Maximum Reload time for WDT
Hi Guys,
We have a need to send data every 4 hours.
In order to do this, we sleep 1 hour at a time (1-hour timer - single shot) and increment counter, and when the count is 4 we send the data. This is working well.
Due to unknown reasons the device sometimes can get hung when trying to send the data.
Our plan was to set the WDT_CONFIG_RELOAD_VALUE to 120000000, to make sure we reset the device after 1 hour if it got stuck.
But we are unable to provide values more than 600000 (which triggers at 100 seconds).
Can u suggest a way to configure such a large interval?
regards
Shankar
  • Hi Stian,
    I am actually using nRF52833 which doesn't have ULP mode. Best result is 1.4uA when I select LFXO. As you can see I use 1000 second WDT reload timeout, to enable longer startup time for LFXO. But I don't see variation if I wait for longer. With RC oscillator I am measuring 1.9uA.
    I use NRF Power Profiler for measurement, VDD is 3V.
    Is this the best I can get with 52833? Or maybe my consumption is higher because of process variation?
    1.4uA is still an improvement compared to 2.3uA sleep current measured in the past when I simply use timer to wakeup and with full RAM retention
        NRF_CLOCK->LFCLKSRC = 1; // LFXO
        //NRF_CLOCK->LFRCMODE = 1; // ULP mode
        //NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_RC << CLOCK_LFCLKSRC_SRC_Pos);
        NRF_CLOCK->TASKS_LFCLKSTART = 1; // Start LF clock
        while(!NRF_CLOCK->EVENTS_LFCLKSTARTED){
        NRF_WDT->CRV = 32768000; // WDT wakeup every 100 sec
        NRF_WDT->TASKS_START = 1; // start WDT
        for(int i = 0; i < 8; i++){
            NRF_POWER->RAM[i].POWERCLR = 0x3; // Turn off RAM block 0-7
        NRF_POWER->RAM[8].POWERCLR = 0x3F; // Turn off RAM block 8
        for(;;){
            __WFE();
  • Hi, the base current is a little bit higher on 833.
    ION_RAMOFF_EVENT
    System ON, no RAM retention, wake on any event
    1.1
    µA
    So 1.1 + .23 = 1.33 uA, which is the expected typical current. And yes, if you get higher (or lower) current it's because of process variation.
