Debugging blinky example with GNU Eclipse with SDK7.x
I'm trying to debug the blinky example with SDK 7.1 using Eclipse Luna. Going through several threads here I could figure out configurations needed and build the app. I can download the app through nRF studio and it works fine. However the issue comes while debugging. I get the following error (see screen shot) while I hit run.
Following is the error on J-link console. Application has been compiled with -O0 -g3 flags
SEGGER J-Link GDB Server V4.96 Command Line Version
JLinkARM.dll V4.96 (DLL compiled Dec 22 2014 09:51:48)
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      localhost only
Generate logfile:              off
Verify download:               on
Init regs on start:            on
Silent mode:                   off
Single run mode:               on
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 nRF51422_xxAC
Target interface:              SWD
Target interface speed:        1000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Nov 28 2014 10:32:04
Hardware: V1.00
S/N: 681110165
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 1 bytes @ address 0x00000000 (Data = 0xFF)
Target interface speed set to 1000 kHz
Resetting target
Halting target CPU...
...Target halted (PC = 0xFFFFFFFE)
R0 = FFFFFFFF, R1 = FFFFFFFF, R2 = FFFFFFFF, R3 = FFFFFFFF
R4 = FFFFFFFF, R5 = FFFFFFFF, R6 = FFFFFFFF, R7 = FFFFFFFF
R8 = FFFFFFFF, R9 = FFFFFFFF, R10= FFFFFFFF, R11= FFFFFFFF
R12= FFFFFFFF, R13= FFFFFFFC, MSP= FFFFFFFC, PSP= FFFFFFFC
R14(LR) = FFFFFFFF, R15(PC) = FFFFFFFE
XPSR C1000000, APSR C0000000, EPSR 01000000, IPSR 00000000
CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
Select auto target interface speed (1000 kHz)
Flash breakpoints enabled
Semi-hosting enabled (VectorAddr = 0x08)
Semihosting I/O set to TELNET Client
Downloading 1200 bytes @ address 0x00000000 - Verified OK
Downloading 8 bytes @ address 0x000004B0 - Verified OK
Downloading 100 bytes @ address 0x000004B8 - Verified OK
Writing register (R8 = 0x00000439)
Read 1 bytes @ address 0x00000439 (Data = 0x21)
Reading 14 bytes @ address 0x00000439
Read 1 bytes @ address 0x0000033C (Data = 0x80)
Reading 14 bytes @ address 0x0000033C
Resetting target
...Target halted (PC = 0x00000438)
R12= FFFFFFFF, R13= 20008000, MSP= 20008000, PSP= FFFFFFFC
R14(LR) = FFFFFFFF, R15(PC) = 00000438
Read 1 bytes @ address 0xFFFFFFFF (Data = 0x00)
Setting breakpoint @ address 0x0000033C, Size = 4, BPHandle = 0x0002
Starting target CPU...
...Breakpoint reached @ address 0x0000033C
Removing breakpoint @ address 0x0000033C, Size = 4
image description
