BLE DFU fails after a certain time
When I try to update the firmware by sending 20 bytes at a time, it fails after around 1.25 minutes consistently.
1. Is it because nrf52 cannot hold the ble connection beyond 1.25 minutes? I can see the led status change on the nrf52 dev board as if it has lost connection.
2. How do I increase this time in secure bootloader ble code? I'm using SDK 15.2.
3. How do I increase the NRF_SDH_BLE_GAP_DATA_LENGTH to 244? Besides making changes in the sdk_config.h are there any more changes to be made?
After I change NRF_SDH_BLE_GAP_DATA_LENGTH = 244, for the last execute command I receive 60-04-08 in response. Also for all data objects, I have to use this size command - 01 02 00 10 00 00. I was trying to make each data object of the size 3904 bytes as it is divisible by 244 (BLE packet size).
My RTT Log -
00> <info> app: Inside main
00> <debug> app: In nrf_bootloader_init
00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
00> <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
00> <debug> nrf_dfu_settings: Writing settings...
00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x20006D88, len=440 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
00> <debug> app: Enter nrf_bootloader_fw_activate
00> <info> app: No firmware to activate.
00> <debug> app: Enter nrf_dfu_app_is_valid
00> <debug> app: No valid app to boot.
00> <debug> app: DFU mode because app is not valid.
00> <info> nrf_bootloader_wdt: WDT is not enabled
00> <debug> app: in weak nrf_dfu_init_user
00> <debug> app: timer_stop (0x200057D0)
00> <debug> app: timer_activate (0x200057D0)
00> <info> app: Entering DFU mode.
00> <debug> app: Initializing transports (found: 1)
00> <debug> nrf_dfu_ble: Initializing BLE DFU transport
00> <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
00> <debug> nrf_dfu_ble: Enabling SoftDevice.
00> <debug> nrf_dfu_ble: Configuring BLE stack.
00> <debug> nrf_dfu_ble: Enabling the BLE stack.
00> <debug> nrf_dfu_ble: No advertising name found
00> <debug> nrf_dfu_ble: Using default advertising name
00> <debug> nrf_dfu_ble: Advertising...
00> <debug> nrf_dfu_ble: BLE DFU transport initialized.
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
00> <debug> app: Enter main loop
00> <debug> nrf_dfu_ble: Connected
00> <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 527, reply: 247).
00> <debug> nrf_dfu_ble: Finished handling conn sec update
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
00> <debug> app: Shutting down transports (found: 1)
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
00> <debug> nrf_dfu_ble: Buffer 0x20005D54 acquired, len 142 (244)
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
00> <debug> nrf_dfu_ble: Freeing buffer 0x20005D54
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
00> <debug> nrf_dfu_validation: PB: Init packet data len: 65
00> <info> nrf_dfu_validation: Signature required. Checking signature.
00> <info> nrf_dfu_validation:Calculating init packet hash (init packet len: 65)
00> <info> nrf_dfu_validation: Verify signature
00> <info> nrf_dfu_validation: Image verified
00> <debug> app: Enter nrf_dfu_cache_prepare()
00> <debug> app: required_size: 0xC730.
00> <debug> app: single_bank: false.
00> <debug> app: keep_app: false.
00> <debug> app: keep_softdevice: true.
00> <debug> app: SD_PRESENT: true.
00> <debug> app: Bank contents:
00> <debug> app: Bank 0 code: 0x00: Size: 0x0
00> <debug> app: Bank 1 code: 0x00: Size: 0x0
00> <debug> app: pass: 0.
00> <debug> app: cache_address: 0x26000.
00> <debug> app: cache_too_small: false.
00> <debug> app: keep_firmware: false.
00> <debug> app: delete_more: false.
00> <debug> nrf_dfu_validation: Write address set to 0x00026000
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x20006D88, len=440 bytes), queue usage: 2
00> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 3
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20006F40, len=440 bytes), queue usage: 4
00> <debug> nrf_dfu_req_handler: Writing valid init command to flash.
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
00> <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 4
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 3
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 3
00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 3
00> <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 2
00> <debug> nrf_dfu_ble: Buffer 0x20005D54 acquired, len 244 (244)
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x20005D54, len=244 bytes), queue usage: 2
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 2
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_ble: Buffer 0x20005E48 acquired, len 244 (244)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261E8, src=0x20005E48, len=244 bytes), queue usage: 2
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000260F4, pending 2
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000261E8, pending 1
00> <debug> nrf_dfu_ble: Freeing buffer 0x20005E48
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262DC, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000262DC, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263D0, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000263D0, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264C4, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000264C4, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265B8, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000265B8, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000266AC, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000266AC, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000267A0, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000267A0, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026894, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026894, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026988, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026988, pending 1
00> <debug> nrf_dfu_ble: Freeing buffer0x20005E48
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A7C, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026A7C, pending 1
00> <debug>nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B70, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026B70, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C64, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026C64, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D58, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026D58, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E4C, src=0x20005E48, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x00026E4C, pending 1
00> <error> nrf_dfu_req_handler: Write request too long
00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x3
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
00> <debug> nrf_dfu_req_handler: Offset:3904, CRC:0x5E8CC13B
00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=1 pages), queue usage: 1
00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success: addr=0x000260F4, pending 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261E8, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262DC, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263D0, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264C4, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265B8, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000266AC, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000267A0, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026894, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026988, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A7C, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B70, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C64, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D58, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E4C, src=0x20005D54, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_req_handler:Offset:3904, CRC:0x988A1704
00> <debug> nrf_dfu_ble: Buffer 0x20005F3C acquired, len 244 (244)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_ble: Freeing buffer 0x20005F3C
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261E8, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug>nrf_dfu_ble: Freeing buffer 0x20005F3C
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262DC, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263D0, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264C4, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265B8, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000266AC, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE(data)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000267A0, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026894, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026988, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A7C, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B70, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C64, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D58, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E4C, src=0x20005F3C, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_ble: Buffer0x20005F3C acquired, len 244 (244)
00> <debug> nrf_dfu_req_handler: Offset:3904, CRC:0xEEB3B9C9
00> <debug> nrf_dfu_ble: Buffer 0x20006030 acquired, len 244 (244)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_ble: Freeing buffer 0x20006030
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261E8, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262DC, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263D0, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264C4, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265B8, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000266AC, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000267A0, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026894, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026988, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A7C, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026B70, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026C64, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026D58, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026E4C, src=0x20006030, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_req_handler: Requesthandling complete. Result: 0x3
00> <debug> nrf_dfu_req_handler: Offset:3904, CRC:0x8C3EF973
00> <debug> nrf_dfu_ble: Buffer 0x20006124 acquired, len 244 (244)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: Flash write success:addr=0x00026000, pending 1
00> <debug> nrf_dfu_ble: Freeing buffer 0x20006124
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000260F4, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug>nrf_dfu_ble: Buffer 0x20006124 acquired, len 244 (244)
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000261E8, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000262DC, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000263D0, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000264C4, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000265B8, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000266AC, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000267A0, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026894, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026988, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026A7C, src=0x20006124, len=244 bytes), queue usage: 1
00> <debug> nrf_
