Time out error while production test using DTM
I am testing 9 channels for PER (1,2,3,21,22,23,37,38,39). During testing the last 3 channels I always get a single time out error in response to LE_TEST_END. I also get much higher PER for higher channels (not sure if these 2 problems are related). Anybody with a similar experience? I am using nRF51 dev kit.
Thanks
Jerry
  • Hi Håkon, thanks for your reply.
    I use LE_TEST_END for each channel, the power for the dev kit is not cycled during testing.
    I do not have another dev kit to try. It ran overnight with 1400 cycles and 4 failures so that's not bad, but still.
  • Do you have a nRF52 kit for instance? It would be interesting to see if this issue still occurs on other devices as well.
    Could be a problem with the UART handling, where the firmware gets a framing error or similar. The default behavior for the nRF dtm firmware is to assert (softreset) if this happens. Have you tried with a different USB-UART bridge?
    Håkon
    We do not have any other hardware. We're a system integration house, we only buy what we need to complete the project, no spares.
    I think my communication is ok. I do get occasional timeouts on the DUT side, but I do not know what firmware they are running.
    Here's a rough sketch of what our system looks like, hopefully, this will give you a better idea.
  • Looking through the code, there is a theoretical chance that this is related to receiving a framing error on the nRF-side, and if you are running based on the python scripts in nAN-034, these will not retry commands by default. However, if this was the case, the result should be a timeout on the command itself, not a high packet error.
    Are these issues only observed when testing against one specific DUT, or is this something that you have seen on other products as well?
    Håkon
  • Thanks Håkon for your response.
    All product samples exhibit this behavior, I have 10 samples.
    Could please make some comment about timing for this test? Do I need to wait between switching channels? I found that having 300-500 ms there helps. There was also another delay absolutely needed to make it work. Here's where I inserted it:
    - Start transmitting on the requested channel (i.e dev kit)
    - Receive packets for 100 ms (DUT)
    - Wait 0.5 sec
    - Stop Transmitting on the requested channel (dev kit)
    Without this 0.5 second delay, it would not work. We'd be getting exceptions, meaning no response to LE_TEST_END command.
    If I increase the receiving window to 1 s (from 100 ms), this 0.5 delay is not necessary.
    Is there an explanation for it?
