Storing adv data
Hi. My application is scanning ble beacons for 1 sec every minute, and I want to store this data in an array to be sent every 10 min. I am getting the data in BLE_GAP_EVT_ADV_REPORT in p_ble_evt->header.evt_id, then I am printing to verify what I have received, and then I am storing the data using  the following
for (int i=0;i<p_gap_evt->params.adv_report.data.len;i++)
    devices[k++]=p_gap_evt->params.adv_report.data.p_data[i];
Then in repeated timer handler, I am sending the devices array that should contain all the beacons 30 byte data. At this time I have 5 beacons, so I declared array of size 200. In timer handler, I am doing this.
static void repeated_timer_handler(void * p_context)
    for (int i=0;i<sizeof(devices);i++)
        app_uart_put(devices[i]);
My main function looks like
    // Initialize.
    log_init();
    uart_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    app_timer_init();
    create_timers();
    scan_start();
    app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(15000), NULL);
    // Enter main loop.
    for (;;)
        idle_state_handle();
But I am not getting anything on console, and if change my first snippet like this
    devices[i]=p_gap_evt->params.adv_report.data.p_data[i];
devices [k++] to devices[i], then in timer handler I get data in devices array but the last data that is stored, not all the data. I want to store the data for 10 scanning instances (1 sec scan every 1 min), then the timer handler will be executed every 10 min to send the data, and the process repeats.
Kindly suggest suitable way to achieve this.
I appreciate your suggestions.
  • if you have access to the UART output then I suggest that you use the NRF_LOG module with UART as backend, instead of app_uart_put. The reason for this is that NRF_LOG will give you information when the APP_ERROR_CHECK() detects something strange. Maybe the error handler fires in your application, causing the application to restart, and hence your counter goes back, and you lose all your previously stored data.
    So, enable logging in sdk_config.h with UART as backend, and define DEBUG in your preprocessor defines, and monitor the uart log output.
  • OK I will do as you said. I will enable the logging using uart. And I will get back to you in a day.
  • Hi Edvin,
    Well, i have tried many things and have completed most of my work. But still I am not able to store advertisement data. I am sure that the problem is with storing part, because when I store only one device, it works as expected, but when I store multiple devices in one array as I mentioned above, the application crashes.This storing part is the main part of my application, and I am no C expert, so could not figured out how to store the devices data into one array for specific time to be able to send it and reinitialize the array and repeat the process.
    Can you suggest something.
    PK SHER
  • Does the log say anything on where the application crashes? You can try to add "DEBUG" to your preprocessor defines if it only says "Fatal error". Then it should give you a line number.
    Looking at your snippet from a couple of posts ago:
    static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
      ble_gap_evt_t const *p_gap_evt = &p_ble_evt->evt.gap_evt;
      uint8_t uuid[30];
      uint8_array_t adv_data;
      switch (p_ble_evt->header.evt_id) {
      case BLE_GAP_EVT_ADV_REPORT: {
        nrf_gpio_pin_set(LED2);    //Green LED
        if (p_gap_evt->params.adv_report.data.p_data[0] == 0x02) {
          if (p_gap_evt->params.adv_report.data.p_data[1] == 0x01) {
            if (p_gap_evt->params.adv_report.data.p_data[2] == 0x06) {
                for (int i = 0; i < p_gap_evt->params.adv_report.data.len; i++)
                    devices[deviceLength] = p_gap_evt->params.adv_report.data.p_data[i];
                    deviceLength++;
                devices[deviceLength] = p_gap_evt->params.adv_report.rssi;
                deviceLength++;
        nrf_gpio_pin_clear(LED2);
    What type is your deviceLength variable?
    Try to set it as a "volatile uint32_t" or whatever uintx_t you use. Just make it volatile. You can declare it at the top of that .c file that you use it in.
    Also, what type of variable is the "devices" variable? Is it an array? what type? How do you declare it? If it is an array, how long is it?
  • Thanks Edvin for your amazing support on this issue,
    I managed to solve this issue by using two dimensional array to save my devices. Although I do not understand why it did not work with the above code. However the issue has been resolved.
