Is possible for the nRF52811 to measure AoA on the receiver side with nRF52832 on the transmitter side?
Thank You,
David
Thank You,
David
As I understand it, the CTE is an (unwhitened) all-ones pattern, transmitted after the CRC.
It seems to me that, if the radio hardware can be commanded to send a long enough cell, then even if it insists on adding the CRC and doing whitening, the soft device could (at some CPU cost) do this:
So if the soft device could be hacked to do this, say to advertising packets (which are constant and have a long time to be pre-processed), you'd have a software upgrade that could let chips like the nRF52832 or nRF52840 act as AoA senders with no hardware changes; and not a lot of extra crunch.
The last byte of the transmitted packet would be garbage (thus violating the standard). But if the AoA receiver is programmed to ignore it, this should just work.
Oops. The transmitter might include the extra bytes in the byte count, which would break this if it can't be overridden.
Hi Michael
It should be possible to use the STATLEN field in the PCNF1 register to add some additional bytes to the payload, independent of what is configured through the length register.
That said you also need to control the antenna selection pins which needs to be controlled very accurately, and do a lot more processing in software.
While it might be possible in the TX only case (AoD) I can more or less guarantee it won't work in receive (AoA).
Since this case was originally opened we officially unveiled the nRF52833, which is essentially a mix of the nRF52832 and the nRF52840 with support for Bluetooth 5.1 added. I would strongly suggest this device for anyone interested in AoA/AoD.
Best regards
Torbjørn
