count);
           return NRF_ERROR_INVALID_ADDR;
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Cannot read because QSPI is busy");
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Cannot read because of ongoing previous operation");
        p_work->left_req = *p_blk;
        p_work->req = *p_blk;
        p_work->state = NRF_BLOCK_DEV_QSPI_STATE_READ_EXEC;
        ret = nrf_drv_qspi_read(p_blk_left->p_buff,
                                p_blk_left->blk_count * p_work->geometry.blk_size,
                                p_blk_left->blk_id * p_work->geometry.blk_size);
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI read error: %"PRIu32"", ret);
            return ret;
        p_blk_left->p_buff = NULL;
        p_blk_left->blk_count = 0;
        if (!p_work->ev_handler && (p_work->state != NRF_BLOCK_DEV_QSPI_STATE_IDLE))
            /*Synchronous operation*/
            wait_for_idle(p_qspi_dev);
        return ret;
    static bool block_dev_qspi_update_eunit(nrf_block_dev_qspi_t const * p_qspi_dev,
                                            size_t off,
                                            const void * p_src,
                                            size_t len)
        ASSERT((len % sizeof(uint32_t)) == 0)
        uint32_t *       p_dst32 = (uint32_t *)(p_work->p_erase_unit_buff + off);
        const uint32_t * p_src32 = p_src;
        bool erase_required = false;
        len /= sizeof(uint32_t);
        /*Do normal copying until erase unit is not required*/
        do
            if (*p_dst32 != *p_src32)
                if (*p_dst32 != BD_ERASE_UNIT_ERASE_VAL)
                    erase_required = true;
                /*Mark block as dirty*/
                p_work->erase_unit_dirty_blocks |= 1u << (off / p_work->geometry.blk_size);
            *p_dst32++ = *p_src32++;
            off += sizeof(uint32_t);
        } while (--len);
        return erase_required;
    static ret_code_t block_dev_qspi_write_start(nrf_block_dev_qspi_t const * p_qspi_dev)
        if (!p_work->erase_required)
            /*Bypass write if there if no dirty block.*/
            if (!p_work->erase_unit_dirty_blocks)
                qspi_handler(NRFX_QSPI_EVENT_DONE, (void *)p_qspi_dev);
                return NRF_SUCCESS;
            /*Get first block to program from program mask*/
            ASSERT(block_to_program < (NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE / p_work->geometry.blk_size));
            return nrf_drv_qspi_write(p_src_address,
                                      dst_address);
        /*Erase is required*/
        uint32_t address = (p_work->erase_unit_idx * NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE);
        p_work->state = NRF_BLOCK_DEV_QSPI_STATE_WRITE_ERASE;
        p_work->erase_required = false;
        return nrf_drv_qspi_erase(NRF_QSPI_ERASE_LEN_4KB, address);
        size_t blk = p_blk_left->blk_id %
        if (cnt > p_blk_left->blk_count)
            cnt = p_blk_left->blk_count;
        bool erase_required = block_dev_qspi_update_eunit(p_qspi_dev,
                                                          off,
                                                          p_blk_left->p_buff,
        if (erase_required)
            p_work->erase_required = true;
        p_blk_left->blk_count -= cnt;
        p_blk_left->blk_id += cnt;
        p_blk_left->p_buff = (uint8_t *)p_blk_left->p_buff + cnt * p_work->geometry.blk_size;
        if (p_work->erase_required)
            uint32_t blk_size = p_work->geometry.blk_size;
            p_work->erase_unit_dirty_blocks |= (1u << BD_BLOCKS_PER_ERASEUNIT(blk_size)) - 1;
        if (p_work->erase_unit_dirty_blocks == 0 || p_work->writeback_mode)
            /*No dirty blocks detected. Write end.*/
            if (p_work->ev_handler && p_blk_left->blk_count == 0)
                        &p_work->req,
                        p_work->p_context
                return NRF_SUCCESS;
        return block_dev_qspi_write_start(p_qspi_dev);
    static ret_code_t block_dev_qspi_write_req(nrf_block_dev_t const * p_blk_dev,
        ASSERT(p_blk_dev);
        ASSERT(p_blk);
        NRF_LOG_INST_DEBUG(
            p_qspi_dev->p_log,
            "Write req to block %"PRIu32" size %"PRIu32"(x%"PRIu32") from %"PRIXPTR,
            p_blk->blk_id,
            p_blk->blk_count,
            p_blk->p_buff);
           NRF_LOG_INST_ERROR(
               p_qspi_dev->p_log,
               "Out of range write req block %"PRIu32" count %"PRIu32" while max is %"PRIu32,
               p_blk->blk_id,
               p_blk->blk_count,
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Cannot write because QSPI is busy");
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "Cannot write because of ongoing previous operation");
        if (erase_unit == p_work->erase_unit_idx)
                ret = block_dev_qspi_write_start(p_qspi_dev);
                p_work->erase_unit_idx = erase_unit;
                        erase_unit * NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE);
            NRF_LOG_INST_ERROR(p_qspi_dev->p_log, "QSPI write error: %"PRIu32"", ret);
            return ret;
        return ret;
    static ret_code_t block_dev_qspi_ioctl(nrf_block_dev_t const * p_blk_dev,
                                           nrf_block_dev_ioctl_req_t req,
                                           void * p_data)
        ASSERT(p_blk_dev);
        switch (req)
            case NRF_BLOCK_DEV_IOCTL_REQ_CACHE_FLUSH:
                bool * p_flushing = p_data;
                NRF_LOG_INST_DEBUG(p_qspi_dev->p_log, "IOCtl: Cache flush");
                if (!p_work->writeback_mode || p_work->erase_unit_dirty_blocks == 0)
                    if (p_flushing)
                        *p_flushing = false;
                    return NRF_SUCCESS;
                ret_code_t ret =  block_dev_qspi_write_start(p_qspi_dev);
                if (ret == NRF_SUCCESS)
                    if (p_flushing)
                        *p_flushing = true;
                    p_work->cache_flushing = true;
                return ret;
            case NRF_BLOCK_DEV_IOCTL_REQ_INFO_STRINGS:
                if (p_data == NULL)
                    return NRF_ERROR_INVALID_PARAM;
                nrf_block_dev_info_strings_t const * * pp_strings = p_data;
                *pp_strings = &p_qspi_dev->info_strings;
                return NRF_SUCCESS;
    static nrf_block_dev_geometry_t const * block_dev_qspi_geometry(nrf_block_dev_t const * p_blk_dev)
        ASSERT(p_blk_dev);
        return &p_work->geometry;
    const nrf_block_dev_ops_t nrf_block_device_qspi_ops = {
            .init = block_dev_qspi_init,
            .uninit = block_dev_qspi_uninit,
            .read_req = block_dev_qspi_read_req,
            .write_req = block_dev_qspi_write_req,
            .ioctl = block_dev_qspi_ioctl,
            .geometry = block_dev_qspi_geometry,
    #endif // NRF_MODULE_ENABLED(NRF_BLOCK_DEV_QSPI)
    The team is also reconsidering to refactor most of the code, but that is something that is long on the roadmap, so please do not wait for that in the near term.
    /Susheel
  • Hi Susheel,
    Thanks for the update. However i still see issues when i change the NRF_BLOCK_DEV_QSPI_ERASE_UNIT_SIZE to 64KB and m_sflash_params.erase_size = 64KB.
    For some reason the code only works for 4KB erase unit size. The flash part we are using has 64 KB erase size. Any idea why?
