Problem :
I have two I2C devices and would like to connect them both to nRF52840 DK on different I2C pins. According to datasheet nRF52840 has two I2C pins (P1.00, P0.22) and (P0.27, 0.26). I want to connect one device on (P1.00, P0.22) and other on (P0.27, 0.26).
I am using SDK 15.3.0.
Current Code :
I have created two TWI Instance.
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(0); static const nrf_drv_twi_t m_twi2 = NRF_DRV_TWI_INSTANCE(1);
I have also initialized both of them.
* @brief TWI initialization.
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
nrf_drv_twi_enable(&m_twi);
const nrf_drv_twi_config_t twi_config2 = {
.scl = NRF_GPIO_PIN_MAP(0,22),
.sda = NRF_GPIO_PIN_MAP(1,0),
err_code = nrf_drv_twi_init(&m_twi2, &twi_config2, NULL, NULL);
NRF_LOG_INFO("%d", err_code);
nrf_drv_twi_enable(&m_twi2);
Further I try to scan for I2C devices on both TWI instances and fail to read on (P1.00, P0.22).
Things I have tried :
- Scan only one TWI instance.
Scanning on (P0.27, P0.26) works but (P1.00, P0.22) doesn't work. - Try using same NRF_DRV_TWI_INSTANCE
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(0); static const nrf_drv_twi_t m_twi2 = NRF_DRV_TWI_INSTANCE(0);
Some other questions I have :
