Color sensor pca20035
Dear,
I am using thingy:91 pca20035 and try to test the color sensor BH1749NUC
I tried to run the /samples/sensor/bh1749
I got the output:
SPM: NS image at 0xc000
SPM: NS MSP at 0x20020a78
SPM: NS reset vector at 0xde51
SPM: prepare to jump to Non-Secure image.
***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-1270-gb1d603491de8 *****
device is 0x20021d9c, name is BH1749
[00:00:00.004,913] [1B][0m<inf> BH1749: BH1749 initialized[1B][0m
I expected it will return the color in process(dev); but I got nothing.
Do I need to do some "trigger" to enable sensor?
BR,
Hoang Nguyen
  • Hello, yes I am here Slight smile
    Actually I changed it in SES, through Project→Configure nRF Connect...→(search for trigger in top right corner and unhooked the box "Trigger for BH1749"). But I think setting to (=n) it in prj.conf should do the same.
    I also used the master branch (not NCS v1.0.0).
    Did you put the file ncs\nrf\dts\bindings\sensor into ncs\zephyr\dts\bindings\sensor?
    I used the code in \ncs\nrf\samples\sensor\bh1749.
    Simon
  • Thanks Simon,
    ja, I am using master branch also
    I will try ........................
  • Actually I changed it in SES, through Project→Configure nRF Connect...→(search for trigger in top right corner and unhooked the box "Trigger for BH1749"). But I think setting to (=n) it in prj.conf should do the same.
    Ja, you right,
    Ja, I am using the same branch
    I just tried it, in ncs\zephyr\dts\bindings\sensor missed file rohm,bh1749.yaml
    I am using the same one
    My result:
    Peripheral		Domain		Status
    00 NRF_P0		Non-Secure	OK
    01 NRF_CLOCK		Non-Secure	OK
    02 NRF_RTC1		Non-Secure	OK
    03 NRF_NVMC		Non-Secure	OK
    04 NRF_UARTE1		Non-Secure	OK
    05 NRF_TWIM2		Non-Secure	OK
    06 NRF_SPIM3		Non-Secure	OK
    07 NRF_TIMER0		Non-Secure	OK
    08 NRF_TIMER1		Non-Secure	OK
    09 NRF_TIMER2		Non-Secure	OK
    10 NRF_SAADC		Non-Secure	OK
    11 NRF_PWM0		Non-Secure	OK
    12 NRF_PWM1		Non-Secure	OK
    13 NRF_PWM2		Non-Secure	OK
    14 NRF_PWM3		Non-Secure	OK
    15 NRF_IPC		Non-Secure	OK
    16 NRF_VMC		Non-Secure	OK
    17 NRF_FPU		Non-Secure	OK
    18 NRF_EGU1		Non-Secure	OK
    19 NRF_EGU2		Non-Secure	OK
    20 NRF_GPIOTE1		Non-Secure	OK
    SPM: NS MSP at 0x20020a70
    SPM: NS reset vector at 0xdda1
    device is 0x20021d94, name is BH1749
    [00:0sensor_sample_fetch failed ret -5
    [00:00:00.010,742] [1B][1;31m<err> BH1749: No valid data to fetch.[1B][0m
  • I built a secure application and modified the prj.conf as well:
    CONFIG_LOG=y
    CONFIG_I2C=y
    CONFIG_SENSOR=y
    CONFIG_BH1749=y
    CONFIG_BH1749_TRIGGER=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    But I changed CONFIG_BH1749_TRIGGER in SES after, so it was eventually set to n
    I will see if I am able to recreate your error.
    Simon
  • hi @Simon,
    I changed the prj.conf as your:
    (added)
    and ran again:
    nothing come ( run NS)
    SPM: NS MSP at 0x20020f38
    SPM: NS reset vector at 0xdff1
    Could you please share your code, is it possible?
    BR,
    Hoang Nguyen
