NRF9160 DK ADC long sample times
I'm working with the NRF9160 DK and have found the sample times for the ADC to be abnormally long. I am sampling three channels and seeing a total time for the ADC read of 80+us when I'm expecting something on the order of 15us. I have experimented with many different settings and configurations and not found any way to improve it.
Here is my configuration
#include <hal/nrf_saadc.h>
#define ADC_DEVICE_NAME DT_ADC_0_NAME
#define ADC_RESOLUTION 10
#define ADC_GAIN ADC_GAIN_1_6
#define ADC_REFERENCE ADC_REF_INTERNAL
#define ADC_ACQUISITION_TIME ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 3)
#define ADC_1ST_CHANNEL_ID 0
#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN0
#define ADC_2ND_CHANNEL_ID 2
#define ADC_2ND_CHANNEL_INPUT NRF_SAADC_INPUT_AIN2
#define ADC_3RD_CHANNEL_ID 3
#define ADC_3RD_CHANNEL_INPUT NRF_SAADC_INPUT_AIN3
static const struct adc_channel_cfg m_1st_channel_cfg = {
.gain = ADC_GAIN,
.reference = ADC_REFERENCE,
.acquisition_time = NRF_SAADC_ACQTIME_3US,
.channel_id = ADC_1ST_CHANNEL_ID,
#if defined(CONFIG_ADC_CONFIGURABLE_INPUTS)
.input_positive = ADC_1ST_CHANNEL_INPUT,
static const struct adc_channel_cfg m_2nd_channel_cfg = {
.gain = ADC_GAIN,
.channel_id = ADC_2ND_CHANNEL_ID,
.input_positive = ADC_2ND_CHANNEL_INPUT,
static const struct adc_channel_cfg m_3rd_channel_cfg = {
.gain = ADC_GAIN,
.channel_id = ADC_3RD_CHANNEL_ID,
.input_positive = ADC_3RD_CHANNEL_INPUT,
Here is the channel set up:
adc_dev = device_get_binding("ADC_0");
if (!adc_dev) {
printk("device_get_binding ADC_0 failed\n");
err = adc_channel_setup(adc_dev, &m_1st_channel_cfg);
if (err) {
printk("Error in adc setup: %d\n", err);
err = adc_channel_setup(adc_dev, &m_2nd_channel_cfg);
if (err) {
err = adc_channel_setup(adc_dev, &m_3rd_channel_cfg);
if (err) {
And here is where I'm sampling:
static int adc_sample(void)
int ret;
const struct adc_sequence_options options = {
.interval_us = 0,
.extra_samplings = 0,
const struct adc_sequence sequence = {
.channels = BIT(ADC_1ST_CHANNEL_ID) | BIT(ADC_2ND_CHANNEL_ID) | BIT(ADC_3RD_CHANNEL_ID),
.buffer = m_sample_buffer,
.buffer_size = sizeof(m_sample_buffer),
.resolution = ADC_RESOLUTION,
.oversampling = 0,
.calibrate = false,
.options = &options,
if (!adc_dev) {
return -1;
gpio_pin_write(gpio_dev, 10, 1);
ret = adc_read(adc_dev, &sequence);
gpio_pin_write(gpio_dev, 10, 0);
/*printk("ADC read err: %d\n", ret);
/* Print the AIN0 values */
/*for (int i = 0; i < BUFFER_SIZE; i++) {
float adc_voltage = 0;
adc_voltage = (float)(((float)m_sample_buffer[i] / 1023.0f) *
3600.0f);
printk("ADC raw value: %d\n", m_sample_buffer[i]);
printf("Measured voltage: %f mV\n", adc_voltage);
return ret;
  • I'm not sure why I'm getting undefined references. Here is my main.c file. Maybe there's something obvious?
     * Copyright (c) 2018 Nordic Semiconductor ASA
     * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    #include <gpio.h>
    #include <net/socket.h>
    #include <nrf9160.h>
    #include <stdio.h>
    #include <string.h>
    #include <uart.h>
    #include <adc.h>
    #include <zephyr.h>
    #include <nrfx.h>
    #include <nrfx_saadc.h>
    //#include <hal/nrf_saadc.h>
    //#include <nrfx_dppi.h>
    struct device *gpio_dev;
    #define SAADC_DEFAULT_CONFIG                                               \
        .resolution         = (nrf_saadc_resolution_t)NRFX_SAADC_CONFIG_RESOLUTION, \
        .oversample         = (nrf_saadc_oversample_t)NRFX_SAADC_CONFIG_OVERSAMPLE, \
        .interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY,                       \
        .low_power_mode     = NRFX_SAADC_CONFIG_LP_MODE                             \
    #define SAADC_DEFAULT_CHANNEL_CONFIG_SE(PIN_P) \
        .resistor_p = NRF_SAADC_RESISTOR_DISABLED,      \
        .resistor_n = NRF_SAADC_RESISTOR_DISABLED,      \
        .gain       = NRF_SAADC_GAIN1_6,                \
        .reference  = NRF_SAADC_REFERENCE_INTERNAL,     \
        .acq_time   = NRF_SAADC_ACQTIME_3US,           \
        .mode       = NRF_SAADC_MODE_SINGLE_ENDED,      \
        .burst      = NRF_SAADC_BURST_DISABLED,         \
        .pin_p      = (nrf_saadc_input_t)(PIN_P),       \
        .pin_n      = NRF_SAADC_INPUT_DISABLED          \
    nrf_saadc_channel_config_t saadc_channel_config = SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    static bool adcCalibrateDone;
    #define BUFFER_SIZE 3
    static nrf_saadc_value_t m_sample_buffer[BUFFER_SIZE];
    static void saadc_callback(nrfx_saadc_evt_t const * p_event){
        if ( p_event->type == NRFX_SAADC_EVT_DONE )
           printk("ADC raw value: %d\n", m_sample_buffer[0]);
        else if( p_event->type == NRFX_SAADC_EVT_CALIBRATEDONE )
          adcCalibrateDone = true;
    void InitAdcModule(void)
        nrfx_err_t err_code;
        nrfx_saadc_config_t drv_saadc_cfg = SAADC_DEFAULT_CONFIG;
