blinky_freertos example adds Serial UART but nrf_serial_init() fail
SDK version: nRF5_SDK_15.3.0
Platform: nRF52840 DK
SoftDevice: s140
Hi All,
I use blinky_freertos example to add nrf_serial lib to send/receive AT command by UART port.
It's work when I press "build and run" on SES IDE,
bit if I switch the power key on nRF52840DK, it's didn't work.
I try to trace to find that nrf_serial_init() call nrf_queue_reset() and the nrf_queue_reset() can not return.
I don't know why.
NRF_SERIAL_UART_DEF(serial1_uarte, 1);
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
                      ARDUINO_0_PIN, ARDUINO_1_PIN,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_115200,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
                      &serial1_queues, &serial1_buffs, NULL, sleep_handler);
static void uart_init(void)
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
#if defined (UART_PRESENT)
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
    ret_code_t err_code;
    ret_code_t ret;
    uart_init();
    ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    ret = nrf_drv_power_init(NULL);
    ret = app_timer_init();
    bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
    ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
    xMutex = xSemaphoreCreateMutex();
    at_setting(_AT, 3000);
    at_setting(_QICSGP, 200);
    at_setting(_QIACT_1, 2000);
    at_setting(_QIACT_IP, 2000);
    // MQTT AT Command
    at_setting(_QMTCFG_VER_0, 300);
    at_setting(_QMTOPEN_0, 5000);
    at_setting(_QMTCONN_0, 3000);
    if( xMutex != NULL )
      UNUSED_VARIABLE(xTaskCreate(mqtt_sub_task_function, "SUB", configMINIMAL_STACK_SIZE + 200, NULL, 3, &mqtt_sub_task_handle));
      UNUSED_VARIABLE(xTaskCreate(mqtt_pub_task_function, "PUB", configMINIMAL_STACK_SIZE + 200, NULL, 3, &mqtt_pub_task_handle));
      // Activate deep sleep mode
      SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
      vTaskStartScheduler();
    while (true)
        // FreeRTOS should not be here... FreeRTOS goes back to the start of stack
        // in vTaskStartScheduler function.
BTW, this example I use app_timer(RTC1) and FreeRTOS timer(RTC2)
Thanks.
Tim
  • should we close this case then? I do not understand, why did you open a new case with the same project and the same description?
  • before I add
     <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
    to flash_placement.xml to fix "region `UNPLACED_SECTIONS' overflowed by xx bytes"
    but I put it into wrong place as below
     <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
       <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack"  address_symbol="__StackLimit" end_symbol="__StackTop"/>
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
    </Root>
    Now I put it into the right place,
    Its solve my first issue
    "if I switch the power key on nRF52840DK, it's didn't work."
  • You seems to have enabled Tickless IDLE mode in freeRTOSConfig.h file
    #define configUSE_TICKLESS_IDLE 1
    And you are managing the sleep in your application explicitly using sleep_handler. This both does not go together. Disable the tickless idle so that you can manage your application sleep pattern just by calling sleep_handler when needed. FreeRTOS tick handler will not try to manage your device power.
    .I am not able to reproduce the problem you are mentioning here, that it does not work in non debug mode.
    The behavior is pretty same both in debug and non debug mode at my desk.
