Why is current consumption unstable in k_cpu_idle() after GPIO interrupt?
Current consumption during  k_cpu_idle() after GPIO interrupt does not take the same value. Why does this happen? Any idea? Thank you for reading this post in advance.
<Environment>
- DK v0.8.5(SB43 cut)
- modem firmware v1.0.0
- nrf; v1.0.0
- current measurement tool: multimeter
I configure GPIO11 as interrupt pin. I connect it to GND and disconnect again and again by jumper wire. After I connect it back to GND, the DK sometimes continuously consumes 25 uA and in another time 150 uA.
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_GPIO=y
CONFIG_SERIAL=n
# CONFIG_SERIAL=n in spm program
CONFIG_LOG=n
CONFIG_AT_HOST_LIBRARY=n
CONFIG_REBOOT=y
#include <zephyr.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <gpio.h>
#include <device.h>
#define GPIO_IN_INT GPIO_IN_PIN11_Pos
struct device *gpio_controller;
struct gpio_callback gpio_cb;
bool is_interrupted;
void gpio_test_interrupt(struct device *gpio, struct gpio_callback *cb, u32_t pins) {
    is_interrupted = true;
u8_t init_gpio_interrupt() {
    int8_t ret;
    ret = gpio_pin_configure(gpio_controller, GPIO_IN_INT, (GPIO_DIR_IN | GPIO_INT | GPIO_INT_EDGE | GPIO_INT_ACTIVE_HIGH));
    if (ret) {
        return -1;
    gpio_init_callback(&gpio_cb, gpio_test_interrupt, BIT(GPIO_IN_INT));
    ret = gpio_add_callback(gpio_controller, &gpio_cb);
    if (ret){
        return -1;
    ret =  gpio_pin_enable_callback(gpio_controller, GPIO_IN_INT);
    if (ret){
        return -1;
    return 0;
void main(void)
    gpio_controller = device_get_binding("GPIO_0");
    if (!gpio_controller) {
        sys_reboot();
    if (init_gpio_interrupt() != 0) {
        sys_reboot();
    while (1) {
        k_cpu_idle();
