MQTT_Connect -45 when connecting to AWS
I am trying to write a simple application to publish messages over MQTT to an AWS IoT-Core broker. I started with the MQTT_Simple and AWS_FOTA examples. When trying to do the mqtt_connect I am getting a -45 error code.  My code is as follows:
 * Copyright (c) 2019 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <stdio.h>
#include <uart.h>
#include <string.h>
#include <at_cmd.h>
#include <lte_lc.h>
#include <net/mqtt.h>
#include <net/socket.h>
//#include <net/aws_fota.h>
#include <dfu/mcuboot.h>
#include <misc/reboot.h>
#if defined(CONFIG_BSD_LIBRARY)
#include "nrf_inbuilt_key.h"
#include "certificates.h"
#if !defined(CONFIG_CLOUD_CLIENT_ID)
#define IMEI_LEN 15
#define CLIENT_ID_LEN (IMEI_LEN + 4)
#else
#define CLIENT_ID_LEN (sizeof(CONFIG_CLOUD_CLIENT_ID) - 1)
static u8_t client_id_buf[CLIENT_ID_LEN+1];
/* The mqtt client struct */
static struct mqtt_client client;
/* Buffers for MQTT client. */
static u8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* MQTT Broker details. */
static struct sockaddr_storage broker_storage;
/* File descriptor */
static struct pollfd fds;
/* Set to true when application should teardown and reboot */
static bool do_reboot;
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
	printk("bsdlib recoverable error: %u\n", err);
/**@brief Irrecoverable BSD library error. */
void bsd_irrecoverable_error_handler(uint32_t err)
	printk("bsdlib irrecoverable error: %u\n", err);
	__ASSERT_NO_MSG(false);
#endif /* defined(CONFIG_BSD_LIBRARY) */
/**@brief Function to print strings without null-termination. */
static void data_print(u8_t *prefix, u8_t *data, int len)
	char buf[len + 1];
	memcpy(buf, data, len);
	buf[len] = 0;
	printk("%s%s\n", prefix, buf);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c,
			       u8_t *write_buf,
			       size_t length)
	u8_t *buf = write_buf;
	u8_t *end = buf + length;
	if (length > sizeof(payload_buf)) {
		return -EMSGSIZE;
	while (buf < end) {
		int ret = mqtt_read_publish_payload_blocking(c, buf, end - buf);
		if (ret < 0) {
			return ret;
		} else if (ret == 0) {
			return -EIO;
		buf += ret;
	return 0;
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
	float data)
	struct mqtt_publish_param param;
        char output[50];
        snprintf(output, 50, "%f", data);
	param.message.topic.qos = qos;
	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
	param.message.payload.data = output;
	param.message.payload.len = 50;
	param.message_id = sys_rand32_get();
	param.dup_flag = 0;
	param.retain_flag = 0;
	data_print("Publishing: ", output, 50);
	printk("to topic: %s len: %u\n",
		CONFIG_MQTT_PUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
	return mqtt_publish(c, &param);
/**@brief MQTT client event handler */
void mqtt_evt_handler(struct mqtt_client * const c,
		      const struct mqtt_evt *evt)
	int err;
	switch (evt->type) {
	case MQTT_EVT_CONNACK:
		if (evt->result != 0) {
			printk("MQTT connect failed %d\n", evt->result);
		printk("[%s:%d] MQTT client connected!\n", __func__, __LINE__);
                printk("MQTT Host: %s", CONFIG_MQTT_BROKER_HOSTNAME);
		if (err) {
			printk("Unable to initialize AWS jobs upon "
			       "connection\n");
			err = mqtt_disconnect(c);
			if (err) {
				printk("Could not disconnect: %d\n", err);
	case MQTT_EVT_DISCONNECT:
		printk("[%s:%d] MQTT client disconnected %d\n", __func__,
		       __LINE__, evt->result);
	case MQTT_EVT_PUBLISH: {
		const struct mqtt_publish_param *p = &evt->param.publish;
		printk("[%s:%d] MQTT PUBLISH result=%d len=%d\n", __func__,
		       __LINE__, evt->result, p->message.payload.len);
		err = publish_get_payload(c,
					  payload_buf,
		if (err) {
			printk("mqtt_read_publish_payload: Failed! %d\n", err);
			printk("Disconnecting MQTT client...\n");
			if (err) {
		if (p->message.topic.qos == MQTT_QOS_1_AT_LEAST_ONCE) {
			const struct mqtt_puback_param ack = {
				.message_id = p->message_id
			/* Send acknowledgment. */
			err = mqtt_publish_qos1_ack(c, &ack);
			if (err) {
				printk("unable to ack\n");
		data_print("Received: ", payload_buf, p->message.payload.len);
	case MQTT_EVT_PUBACK:
			printk("MQTT PUBACK error %d\n", evt->result);
		printk("[%s:%d] PUBACK packet id: %u\n", __func__, __LINE__,
		       evt->param.puback.message_id);
	case MQTT_EVT_SUBACK:
			printk("MQTT SUBACK error %d\n", evt->result);
		printk("[%s:%d] SUBACK packet id: %u\n", __func__, __LINE__,
		       evt->param.suback.message_id);
