Flashing nrf51422 through SWD interface
In my project, the nrf51422 chip will be hosted on a board with another CPU. I need to be able to flash the firmware through the SWD interface, controlled by the host CPU, I have already a code which is able to do it. However, I miss one some parameters that I am not able to find. Where can I find details about how to flash the memory from the SWD interface?
Once I set the CPU in debug mode, I want to program the flash memory with the updated firmware.
I have studied the ARM Debug Interface Architecture Specification I can issue the SWD commands for writing data to the flash (accessing it through the MEM-AP interface), but that won't work.
I guess I should issue some commands to prepare the CPU for the flash programming (such as unlocking the flash memory and so on) but all these things seem to be "implementation defined".
I tried to port this code which does exactly what i need, but for an EFM32 cpu (which has cortex-m0 core as well). I could make it work up to reading and writing AP & DP registers, but the flash programming part has many registers that are CPU-specific, and I cannot find the equivalent for the nRF51422.
To make it short, I need to know which sequence of SWD commands should I issue to write to and read from the flash memory.
Thanks, Vito
  • Hi There, I am stuck at the same point where I can access the AP and DP registers of the nRF51822 but I can't talk to flash. Could you please help me with the next steps? I browsed the McHck Project mentioned above but couldn't find the correct information. Could you please point it to me ?
1 2
