LTE Link connecting is blocking?
Hi
In the mqtt_simple example there is a line "modem_configure();" which establishes the LTE Link connection. If connecting the LTE link is not possible (for example no signal), this function never returns.
1. Is this the intention of this function or is there a possibility to configure a timeout?
2. Is it normal, that this function needs several minutes to establish the LTE link, if a provider is present?
regards
ExAg
  • Nothing is pointing to anything wrong on your side (nRF91), the network seems to have some capacity issues or other issues causing temporary registration failures.
    However, without seeing additional logs from various delays we are not able to say anything for sure, there are always possibilities for errors in modem SW or maybe we can suggest workarounds for certain problems.
    If you can provide more logs we can check those.
    One thing I would suggest is to check with the operator that the SIM they are using is intended for IoT devices and is expected to work in the M1 network.
    Simon
  • Hi Simon
    Thank you for your answers. So its most likely an issue of our national telecom provider. I will discuss this with them. Because these long connection times have a big influence of the total power consumption of an battery powered IoT device out in the field.
    The SIM card is specially for IoT purpose (for the M1 Network; NB is not yet supported at the moment).
    Best regards
    Michael
     Yes, based on the trace you sent. If you sent more traces from other delays, we can confirm this with more certainty.
    Simon
  • Hi Simon
    Here are some more trace files for you to analyse if you want. Today there was no single LTE connection attempt shorter than about 2 minutes. But I think you will see that in the trace files.
    Traces11_11_2019.zip
    I had some difficulties to record the traces this time because the connection between the Trace Collector and the eval board or the connetion between the LTE link monitor and the eval board were lost relatively often. I have no idea why...
    Best regards
    Michael
  • Thank you. I have provided the trace files internally and will report to you as soon as I get a reply.
    Simon