		printk("[%s:%d] default: %d\n", __func__, __LINE__,
		       evt->type);
/**@brief Resolves the configured hostname and
 * initializes the MQTT broker structure
static void broker_init(const char *hostname)
	int err;
	struct addrinfo *result;
	struct addrinfo *addr;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM
	err = getaddrinfo(hostname, NULL, &hints, &result);
	if (err) {
		printk("ERROR: getaddrinfo failed %d\n", err);
		return;
	addr = result;
	err = -ENOENT;
	while (addr != NULL) {
		/* IPv4 Address. */
		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
			struct sockaddr_in *broker =
				((struct sockaddr_in *)&broker_storage);
			broker->sin_addr.s_addr =
				((struct sockaddr_in *)addr->ai_addr)
				->sin_addr.s_addr;
			broker->sin_family = AF_INET;
			broker->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
			printk("IPv4 Address 0x%08x\n", broker->sin_addr.s_addr);
		} else if (addr->ai_addrlen == sizeof(struct sockaddr_in6)) {
			/* IPv6 Address. */
			struct sockaddr_in6 *broker =
				((struct sockaddr_in6 *)&broker_storage);
			memcpy(broker->sin6_addr.s6_addr,
				((struct sockaddr_in6 *)addr->ai_addr)
				sizeof(struct in6_addr));
			broker->sin6_family = AF_INET6;
			broker->sin6_port = htons(CONFIG_MQTT_BROKER_PORT);
			printk("IPv6 Address");
		} else {
			printk("error: ai_addrlen = %u should be %u or %u\n",
				(unsigned int)addr->ai_addrlen,
				(unsigned int)sizeof(struct sockaddr_in),
				(unsigned int)sizeof(struct sockaddr_in6));
		addr = addr->ai_next;
	/* Free the address. */
	freeaddrinfo(result);
static int provision_certificates(void)
		int err;
		/* Delete certificates */
		nrf_sec_tag_t sec_tag = CONFIG_CLOUD_CERT_SEC_TAG;
		for (nrf_key_mgnt_cred_type_t type = 0; type < 3; type++) {
			err = nrf_inbuilt_key_delete(sec_tag, type);
			printk("nrf_inbuilt_key_delete(%u, %d) => result=%d\n",
				sec_tag, type, err);
		/* Provision CA Certificate. */
		err = nrf_inbuilt_key_write(CONFIG_CLOUD_CERT_SEC_TAG,
					NRF_KEY_MGMT_CRED_TYPE_CA_CHAIN,
					CLOUD_CA_CERTIFICATE,
					strlen(CLOUD_CA_CERTIFICATE));
		printk("nrf_inbuilt_key_write => result=%d\n", err);
		if (err) {
			printk("CLOUD_CA_CERTIFICATE err: %d", err);
			return err;
		/* Provision Private Certificate. */
			NRF_KEY_MGMT_CRED_TYPE_PRIVATE_CERT,
			CLOUD_CLIENT_PRIVATE_KEY,
			strlen(CLOUD_CLIENT_PRIVATE_KEY));
		if (err) {
			printk("NRF_CLOUD_CLIENT_PRIVATE_KEY err: %d", err);
			return err;
		/* Provision Public Certificate. */
			NRF_KEY_MGMT_CRED_TYPE_PUBLIC_CERT,
				 CLOUD_CLIENT_PUBLIC_CERTIFICATE,
				 strlen(CLOUD_CLIENT_PUBLIC_CERTIFICATE));
		if (err) {
			printk("CLOUD_CLIENT_PUBLIC_CERTIFICATE err: %d",
				err);
			return err;
	return 0;
static int client_id_get(char *id_buf)
	enum at_cmd_state at_state;
	char imei_buf[IMEI_LEN + 5];
	int err = at_cmd_write("AT+CGSN", imei_buf, (IMEI_LEN + 5), &at_state);
	if (err) {
		printk("Error when trying to do at_cmd_write: %d, at_state: %d", err, at_state);
	snprintf(id_buf, CLIENT_ID_LEN + 1, "nrf-%s", imei_buf);
#else
	memcpy(id_buf, CONFIG_CLOUD_CLIENT_ID, CLIENT_ID_LEN + 1);
#endif /* !defined(NRF_CLOUD_CLIENT_ID) */
	return 0;
/**@brief Initialize the MQTT client structure */
static int client_init(struct mqtt_client *client, char *hostname)
	mqtt_client_init(client);
	broker_init(hostname);
	int ret = client_id_get(client_id_buf);
	printk("client_id: %s\n", client_id_buf);
	if (ret != 0) {
		return ret;
	/* MQTT client configuration */
	client->broker = &broker_storage;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = client_id_buf;
	client->client_id.size = strlen(client_id_buf);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	client->transport.type = MQTT_TRANSPORT_SECURE;
	static sec_tag_t sec_tag_list[] = {CONFIG_CLOUD_CERT_SEC_TAG};
	struct mqtt_sec_config *tls_config = &(client->transport).tls.config;
//	tls_config->peer_verify = 2;
	tls_config->cipher_list = NULL;
	tls_config->cipher_count = 0;
	tls_config->sec_tag_count = ARRAY_SIZE(sec_tag_list);
	tls_config->sec_tag_list = sec_tag_list;
//	tls_config->hostname = hostname;
        tls_config->peer_verify = 0;
//	tls_config->cipher_list = NULL;
//	tls_config->cipher_count = 0;
//	tls_config->sec_tag_count = 0;
//	tls_config->sec_tag_list = NULL;
	tls_config->hostname = NULL;
	return 0;
/**@brief Initialize the file descriptor structure used by poll. */
static int fds_init(struct mqtt_client *c)
	fds.fd = c->transport.tls.sock;
	fds.events = POLLIN;
	return 0;
/**@brief Configures modem to provide LTE link.
