I faced a problem while building my project. Please see screenshot below
I think I have already include all the files and everything compiled. But this error shows up at the very end. Please advise.
Thank you.
Thank you.
Hi.
lsvw1217 said:I made a modification and that is adding "nrfx_power_clock.c" from previous SDK since it wasn't included in the newest SDK.
Can you please remove nrfx_power_clock.c from the project? This file is in SDK 15.3 split up into two different files, nrfx_clock.c and nrfx_power.c.
And add the file you need, nrfx_clock.c.
Andreas
Not having the header #included in the source where needed would give compiler errors (or warnings) - but these are Linker errors.
The header gives the necessary declarations to the compiler - but the Linker needs to see the definitions.
http://c-faq.com/decl/decldef.html
This error usually means that the header has been #included in the source (giving the declarations to the Compiler) - but the .c (or pre-built binary) containing the definitions is missing - hence the Linker complains about things being "un-defined"
The above is standard 'C' stuff - not specific to Nordic or microcontrollers.
But with the Nordic SDK specifically there is an extra twist: many features have to be enabled by settings in the sdk_config.h; so, even with the correct headers #included, and all the correct .c files in the Project, you can still get 'Undefined' Linker errors - because the content of the 'C' files is disabled by conditional compilation such as:
#if NRF_MODULE_ENABLED(NRF_CLOCK)
adding [anything] from previous SDK
is never a good idea!
The whole point of going to all the effort of making a separate SDK release is (as AndreasF says) that things are not the same - so you can't just go taking stuff from one SDK and dropping it willy-nilly into a different SDK!
Hi Andreas and awneil,
Oh I didn't know that. So I tried installing a whole new SDK 15.3 and deleting nrfx_power_clock.c and also make sure app_timer is enabled in the sdk.config. But the same error still shows up.
I've tried to search the error online and found this.
https://devzone.nordicsemi.com/f/nordic-q-a/51106/linker-issue-in-sdk15-2
According to Amanda, it might be due to different version of app_timer.c in the SDK.
But right now I'm using a whole new SDK 15.3, and files are not modified. So I think they should be from the same version.
Is there anything else I can try? Maybe download a previous version of SDK?
Also, could you provide a link to download the newest version of SDK? Maybe I'm downloading the wrong one.
Thank you so much!
Hi.
Please make sure that you download SDK 15.3 here.
If you have not worked much with your project, I suggest that you start a new project with a clean downloaded SDK so that you are sure that it contains the correct files.
Andreas
