Transfer Speeds at 100m with 15 devices
Hey,
I am having trouble validating this idea through research. I was hoping someone could give me some ballpark feedback.
The setup:
- 15 NRF52832 devices on custom PCB (30mmx50mm)
- All around 100m away outside with little to no obstacles in the way
- I need to stream data from each device. This means that the Bluetooth transfer speed needs to be faster than the combined data collection speed.
- Each device collects at 24kbps. So there is a combined 360kbps of data.
I imagine that I need to connect to each device individually and receive data. Then cycle through to the next device.
The connection parameters would be:
- BLE 5.0
- PHY: 2M
- TX power: 4dB
- connection interval 7.5ms
- data packet length extension on
- connection event length extension on
I can calculate theoretical transfer speeds using the nordic online power profiler. However, it's hard to get data at long distances. Also, I am not sure if I can cycle through the 15 devices fast enough?
Can I achieve this transfer rate (360kbps) at 100m? If not, what distance should be OK?
  • I mean an implementation that uses radio directly. In this case, you have no overhead of LL/L2CAP/ATT layers and acknowledgements, and you have full control over timings, thus avoiding collisions. Of course, this is more complex challenge than using BLE.
    To confirm, you think a simple custom protocol could communicate with 15 devices 70 Metres away sampling at 360kbps (total)?
    I cannot confirm this (there are too many factors), you have to do some expreriments. What I can say exactly - Coded PHY will give you a longer distance, and in your case Coded PHY is possible only with custom protocol.
