GPIO interrupt after wake up
Hello
My custom board has only 1 button and I'm trying to detect 3 button clicks. The first click is waking up the device and the other 2 are configured as BSP_EVENT_KEY_0.  I noticed people pushes the button between 0.2s to 0.4s after each click and the nRF52832 is not detecting the second click and the button has to be pressed a 4th time.
The IRQ prority is already at 2. I´m not sure if I should put it higher. My guess is that something in the main has higher priority and it is ignoring the bsp event
The only problem i have is when the device is sleeping. When the device is advertising the interruptions work fine. Any idea what is happening?
Here is my main,
    bool       wakeup;
    ret_code_t err_code;
    log_init();
    // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
    err_code = ble_dfu_buttonless_async_svci_init();
    timers_init();
    buttons_leds_init(&wakeup);
    my_fstorage_init();
    if(wakeup)
        timer_counter();
    power_management_init();
    fstorage_read(0x66C00,4);
    ble_stack_init();
    peer_manager_init();
    gap_params_init();
    gatt_init();
    services_init();
    conn_params_init();
    advertising_init();
    //saadc init
    saadc_init();
    saadc_sampling_event_init();
    adv_init_and_start();
    NRF_LOG_INFO("GWi DFU Application started.");
    // Enter main loop.
    for (;;)
        idle_state_handle();
SDK15.2
nrf52832 custom board
nrf52DK
windows 10
segger v4.16
  • Sorry that it took me a couple of months to reply.
        bsp_led_state = BSP_INDICATE_IDLE;
        // Prepare wakeup buttons.
        //Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
        //GPREGRET2 register holds the information about skipping CRC check on next boot.
        err_code = nrf_sdh_disable_request();
    the reference manual says the default is system ON. I'm not sure where to change that.
  • Use nrf_pwr_mgmt_run(); instead. It will put the system into SystemON, Idle. And it will not reset the MCU when it wakes up.
  • Keeping the device awake consumes too much battery so I decided to go back and try to fix the issue with nrf_sdh_enable.
    Defining NRF_SDH_CLOCK_LF_SRC as NRF_CLOCK_LF_SRC_RC
    or NRF_CLOCK_LF_SRC_XTAL takes a lot of time for nrf_sdh_enable to resolve. Using NRF_CLOCK_LF_SRC_SYNTH executes it faster. I don´t know why. For now I will just keep it like this. Thank you for the help.
