Dear Nordic Support,
I follow this SAADC example to calibrate the SAADC every SAADC_CALIBRATION_INTERVAL.
However, whenever the function nrfx_saadc_abort() is called, it always asserts at these lines of code:
// Wait for ADC being stopped.
bool result;
NRFX_WAIT_FOR((m_cb.adc_state == NRF_SAADC_STATE_IDLE), HW_TIMEOUT, 0, result);
NRFX_ASSERT(result);
I tried debugging and I found that the m_cb.adc_state only in NRF_SAADC_STATE_IDLE after the initialization and then it is always busy.
I have 2 SAADC channels they are working with the PPI and TIMER. Every 10ms, the TIMER triggers the SAADC event. I am using nRF5_SDK_15.3.0_59ac345 with my nRF52840-DK.
For more details, I attached my code in following file: main.c, peripherals.h and peripherals.c.
<error> app: ERROR 3735928559 [Unknown error code] at D:\Projects\torquevault_torquedevicesfw\torque_wrench\nRF5_SDK_15.3.0_59ac345\modules\nrfx\drivers\src\nrfx_saadc.c:594 PC at: 0x0002647F <error> app: End of error report
Thank you and best regards,
Duy
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_hts_main main.c
* @ingroup ble_sdk_app_hts
* @brief Health Thermometer Service Sample Application main file.
* This file contains the source code for a sample application using the Health Thermometer service
* It also includes the sample code for Battery and Device Information services.
* This application uses the @ref srvlib_conn_params module.
#include "main.h"
#define MIN_BATTERY_LEVEL 81 /**< Minimum battery level as returned by the simulated measurement function. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum battery level as returned by the simulated measurement function. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Value by which the battery level is incremented/decremented for each call to the simulated measurement function. */
#define TEMP_TYPE_AS_CHARACTERISTIC 0 /**< Determines if temperature type is given as characteristic (1) or as a field of measurement (0). */
#define MIN_CELCIUS_DEGREES 3688 /**< Minimum temperature in celcius for use in the simulated measurement function (multiplied by 100 to avoid floating point arithmetic). */
#define MAX_CELCIUS_DEGRESS 3972 /**< Maximum temperature in celcius for use in the simulated measurement function (multiplied by 100 to avoid floating point arithmetic). */
#define CELCIUS_DEGREES_INCREMENT 36 /**< Value by which temperature is incremented/decremented for each call to the simulated measurement function (multiplied by 100 to avoid floating point arithmetic). */
BLE_BAS_DEF(m_bas); /**< Structure used to identify the battery service. */
BLE_HTS_DEF(m_hts); /**< Structure used to identify the health thermometer service. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_hts_meas_ind_conf_pending = false; /**< Flag to keep track of when an indication confirmation is pending. */
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t m_temp_celcius_sim_cfg; /**< Temperature simulator configuration. */
static sensorsim_state_t m_temp_celcius_sim_state; /**< Temperature simulator state. */
static bool m_device_connected = false;
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_HEALTH_THERMOMETER_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static bool m_device_first_start = true;
static void advertising_start(bool erase_bonds);
static void temperature_measurement_send(void);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
bool is_indication_enabled;
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
case PM_EVT_CONN_SEC_SUCCEEDED:
// Send a single temperature measurement if indication is enabled.
// NOTE: For this to work, make sure ble_hts_on_ble_evt() is called before
// pm_evt_handler() in ble_evt_dispatch().
APP_ERROR_CHECK(ble_hts_is_indication_enabled(&m_hts, &is_indication_enabled));
if (is_indication_enabled)
temperature_measurement_send();
advertising_start(false);
/**@brief Function for performing a battery measurement, and update the Battery Level characteristic in the Battery Service.
static void battery_level_update(void)
ret_code_t err_code;
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
uint16_t counter;
static void saadc_acquisition_timeout_handler(nrf_timer_event_t event_type, void *p_context)
switch (event_type)
case NRF_TIMER_EVENT_COMPARE0:
counter++;
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
default: break;
uint16_t counter1;
static void battery_level_meas_timeout_handler(nrf_timer_event_t event_type, void *p_context)
switch (event_type)
counter1++;
battery_level_update();
default: break;
static void saadc_callback(nrf_drv_saadc_evt_t const *p_event)
uint8_t idx;
switch (p_event->type)
case NRF_DRV_SAADC_EVT_DONE:
/* Evaluate if offset calibration should be performed. */
/* Configure the SAADC_CALIBRATION_INTERVAL constant to change the calibration frequency. */
if (0 == (m_saadc_evt_counter % SAADC_CALIBRATION_INTERVAL))
// if (true == m_device_first_start)
// m_device_first_start = false;
// else
/* Abort all ongoing conversions. Calibration cannot be run if SAADC is busy. */
nrf_drv_saadc_abort();
/* Set flag to trigger calibration in main context when SAADC is stopped. */
m_saadc_calibrate = true;
if (false == m_saadc_calibrate)
APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, RAW_ADC_BUFF_SIZE));
NRF_LOG_INFO("ADC channel %d event number: %d",p_event->data.limit.channel, (int)m_saadc_evt_counter);
for (idx = 0; idx < RAW_ADC_BUFF_SIZE; idx++)
NRF_LOG_INFO("%d", p_event->data.done.p_buffer[idx]);
m_saadc_evt_counter++;
case NRF_DRV_SAADC_EVT_CALIBRATEDONE:
/* Set buffer so the SAADC can write to it again.
