state chaneged flags
from SDK 3.1 for thread and zigbee  in simple coap server
after any time it go to disabled mode and no response
what means the flags? why is it disabled and do not response?
<info> app: State changed! Flags: 0x02002044 Current role: 1
Thanks!
  • Hi Fran,
    Could you send me the code for each of your nodes? I have made this case private so you can share your code. I was not able to reproduce the issue using the simple_coap_server and ncp example out of the box with our DKs. Have you done any modification to the examples?
    And can you explain more in detail what do you mean when you say the nodes stop responding? What is the state of the LED0? Are you able to connect using the CLI interface? What happens if you press reset after the node gets detached from the network? Do they reconnect or not?
    BR,
    Marjeris
