Updating Advertising Parameters
I'm writing a BLE app that acts as a peripheral and a broadcaster. If a connection is established, I'd like to continue advertising but update the advertising parameters from connectable to non-connectable. Following the broadcaster example I wrote the following code to setup and start advertising.
static int advertising_init(void)
    uint32_t err_code;
    ble_advdata_t advdata;
    memset(&advdata, 0, sizeof(ble_advdata_t));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    ble_uuid_t adv_uuid = {BLE_UUID_NUS_SERVICE, m_nus.uuid_type};
    advdata.uuids_complete.uuid_cnt = 1;
    advdata.uuids_complete.p_uuids  = &adv_uuid;
    // encode the adv data for use when updating adv data
    m_adv_data.adv_data.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX;
    err_code = ble_advdata_encode(&advdata, m_encoded_adv_data[0], &m_adv_data.adv_data.len);
    APP_VIEWER_ERROR_CHECK(err_code);
    err_code = ble_advdata_encode(&advdata, m_encoded_adv_data[1], &m_adv_data.adv_data.len);
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = MSEC_TO_UNITS(1000, UNIT_0_625_MS);
    m_adv_params.duration        = 0;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    err_code = sd_ble_gap_adv_start(m_adv_handle, 1);
    return 0;
When a connection is established, the below function is called to update the advertising parameters.
void app_viewer_on_connected(uint16_t ch)
    uint32_t err_code;
    NRF_LOG_INFO("Viewer Connected.");
    conn_handle = ch;
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
The issue I'm encountering is that the device still advertises as a connectable device. I'm not seeing any errors returned from the Softdevice. Is sd_ble_gap_adv_set_configure() the correct function to update advertising parameters and am I using it properly?
I'm using:
  • nRF52832
  • SDK 15.2
  • S132 6.1.0
Eric
  • We tried to reproduce the bug, but with no success. It advertises as non-connectable after the first connection. For the record, we are using the multiperipheral sample to test your code, since you didn't provide the entire main.c.
  • Hakon,
    I've recreated the issue using the multiperipheral example. Here is what I modified from the main.c:
    static void on_connected(const ble_gap_evt_t * const p_gap_evt)
        ret_code_t  err_code;
        uint32_t    periph_link_cnt = ble_conn_state_peripheral_conn_count(); // Number of peripheral links.
        NRF_LOG_INFO("Connection with link 0x%x established.", p_gap_evt->conn_handle);
        // Assign connection handle to available instance of QWR module.
        for (uint32_t i = 0; i < NRF_SDH_BLE_PERIPHERAL_LINK_COUNT; i++)
            if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
                err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], p_gap_evt->conn_handle);
        err_code = app_button_enable();
        // Update LEDs
        bsp_board_led_on(CONNECTED_LED);
        if (periph_link_cnt == NRF_SDH_BLE_PERIPHERAL_LINK_COUNT)
            ble_gap_adv_params_t adv_params;
            memset(&adv_params, 0, sizeof(adv_params));
            adv_params.interval      = APP_ADV_INTERVAL;
            adv_params.duration        = APP_ADV_DURATION;
            adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
            err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, NULL, &adv_params);
            advertising_start();
            // Continue advertising. More connections can be established because the maximum link count has not been reached.
    Once periph_link_cnt equals NRF_SDH_BLE_PERIPHERAL_LINK_COUNT, I try to update the advertising parameters to BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED. sd_ble_gap_adv_set_configure() returns success and the advertising data is updated correctly, but it is still connectable.
    Here is the entire main.c file for reference:
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief Multiperipheral Sample Application main file.
     * This file contains the source code for a sample server application with multiple peripheral connections using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "boards.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "ble_conn_state.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define LINK_TOTAL                      NRF_SDH_BLE_PERIPHERAL_LINK_COUNT + \
                                            NRF_SDH_BLE_CENTRAL_LINK_COUNT
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    /**@brief   Priority of the application BLE event handler.
     * @note    You shouldn't need to modify this value.
    #define APP_BLE_OBSERVER_PRIO    3
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                          /**< Context for the Queued Write module.*/
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t        srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.include_appearance = true;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        // Start advertising.
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON from link 0x%x!", conn_handle);
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF from link 0x%x!", conn_handle);
        ble_lbs_init_t     init;
        // Initialize Queued Write Module instances.
        for (uint32_t i = 0; i < LINK_TOTAL; i++)
            err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
        ble_conn_state_init();
    /**@brief Function for handling a Connection Parameters error.
        cp_init.disconnect_on_fail             = true;
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
    /**@brief Function for handling the Connected event.
     * @param[in] p_gap_evt GAP event received from the BLE stack.
        // Update LEDs
    /**@brief Function for handling the Disconnected event.
    static void on_disconnected(ble_gap_evt_t const * const p_gap_evt)
        NRF_LOG_INFO("Connection 0x%x has been disconnected. Reason: 0x%X",
                     p_gap_evt->conn_handle,
                     p_gap_evt->params.disconnected.reason);
        if (periph_link_cnt == 0)
            bsp_board_led_off(CONNECTED_LED);
            err_code = app_button_disable();
        if (periph_link_cnt == (NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - 1))
            // Advertising is not running when all connections are taken, and must therefore be started.
            case BLE_GAP_EVT_CONNECTED:
                on_connected(&p_ble_evt->evt.gap_evt);
                on_disconnected(&p_ble_evt->evt.gap_evt);
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                err_code = sd_ble_gatts_sys_attr_set(p_ble_evt->evt.gap_evt.conn_handle, NULL, 0, 0);
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for writing to the LED characteristic of all connected clients.
     * @details Based on if the button is pressed or released, this function writes a high or low
     *          LED status to the server.
     * @param[in] button_action The button action (press/release).
     *            Determines if the LEDs of the servers will be ON or OFF.
     * @return If successful NRF_SUCCESS is returned. Otherwise, the error code from @ref ble_lbs_led_status_send.
    static uint32_t led_status_send_to_all(uint8_t button_action)
        ble_conn_state_conn_handle_list_t conn_handles = ble_conn_state_periph_handles();
        for (uint8_t i = 0; i < conn_handles.len; i++)
            err_code = ble_lbs_on_button_change(conn_handles.conn_handles[i], &m_lbs, button_action);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE &&
                err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                NRF_LOG_DEBUG("Sent button change 0x%x on connection handle 0x%x.", button_action, conn_handles.conn_handles[i]);
        return NRF_SUCCESS;
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                err_code = led_status_send_to_all(button_action);
                if (err_code == NRF_SUCCESS)
                    NRF_LOG_INFO("Sent button state change to all connected centrals.");
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    /**@brief Function for initializing the logging module.
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Function for application main entry.
        // Initialize.
        log_init();
        timers_init();
        leds_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("Multiperipheral example started.");
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Let me you if there's other information that will help.
  • Try changing the line
    to
  • That was the first thing I tried. I changed the adv data to NULL so I could see the adv data update correctly and the adv parameters fail to update when I connect to it.
    • Are you able to recreate the issue?
    • Are there known issues with updating advertising parameters on a preexisting advertising set?
    • Is there another way to advertising parameters?
    I also tried this on S132 7.0.1 but experienced the same issue.
     No.
     No that I know. All I know is you need to change the buffers everytime you update as explained in the post I linked, but apparently that is not the problem.
     Other than?