Need to setup both buffers, as they were both removed
with the call to nrf_drv_saadc_abort before calibration. */
saadc_set_buffer();
default: break;
/**@brief Function for populating simulated health thermometer measurement.
static void hts_sim_measurement(ble_hts_meas_t * p_meas)
static ble_date_time_t time_stamp = { 2012, 12, 5, 11, 50, 0 };
uint32_t celciusX100;
p_meas->temp_in_fahr_units = false;
p_meas->time_stamp_present = true;
p_meas->temp_type_present = (TEMP_TYPE_AS_CHARACTERISTIC ? false : true);
celciusX100 = sensorsim_measure(&m_temp_celcius_sim_state, &m_temp_celcius_sim_cfg);
p_meas->temp_in_celcius.exponent = -2;
p_meas->temp_in_celcius.mantissa = celciusX100;
p_meas->temp_in_fahr.exponent = -2;
p_meas->temp_in_fahr.mantissa = (32 * 100) + ((celciusX100 * 9) / 5);
p_meas->time_stamp = time_stamp;
p_meas->temp_type = BLE_HTS_TEMP_TYPE_FINGER;
// update simulated time stamp
time_stamp.seconds += 27;
if (time_stamp.seconds > 59)
time_stamp.seconds -= 60;
time_stamp.minutes++;
if (time_stamp.minutes > 59)
time_stamp.minutes = 0;
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
APP_ERROR_CHECK(sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)));
APP_ERROR_CHECK(sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_THERMOMETER));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
APP_ERROR_CHECK(sd_ble_gap_ppcp_set(&gap_conn_params));
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
APP_ERROR_CHECK(nrf_ble_gatt_init(&m_gatt, NULL));
/**@brief Function for simulating and sending one Temperature Measurement.
ble_hts_meas_t simulated_meas;
if (!m_hts_meas_ind_conf_pending)
hts_sim_measurement(&simulated_meas);
err_code = ble_hts_measurement_send(&m_hts, &simulated_meas);
switch (err_code)
case NRF_SUCCESS:
// Measurement was successfully sent, wait for confirmation.
m_hts_meas_ind_conf_pending = true;
case NRF_ERROR_INVALID_STATE:
// Ignore error.
/**@brief Function for handling the Health Thermometer Service events.
* @details This function will be called for all Health Thermometer Service events which are passed
* to the application.
* @param[in] p_hts Health Thermometer Service structure.
* @param[in] p_evt Event received from the Health Thermometer Service.
static void on_hts_evt(ble_hts_t * p_hts, ble_hts_evt_t * p_evt)
switch (p_evt->evt_type)
case BLE_HTS_EVT_INDICATION_ENABLED:
// Indication has been enabled, send a single temperature measurement
case BLE_HTS_EVT_INDICATION_CONFIRMED:
// No implementation needed.
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
* @details Initialize the Health Thermometer, Battery and Device Information services.
ble_hts_init_t hts_init;
ble_bas_init_t bas_init;
ble_dis_init_t dis_init;
ble_dis_sys_id_t sys_id;
APP_ERROR_CHECK(nrf_ble_qwr_init(&m_qwr, &qwr_init));
// Initialize Health Thermometer Service
memset(&hts_init, 0, sizeof(hts_init));
hts_init.evt_handler = on_hts_evt;
hts_init.temp_type_as_characteristic = TEMP_TYPE_AS_CHARACTERISTIC;
hts_init.temp_type = BLE_HTS_TEMP_TYPE_BODY;
// Here the sec level for the Health Thermometer Service can be changed/increased.
