Inability to sleep the nRF52832. Number of possible buttons in using the BSP module?
We have a custom device that has 15 buttons. Presently we use the following code to initialize and use the button interrupts. I am using a __WFE(); to wait for the next event (i.e. a button press) however when I press two specific buttons (by design) together it brings the device partially into sleep_mode. This method works sufficient for detecting the button presses, but in attempting to put the device into a lower power mode it seems that some sort of interrupt is triggering the device to come right out of the low power mode or not completely go into low power mode. The device does come out of the "low power (5mA)" mode but completes a reset in the process. The current draw drops from about 9 mA (with I2C device) down to 5 mA (likely, just without I2C device), but never drops to uA levels. My thought is that another interrupt triggers the device to come right out while keeping the I2C device off, but I'm not sure which one would do that.
* The following contain the interrupt handlers for all button presses
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
   buttons_pressed = true;
   chirp_led(BLUE_LED);
   ret_code_t err_code;
   if(power_off_mode)
            //Disable power-down button to prevent System-off wakeup
            for(int i = 0; i < NUM_BUTTONS; i++) {
                    nrf_drv_gpiote_in_uninit(buttons[i]);
                    nrf_drv_gpiote_in_event_disable(buttons[i]);
            //Configure wake-up button
                nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);    //Configure to generate interrupt and wakeup on pin signal high.
                in_config.pull = NRF_GPIO_PIN_PULLDOWN;                                         //Configure pulldown for input pin to prevent it from floating.
                err_code = nrf_drv_gpiote_in_init(buttons[i], &in_config, in_pin_handler);      //Initialize the wake-up pin
                APP_ERROR_CHECK(err_code);                                                      //Check error code returned
                nrf_drv_gpiote_in_event_enable(buttons[i], true);                               //Enable event and interrupt for the wakeup pin
          //Enter System-off
          NRF_POWER->SYSTEMOFF = 1;
//@brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
// and configures GPIOTE to give an interrupt on pin change.
static void gpio_init(void)
    nrf_gpio_cfg_output(BLUE_LED);
    nrf_gpio_cfg_output(RED_LED);
    if(nrf_drv_gpiote_is_init() == false)
Searching around I found a handful of explanations of using the BSP module along with a sleep_mode_enter() based on a button press. However, all of the documentation only shows 8 buttons available in the BSP module. Is there the ability to handle more buttons than that, 15 or more? If so what steps would need to be taken to modify the included files to allow for this? Do I need to modify the pca10040.h, bsp.h/c, boards.h/c, others? How so?
Thanks for the help!
    No, only unused pins should be set as input with buffer disconnected.
    BendaEng said:
    I've read that in debug mode the device will not be able to properly sleep. I built in release mode, disconnected my debugger, and measured the power consumption during "normal operation".
    Yes, if the nRF is in debug mode then it will not go into system OFF but emulate it, which will not give a current consumption similar to the what is expected in sleep. A complete power cycle should set the nRF to normal mode. Do you have a DK available? Could you try using the external debugger on the DK and program the custom board with the Power Profiling Application from the SDK? What is the current consumption that you're measuring? The result from this would highlight what causes this issue, i.e a problem with the design of the custom board or the application that you're using.  Could you also describe how you measure the current consumption? Are you using the power profiler kit?
    The application also shows how to implement sleep mode properly with BLE.
    regards
    Jared
  • Hi Jared,
    Thanks for getting back to me. Ok, so if I'm understanding correctly my pins are setup properly?
    I regards to the debug mode emulating sleep, I have power cycled my device with the same results returning upon power up. I am using a BL652 DK, which is not the same as the Nordic, but I program and debug externally on a custom board in the following way (I believe no different than the Nordic DK). To answer your follow-up question, no I am not using a power profiler kit, rather a Tinkerforge Voltage/Current Bricklet. My custom device is powered with a battery and measured through this current shunt in-line with the power connection.
    Power Measurement Setup
    Upon disconnecting my SWDIO and SWCLK from the custom board and power cycling my device after programming it I am using my enter sleep mode through button press. This consistently results in 5mA of draw.
    In my previous reply I asked about the bootloader (as my application has a Buttonless DFU integration for OTA upgrading the firmware). Does the bootloader have any effect on forcing the I/O to remain on? I.e. the SWDIO and SWCLK or other peripheral? If so, what is the recommended bootloader for a Buttonless DFU application to retain low power capabilities?
    Thanks!
    The boot loader shouldn't have any effect on keeping the pins on as it will jump directly to the app if it's valid. It seems from the documentation that the TinkerForge does not have a high enough resolution to measure the sleep current, as the current during sleep is in µA:
    From description of features:
    • "1mW, 1mV, 1mA resolution over the whole range"
    Do you have any other available device that can measure at µA range with a high enough resolution?
    Best regards
    Jared
    To answer your question, no I do not. However, basically what my equipment is telling me is the presence or absence of sleep (if 5 mA = ON, if 0mA = OFF, not taking into account any sort of accuracy).
    On a different note, I have now been able to sleep my device. The following was the changes that I made to make the device sleep. Basically, I didn't let all of the 15 pins be a wakeup. Only two of them. I could never identify it, but I think one of those other pins (that are now not enabled for wakeup), was causing the wake-up. Maybe someone can shed light on this, but the pin cnf registers all seemed fine. Part of the issue could have been that my shutdown was contained in the input pin handler. Now it's in a separate function.
    Anyway here's my changes.
    OLD Non-Working
       if(power_off_mode)
              //Enter System-off
    NEW Working Code
    void device_power_off(void)
      ret_code_t err_code = 0;
     if(power_off_mode)
                for(int i = 0; i < 5; i++)
                  chirp_led(RED_LED);
                  nrf_delay_ms(100);
                err_code = nrf_drv_gpiote_in_init(buttons[14], &in_config, in_pin_handler);      //Initialize the wake-up pin on FCN Button
                nrf_drv_gpiote_in_event_enable(buttons[14], true);                               //Enable event and interrupt for the FCN Button Wakeup Pin
                err_code = nrf_drv_gpiote_in_init(buttons[12], &in_config, in_pin_handler);      //Initialize the wake-up pin on BT Button
                nrf_drv_gpiote_in_event_enable(buttons[12], true);                               //Enable event and interrupt for the BT Button wakeup pin
              //Enter System-off
              power_off_mode = false;
              NRF_POWER -> SYSTEMOFF = 1;
              //sd_power_system_off();
    Thanks for the suggestions to get me here @Jared. Much appreciated!
