Getting started with the Thingy:91
Trying to get started with the Thingy:91
- It's connecting to NRF Cloud and reporting data.
Problems:
1. Keeps blinking blue and does not get a GPS lock. I did leave it near the window. I did hold down the button for more than 10 seconds as suggested in another post, to turn on the GPS. I'm in Vancouver, Canada and using the iBasis SIM. How would I find out if this is because my provider does not support power saving mode?
2. Is the LTE Link monitor supposed to work over USB? I connected it via USB but I get "No devices available". I did uncheck auto device port filter.
I don't have a NRF9160 DK.
Thanks!
Calin
  • Thank you Didrik for your reply.
    Here is what I get for CEREG level 5
    AT+CEREG?
    +CEREG: 5,5,"8980","061B8B0B",7,,,"11100000","11100000"
    Please let me know if you make any progress.
    Cheers,
    Calin
  • The problems reported with %XMONITOR and CEREG seems to be confusion on the customers part.
    The two last values of the CEREG level 5 response is the ones related to PSM, Active-Time (the time after a transmit event when the device is reachable) and Periodic-TAU (the time between regular transmit events to keep the connection alive).
    The meaning of the values can be found in 3GPP TS 24.008, section 10.5.7.4, but long story short, when they start with "111" the timers are not active, i.e. you do not have PSM activated.
  • Hi Didrik,
    I got a local SIM, not roaming, and finally got it to connect. Then I updated the asset_tracker application from git, and now it seems I cannot send AT commands anymore. I get getddadrinfo failed, probably because the APN is not set and I cannot set it because I cannot send AT commands. Any ideas how I can make it accept AT commands?
    Is there a known good version of the asset tracker that works on the thingy and takes AT commands?
    Calin
  • This is what I get:
    ***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-1279-g1c3a001f62e6 *****\x0D\x0A
    2019-11-02T05:51:11.749Z DEBUG modem << Asset tracker started\x0D\x0A
    2019-11-02T05:51:11.792Z DEBUG modem << [00:00:00.413,757] \x1B[0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100833741\x1B[0m\x0D\x0A
    2019-11-02T05:51:11.829Z DEBUG modem << [00:00:00.423,095] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100833741/shadow\x1B[0m\x0D\x0A
    2019-11-02T05:51:12.049Z DEBUG modem << [00:00:00.434,875] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: $aws/things/nrf-352656100833741/shadow/get/accepted\x1B[0m\x0D\x0A
    2019-11-02T05:51:12.107Z DEBUG modem << [00:00:00.447,570] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100833741/shadow/get/rejected\x1B[0m\x0D\x0A
    2019-11-02T05:51:12.149Z DEBUG modem << [00:00:00.460,235] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100833741/shadow/update/delta\x1B[0m\x0D\x0A
    2019-11-02T05:51:12.188Z DEBUG modem << [00:00:00.473,266] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100833741/shadow/update\x1B[0m\x0D\x0A
    2019-11-02T05:51:12.233Z DEBUG modem << [00:00:00.485,229] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100833741/shadow/get\x1B[0m\x0D\x0A
    2019-11-02T05:51:12.248Z DEBUG modem << Connecting to LTE network. This may take several minutes.\x0D\x0A
    2019-11-02T05:51:18.284Z DEBUG modem << [00:00:01.669,128] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"2B01","01AE1C0B",7\x0D\x0A
    2019-11-02T05:51:18.299Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-11-02T05:51:18.313Z DEBUG modem << [00:00:03.716,339] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 1,"2B01","01AE1C0B",7\x0D\x0A
    2019-11-02T05:51:18.326Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-11-02T05:51:18.339Z DEBUG modem << Connected to LTE network\x0D\x0A
    2019-11-02T05:51:18.352Z DEBUG modem << [00:00:03.727,050] \x1B[0m<dbg> nrf_cloud_transport.nct_connect: getaddrinfo failed 22\x1B[0m\x0D\x0A
    2019-11-02T05:51:18.371Z DEBUG modem << cloud_connect failed: 22\x0D\x0A
    2019-11-02T05:51:18.385Z DEBUG modem << LTE link disconnect\x0D\x0A
    2019-11-02T05:51:18.399Z DEBUG modem << Shutdown modem\x0D\x0A
  • I hardcoded the IP address, bu then I get
    [00:00:05.122,161]
    [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 0x34ce4b60
    [0m
    cloud_connect failed: -111
    LTE link disconnect
    Shutdown modem