hts_init.ht_meas_cccd_wr_sec = SEC_JUST_WORKS;
hts_init.ht_type_rd_sec = SEC_OPEN;
APP_ERROR_CHECK(ble_hts_init(&m_hts, &hts_init));
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
bas_init.bl_rd_sec = SEC_OPEN;
bas_init.bl_cccd_wr_sec = SEC_OPEN;
bas_init.bl_report_rd_sec = SEC_OPEN;
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
APP_ERROR_CHECK(ble_bas_init(&m_bas, &bas_init));
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
ble_srv_ascii_to_utf8(&dis_init.model_num_str, MODEL_NUM);
sys_id.manufacturer_id = MANUFACTURER_ID;
sys_id.organizationally_unique_id = ORG_UNIQUE_ID;
dis_init.p_sys_id = &sys_id;
dis_init.dis_char_rd_sec = SEC_OPEN;
APP_ERROR_CHECK(ble_dis_init(&dis_init));
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
// Temperature is in celcius (it is multiplied by 100 to avoid floating point arithmetic).
m_temp_celcius_sim_cfg.min = MIN_CELCIUS_DEGREES;
m_temp_celcius_sim_cfg.max = MAX_CELCIUS_DEGRESS;
m_temp_celcius_sim_cfg.incr = CELCIUS_DEGREES_INCREMENT;
m_temp_celcius_sim_cfg.start_at_max = false;
sensorsim_init(&m_temp_celcius_sim_state, &m_temp_celcius_sim_cfg);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
APP_ERROR_CHECK(sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE));
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
APP_ERROR_CHECK(ble_conn_params_init(&cp_init));
APP_ERROR_CHECK(bsp_indication_set(BSP_INDICATE_IDLE));
// Prepare wakeup buttons.
APP_ERROR_CHECK(bsp_btn_ble_sleep_mode_prepare());
APP_ERROR_CHECK(sd_power_system_off());
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
APP_ERROR_CHECK(bsp_indication_set(BSP_INDICATE_ADVERTISING));
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
APP_ERROR_CHECK(bsp_indication_set(BSP_INDICATE_CONNECTED));
APP_ERROR_CHECK(nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle));
m_device_connected = true;
NRF_LOG_INFO("Disconnected.");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
APP_ERROR_CHECK(sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys));
} break;
case BLE_GATTC_EVT_TIMEOUT:
APP_ERROR_CHECK(sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION));
case BLE_GATTS_EVT_TIMEOUT:
APP_ERROR_CHECK(sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION));
APP_ERROR_CHECK(nrf_sdh_enable_request());
uint32_t ram_start = 0;
APP_ERROR_CHECK(nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start));
// Enable BLE stack.
APP_ERROR_CHECK(nrf_sdh_ble_enable(&ram_start));
* @param[in] event Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
APP_ERROR_CHECK(pm_init());
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
APP_ERROR_CHECK(pm_sec_params_set(&sec_param));
APP_ERROR_CHECK(pm_register(pm_evt_handler));
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
APP_ERROR_CHECK(pm_peers_delete());
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
APP_ERROR_CHECK(ble_advertising_init(&m_advertising, &init));
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
APP_ERROR_CHECK(bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler));
APP_ERROR_CHECK(bsp_btn_ble_init(NULL, &startup_event));
static void log_init(void)
APP_ERROR_CHECK(nrf_pwr_mgmt_init());
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
APP_ERROR_CHECK(ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST));
#define SIZE 16
#define ADDR 0x0680
#define DATA 0x28
uint8_t read_data[SIZE], write_data[SIZE];
/**@brief Function for application main entry.
bool erase_bonds;
memset(write_data, DATA, SIZE);
/* Initialize log. */
log_init();
/* Initialize oled. */
spi_init();
oled_init();
nrf_delay_ms(2000);
/* Initialize eeprom. */
twi_init();
/* Read configured memory */
EEPROM_WriteMemory(ADDR, write_data, SIZE);
nrf_delay_ms(10);
EEPROM_ReadMemory(ADDR, read_data, SIZE);
timers_init(saadc_acquisition_timeout_handler, battery_level_meas_timeout_handler);
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
/* Start execution. */
advertising_start(erase_bonds);
saadc_init(saadc_callback);
saadc_sampling_event_init();
NRF_LOG_INFO("Software started.");
/* Enter main loop. */
for (;;)
saadc_wait_calibration();
ssd1309_SetCursor(0, 0);
ssd1309_WriteString("Testing 1 2 3!", Font_7x10, White);
ssd1309_UpdateScreen();
NRF_LOG_FLUSH();
idle_state_handle();
#include "peripherals.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "TT_Config.h"
/* DEFINES */
#define SAADC_TIMER_INSTANCE 1
#define EEPROM_TWI_INSTANCE 1
#define OLED_SPI_INSTANCE 0
/* TIMER instances */
static const nrf_drv_timer_t SAADC_TIMER = NRF_DRV_TIMER_INSTANCE(SAADC_TIMER_INSTANCE); /**< ADC timer. */
static const nrf_drv_timer_t BATTERY_TIMER = NRF_DRV_TIMER_INSTANCE(2); /**< Battery timer. */
/* PPI instances */
static nrf_ppi_channel_t SAADC_TIMER_PPI_CHANNEL;
/* TWI instances */
const nrf_drv_twi_t m_eeprom_twi = NRF_DRV_TWI_INSTANCE(EEPROM_TWI_INSTANCE);
/* SPI instances */
const nrf_drv_spi_t m_oled_spi = NRF_DRV_SPI_INSTANCE(OLED_SPI_INSTANCE);
static nrf_saadc_value_t m_buffer_pool[2][RAW_ADC_BUFF_SIZE];
uint32_t m_saadc_evt_counter;
bool m_saadc_calibrate = false; /**< SAADC internal calibration trigger flag */
void saadc_set_buffer(void)
APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(m_buffer_pool[0], RAW_ADC_BUFF_SIZE));
APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(m_buffer_pool[1], RAW_ADC_BUFF_SIZE));
void saadc_init(nrf_drv_saadc_event_handler_t battery_event_handler)
nrf_saadc_channel_config_t adc_channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
nrf_saadc_channel_config_t battery_channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
APP_ERROR_CHECK(nrf_drv_saadc_init(NULL, battery_event_handler));
APP_ERROR_CHECK(nrf_drv_saadc_channel_init(0, &adc_channel_config));
APP_ERROR_CHECK(nrf_drv_saadc_channel_init(1, &battery_channel_config));
* @brief TWI initialization.