        err_code = nrfx_saadc_init( &drv_saadc_cfg, saadc_callback );
        if(err_code != NRFX_SUCCESS){
            //Blah error
        adcCalibrateDone = false;
        err_code = nrfx_saadc_calibrate_offset( );
            //Blah error
        if( err_code == NRFX_SUCCESS )
    	err_code = 0;
    	while( !adcCalibrateDone );
    //void timer_handler(nrf_timer_event_t event_type, void * p_context)
    //void saadc_sampling_event_init(void)
    //    ret_code_t err_code;
    //    err_code = nrf_drv_ppi_init();
    //    APP_ERROR_CHECK(err_code);
    //    nrf_drv_timer_config_t timer_cfg = NRF_DRV_TIMER_DEFAULT_CONFIG;
    //    timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_32;
    //    err_code = nrf_drv_timer_init(&m_timer, &timer_cfg, timer_handler);
    //    /* setup m_timer for compare event every 400ms */
    //    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
    //    nrf_drv_timer_extended_compare(&m_timer,
    //                                   NRF_TIMER_CC_CHANNEL0,
    //                                   ticks,
    //                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
    //                                   false);
    //    nrf_drv_timer_enable(&m_timer);
    //    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
    //        NRF_TIMER_CC_CHANNEL0);
    //    uint32_t saadc_sample_task_addr   = nrf_drv_saadc_sample_task_get();
    //    /* setup ppi channel so that timer compare event is triggering sample task in SAADC */
    //    err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel);
    //    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel,
    //                                          timer_compare_event_addr,
    //                                          saadc_sample_task_addr);
    	int ret;
    				      3600.0f);
    	return ret;
    static inline void nrf_delay_us(u32_t microsec)
    	NRF_TIMER1_NS->TASKS_CLEAR = 1;
    	if (microsec < 2 )
    		return;
    	NRF_TIMER1_NS->CC[0] = (microsec << 4) - 26;
    	NRF_TIMER1_NS->PRESCALER = 0;
    	NRF_TIMER1_NS->TASKS_START = 1;
    	while (NRF_TIMER1_NS->EVENTS_COMPARE[0] == 0)
    	NRF_TIMER1_NS->EVENTS_COMPARE[0] = 0;
    	NRF_TIMER1_NS->TASKS_STOP = 1;
    	nrfx_err_t err;
            nrf_saadc_value_t  adc_value;
    	printk("nrf91 saadc sampling AIN0 (P0.13)\n");
    	printk("Example requires secure_boot to have ");
    	printk("SAADC set to non-secure!\n");
    	printk("If not; BusFault/UsageFault will be triggered\n");
    //        gpio_dev = device_get_binding(DT_GPIO_P0_DEV_NAME);
    //        if (!gpio_dev) {
    //		printk("Cannot bind gpio device");
    //		return -ENODEV;
    //        err = gpio_pin_configure(gpio_dev, 10, GPIO_DIR_OUT);//Set pin 0 to output
            //Startup the high frequency clock
            NRF_CLOCK_NS->TASKS_HFCLKSTART = 1;
    	while (NRF_CLOCK_NS->EVENTS_HFCLKSTARTED == 0);
            //Configure the timer
    //        NRF_TIMER1_NS->TASKS_CLEAR = 1;
    //	NRF_TIMER1_NS->PRESCALER = 0;//Run at 16MHz
            InitAdcModule();
    	while (1) {
    		err = nrfx_saadc_sample();
    		if (err) {
    			printk("Error in adc sampling: %d\n", err);
    		k_sleep(500);
    Maybe it's my prj.conf? I started with the asset tracker application and haven't changed the prj.conf much? Maybe I should just start over?
    CONFIG_BSD_LIBRARY=y
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_TEST_RANDOM_GENERATOR=y
    CONFIG_NETWORKING=y
    CONFIG_NET_BUF_USER_DATA_SIZE=1
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_NET_RAW_MODE=y
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    CONFIG_LOG=n
    CONFIG_LOG_DEFAULT_LEVEL=4
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    CONFIG_LTE_LINK_CONTROL=n
    CONFIG_ADC=y
    CONFIG_ADC_0=y
    CONFIG_ADC_NRFX_SAADC=y
    CONFIG_MAIN_STACK_SIZE=4096
  • Here's something interesting.
    If I use functions from hal/nrf_saadc.h, I can get it to build. But if I use functions from nrfx_saadc.h, i'll get undefined references.
    The driver does not use the nrfx_saadc.c file, but rather the API in the header file.
    To force the usage of nrfx_saadc.c, you need to do these two things.
    1. Create a Kconfig file in your application directory (ie: nrf/samples/nrf9160/adc/) that contains this:
    mainmenu "NRFX SAADC"
    config FORCE_NRFX_SAADC
    	bool "Test to force SAADC"
    	select NRFX_SAADC
        default y
    source "$ZEPHYR_BASE/Kconfig.zephyr"
    2. Since the file is guarded by a "ENABLE" macro, we need to add this to the prj.conf file:
    CONFIG_COMPILER_OPT="-DNRFX_SAADC_ENABLED=1"
    I apologize for the inconvenience regarding using the nrfx drivers directly. I have been in contact with developers to make it easier to enable these modules directly, and I can assure you that we are working on improving this.
    Håkon
