Since Nordic SDK release v1.0.0 our nRF9160 start having issues flashing and erasing. Coincidence?
I'm using the latest release of software V1.0.0 with the nRF9160 DK and today started flashing the examples.
at_client worked fine (just tried flashing it once, but remember there was something going on there as well).
the sample application asset_tracker worked first time, I made some modifications to the code, and flashing it after, is very problematic.
See the log below.
* Erasing sectors fails.
* RAM doesn't respond in time..
I had to try several times, and also try to manually "erase all" but even that option took several tries before succeeding.
/Johan
LOG
Connecting ‘J-Link’ using ‘USB’
Connecting to target using SWD
Loaded F:/arm_segger_embedded_studio_v418_win_x64_nordic/bin/JLink_x64.dll
Firmware Version: J-Link OB-K22-NordicSemi compiled Feb 14 2019 14:03:18
DLL Version: 6.46h
Hardware Version: V1.00
Target Voltage: 3.300
Device "NRF9160" selected.
Found SW-DP with ID 0x6BA02477
Scanning AP map to find all available APs
AP[5]: Stopped AP scan as end of AP map seems to be reached
AP[0]: AHB-AP (IDR: 0x84770001)
AP[1]: AHB-AP (IDR: 0x24770011)
AP[2]: AHB-AP (IDR: 0x84770001)
AP[3]: APB-AP (IDR: 0x54770002)
AP[4]: JTAG-AP (IDR: 0x12880000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FD212. Implementer code: 0x41 (ARM)
Found Cortex-M33 r0p2, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
Security extension: implemented
Secure debug: enabled
CoreSight components:
ROMTbl[0] @ E00FF000
ROMTbl[0][0]: E000E000, CID: B105900D, PID: 000BBD21 Cortex-M33
ROMTbl[0][1]: E0001000, CID: B105900D, PID: 000BBD21 DWT
ROMTbl[0][2]: E0002000, CID: B105900D, PID: 000BBD21 FPB
ROMTbl[0][3]: E0000000, CID: B105900D, PID: 000BBD21 ITM
ROMTbl[0][5]: E0041000, CID: B105900D, PID: 002BBD21 ETM
ROMTbl[0][6]: E0042000, CID: B105900D, PID: 000BBD21 CTI
Preparing target for download
Executing Reset script TargetInterface.resetAndStop()
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Reset: CPU may have not been reset (DHCSR.S_RESET_ST never gets set).
Reset: Using fallback: Reset pin.
Reset: Reset device via reset pin
Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
Reset: Reconnecting and manually halting CPU.
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
Erasing Chip
J-Link: Flash download: Total time needed: 0.211s (Prepare: 0.032s, Compare: 0.000s, Erase: 0.172s, Program: 0.000s, Verify: 0.000s, Restore: 0.007s)
J-Link: Flash download: Total time needed: 0.213s (Prepare: 0.034s, Compare: 0.000s, Erase: 0.171s, Program: 0.000s, Verify: 0.000s, Restore: 0.007s)
Timeout while erasing sectors, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x01000003)!
Failed to erase sectors.
J-Link: Flash download: Total time needed: 20.736s (Prepare: 0.034s, Compare: 0.000s, Erase: 20.690s, Program: 0.000s, Verify: 0.000s, Restore: 0.011s)
Erasing Chip
J-Link: Flash download: Total time needed: 0.243s (Prepare: 0.047s, Compare: 0.000s, Erase: 0.172s, Program: 0.000s, Verify: 0.000s, Restore: 0.024s)
J-Link: Flash download: Total time needed: 0.245s (Prepare: 0.049s, Compare: 0.000s, Erase: 0.172s, Program: 0.000s, Verify: 0.000s, Restore: 0.024s)
J-Link: Flash download: Total time needed: 21.993s (Prepare: 0.077s, Compare: 0.000s, Erase: 21.866s, Program: 0.000s, Verify: 0.000s, Restore: 0.049s)