void twi_init(void)
const nrf_drv_twi_config_t twi_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = true
#if TWI_USE_INTERRUPT
APP_ERROR_CHECK(nrf_drv_twi_init(&m_eeprom_twi, &twi_config, eeprom_callback, NULL));
#else
APP_ERROR_CHECK(nrf_drv_twi_init(&m_eeprom_twi, &twi_config, NULL, NULL));
nrf_drv_twi_enable(&m_eeprom_twi);
* @brief SPI initialization.
void spi_init(void)
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = ARDUINO_10_PIN;
// spi_config.miso_pin = ARDUINO_12_PIN;
spi_config.mosi_pin = ARDUINO_11_PIN;
spi_config.sck_pin = ARDUINO_13_PIN;
#if SPI_USE_INTERRUPT
APP_ERROR_CHECK(nrf_drv_spi_init(&m_oled_spi, &spi_config, oled_spi_callback, NULL));
#else
APP_ERROR_CHECK(nrf_drv_spi_init(&m_oled_spi, &spi_config, NULL, NULL));
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
void timers_init(nrfx_timer_event_handler_t saadc_timer, nrfx_timer_event_handler_t battery_timer_handler)
/* Enable app timer */
APP_ERROR_CHECK(app_timer_init());
/* Create ADC timer */
APP_ERROR_CHECK(nrf_drv_timer_init(&SAADC_TIMER, &timer_cfg, saadc_timer));
nrf_drv_timer_extended_compare(&SAADC_TIMER, NRF_TIMER_CC_CHANNEL0, nrf_drv_timer_ms_to_ticks(&SAADC_TIMER, ADC_ACQUISITION_INTERVAL), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
/* Configure BATTERY TIMER */
APP_ERROR_CHECK(nrf_drv_timer_init(&BATTERY_TIMER, &timer_cfg, battery_timer_handler));
nrf_drv_timer_extended_compare(&BATTERY_TIMER, NRF_TIMER_CC_CHANNEL0, nrf_drv_timer_ms_to_ticks(&BATTERY_TIMER, BATTERY_LEVEL_MEAS_INTERVAL), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
uint32_t transducer_timer_compare_event_addr, battery_timer_compare_event_addr;
uint32_t saadc_sample_task_addr;
APP_ERROR_CHECK(nrf_drv_ppi_init());
nrf_drv_timer_enable(&SAADC_TIMER);
nrf_drv_timer_enable(&BATTERY_TIMER);
transducer_timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&SAADC_TIMER, NRF_TIMER_CC_CHANNEL0);
saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
/* Setup ppi channel so that timer compare event is triggering sample tasks in SAADC */
APP_ERROR_CHECK(nrf_drv_ppi_channel_alloc(&SAADC_TIMER_PPI_CHANNEL));
APP_ERROR_CHECK(nrf_drv_ppi_channel_assign(SAADC_TIMER_PPI_CHANNEL, transducer_timer_compare_event_addr, saadc_sample_task_addr));
APP_ERROR_CHECK(nrf_drv_ppi_channel_enable(SAADC_TIMER_PPI_CHANNEL));
void saadc_wait_calibration(void)
if (true == m_saadc_calibrate)
NRF_LOG_INFO("SAADC calibration starting... \r\n");
/* Trigger calibration task */
while (NRF_SUCCESS != nrf_drv_saadc_calibrate_offset())
