Hard fault in ipc_trace_handle (proprietary Nordic library)
My application just hit the following fault randomly:
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
***** Hardware exception *****
Current thread ID = 0x20028dac (sysworkq)
Faulting instruction address = 0x319fe
Fatal fault in ISR! Spinning...
I tracked back in the map file and that is inside the Nordic NRFX library in ipc_trace_handle, so I have no source code to help me decode what I might be doing wrong.
Specifically in my linking, ipc_trace_handle starts at 0x3180c, so that is 0x1f2 bytes after the entry.  Here's a snippet for reference from the listing file:
   319f8:	b109      	cbz	r1, 319fe <ipc_trace_handle+0x1f2>
   319fa:	2100      	movs	r1, #0
   319fc:	7011      	strb	r1, [r2, #0]
   319fe:	68a5      	ldr	r5, [r4, #8]
   31a00:	2d00      	cmp	r5, #0
   31a02:	d039      	beq.n	31a78 <ipc_trace_handle+0x26c>
   31a04:	f04f 0c00 	mov.w	ip, #0
Please, if someone from Nordic who has the source code for NRFX could help me understand what is being referenced in that area and give me a hint what might be wrong, I would really appreciate it.