 * Blocks until link is successfully established.
static void modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
		/* Do nothing, modem is already turned on
		 * and connected.
	} else {
		int err;
		printk("LTE Link Connecting ...\n");
		err = lte_lc_init_and_connect();
		__ASSERT(err == 0, "LTE link could not be established.");
		printk("LTE Link Connected!\n");
//static void aws_fota_cb_handler(enum aws_fota_evt_id evt)
//	switch (evt) {
//	case AWS_FOTA_EVT_DONE:
//		printk("AWS_FOTA_EVT_DONE, rebooting to apply update.\n");
//		do_reboot = true;
//		break;
//	case AWS_FOTA_EVT_ERROR:
//		printk("AWS_FOTA_EVT_ERROR\n");
//		break;
void my_timer_handler(struct k_timer *dummy) {
          int err = data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE, 2.0);
          if(err != 0) {
            printk("ERROR: data_publish %d\n", err);
K_TIMER_DEFINE(my_timer, my_timer_handler, NULL);
//struct k_timer my_timer;
void rerun_timer() {
  k_timer_start(&my_timer, K_SECONDS(10), K_SECONDS(10));
void main(void)
	int err;
	printk("The MQTT AWS Jobs FOTA Sample\n");
	provision_certificates();
	modem_configure();
	client_init(&client, CONFIG_MQTT_BROKER_HOSTNAME);
//	err = aws_fota_init(&client, CONFIG_APP_VERSION, aws_fota_cb_handler);
//	if (err != 0) {
//		printk("ERROR: aws_fota_init %d\n", err);
//		return;
	err = mqtt_connect(&client);
	if (err != 0) {
		printk("ERROR: mqtt_connect %d\n", err);
		return;
	err = fds_init(&client);
	if (err != 0) {
		printk("ERROR: fds_init %d\n", err);
		return;
	/* All initializations were successful mark image as working so that we
	 * will not revert upon reboot. */
//	boot_write_img_confirmed();
       if(err != 0) {
	while (1) {
		err = poll(&fds, 1, K_SECONDS(CONFIG_MQTT_KEEPALIVE));
		if (err < 0) {
			printk("ERROR: poll %d\n", errno);
		err = mqtt_live(&client);
		if (err != 0) {
			printk("ERROR: mqtt_live %d\n", err);
		if ((fds.revents & POLLIN) == POLLIN) {
			err = mqtt_input(&client);
			if (err != 0) {
				printk("ERROR: mqtt_input %d\n", err);
		if ((fds.revents & POLLERR) == POLLERR) {
			printk("POLLERR\n");
		if ((fds.revents & POLLNVAL) == POLLNVAL) {
			printk("POLLNVAL\n");
		if (do_reboot) {
			/* Teardown */
			mqtt_disconnect(&client);
			sys_reboot(0);
	err = mqtt_disconnect(&client);
	if (err) {
		printk("Could not disconnect MQTT client. Error: %d\n", err);
  • hi dyres,
    1.
    what is client id ? it generating by self ,?  bind with Policies
    2.
    certificates.h
    it is PEM formatted
  • Hi.
    1. When you are using the asset_tracker sample application, then the device generates its own client ID (nrf-<IMEI>). You can override this behavior by defining  NRF_CLOUD_CLINET_ID.
    If you are not using the nrf_cloud library, you have to define the client ID yourself. When using a cloud service, the device ID usually has to correspond to the device ID defined in the cloud.
    2. Yes, the certificates in certificates.h is PEM formatted, e.g.:
    #define NRF_CLOUD_CLIENT_PRIVATE_KEY \
    	"-----BEGIN RSA PRIVATE KEY-----\n" \
    	"NRF_CLOUD_CLIENT_PRIVATE_KEY\n" \
    	"-----END RSA PRIVATE KEY-----\n"
    #define NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE \
    	"-----BEGIN CERTIFICATE-----\n" \
    	"NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE\n" \
    	"-----END CERTIFICATE-----\n"
    #define NRF_CLOUD_CA_CERTIFICATE \
    	"NRF_CLOUD_CA_CERTIFICATE\n" \
    Didrik
  • Hi, I think the answer of is correct.
    Just to make sure the certificates are insert correctly in certificates.h.
    In addition, there are 3 certificates you need to obtain: Client certificate, client private key, and cloud certificate.
    Good luck.
