nrf_delay_ms not working?
Hello Nordic Pros,
Doing some debugging using RTT Viewer and an nRF51822 under SDK12.3.  Here is the code lines of interest:
    NRF_LOG_INFO("IPHONE 'PPM' RECEIVED @ %d mS\r\n", m_life_count_msec);
    nrf_delay_ms(2000);
    NRF_LOG_INFO("ID QUERY '?' SENT AT: %d\r\n", m_life_count_msec);
And here are the log messages:
iDrink::INFO:IPHONE 'PPM' RECEIVED @ 683250 mS
iDrink::INFO:ID QUERY '?' SENT AT: 683250
m_life_count_msec is a copy of an app timer count in mSec that is set up to inc ~ every 50 mSec.
Here is the timer setup code:
  app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timeout_handler);  //create and start timer...
  app_timer_start(m_app_timer_id, APP_TIMER_TIMEOUT_TICKS, (void*) 0);
And here is the timeout code showing the assignment to m_life_count_msec:
void timeout_handler(void * context)
  m_life_count_msec   += APP_TIMER_MS_COUNT;
Obviously the questions is, why is there not a 2000 mSec delay between the two log messages?
Does nrf_delay_ms() suspend m_app_timer while it is counting?
Help, please!
Robin @ TL
  • So let me try to get this straight...Even though the handler is getting called every 50 mSec, because the function I call is within the handler, the variable does not get updated?  That sounds, to me, like the app timer is being blocked by the delay function.  I was unaware that the delay was a "synchronous" function, so that explains it.  I guess I should have looked deeper into the code I I was using, rather than assume it was asynchronous.
    The silly thing here is... all I was trying to do, was confirm that the delay was happening.  At some level, I would thought ( or maybe more appropriately, hoped) that anything named with "delay" in it would have a very similar structure.
    Thank you all for an embarrassingly basic lesson.
    Obviously this embedded coding stuff has not been my first engineering task in life.
    Thanks again,
    Robin @ TL
  • I'd put it slightly differently, the handler is not getting called every 50ms, the timer is raising an interrupt isevery 50ms. If the processor is running anything with lower priority, then it takes the interrupt and runs the handler, else the interrupt just pends. When the processor returns from the interrupt handler it was running, then it runs the next handler for the highest priority pended interrupt.
    If the ISR doesn't return quickly, the interrupt keeps firing and firing and firing, but the processor cannot interrupt itself for something of equal or lower priority, so those interrupts just pend and coalesce into one which does get called when the first handler call finally returns.
    In your case the first call of the handler didn't return for about 2 seconds because it was stuck in nrf_delay_ms which is basically a carefully implemented in assembler for-loop designed to keep the processor spinning for a number of milliseconds. As soon as it did return, the handler would have been called again as there were missed interrupts, 40 of them, but by then you've done both LOGs and exited and your counter has missed 2 seconds of counts.
